Displacement of water for a boat and raft
  • Context: High School
  • Thread starter Thread starter donquixote17
    Boat Displacement Water
The discussion centers on the water displacement of a flat, rectangular raft versus a flat, rectangular boat, emphasizing that displacement is determined by the weight of the object. Participants clarify that if both the raft and the boat have the same mass, their water displacement will be identical, as per Archimedes' principle. The conversation highlights the importance of understanding the functional differences between a raft and a boat, particularly in the context of a cardboard boat design for shallow waters.
  • Understanding of Archimedes' principle
  • Basic knowledge of buoyancy and water displacement
  • Familiarity with the concepts of mass and weight
  • Knowledge of boat design principles, particularly for shallow water applications
  • Research Archimedes' principle and its applications in fluid mechanics
  • Explore the design considerations for cardboard boats in shallow waters
  • Learn about the differences in buoyancy between solid and hollow structures
  • Investigate methods for calculating water displacement for various shapes
This discussion is beneficial for marine engineers, boat designers, and hobbyists involved in constructing floating objects, particularly those interested in optimizing designs for shallow water environments.
donquixote17
If you have a perfectly flat, rectangular raft and a perfectly flat, rectangular boat, which will displace more water? Or will the water displacement be the same.
I remember that the water displacement is dependent on the shape of the floating object and the weight, but I can't remember exactly how to calculate the water displaced.
This is for a cardboard boat design in a pretty shallow creek, so vertical displacement is the most important factor. Thanks!
First thing we need to understand is the functional difference is between a raft and a boat in your world.
I am going to guess that the functional difference between the two is that a boat is a hollow rectangle, whereas a raft is a solid rectangle. Would this be correct?
...assuming that's the case and assuming the mass is the same, displacement, as Archimedes figured out, is equal to the weight of the boat/raft, so...
russ_watters said:
... assuming the mass is the same...
That was going to be my next question. The OP has not provided enough detail and I wasn't prepared to take it for granted (If you assume the mass is the same then there is no functional difference at all between a raft and a boat). I figured I'd tease it out of him while he worked it through.
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 32 ·
10K
  • · Replies 35 ·
11K
