Distance traveled with acceleration & deceleration
The discussion revolves around a bungee jumping scenario where a jumper free falls for 3 seconds and is then decelerated by the bungee cord over 5 seconds. Participants are exploring how to calculate the total distance fallen, considering the effects of gravity and deceleration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of kinematic equations and the importance of sign conventions for acceleration due to gravity. There are attempts to calculate distances for both the free fall and the deceleration phases, with varying interpretations of the results based on sign usage.
There is an ongoing exploration of different methods to approach the problem, including the use of average velocity. Some participants have provided guidance on understanding sign conventions and the implications of constant acceleration, while others are questioning their assumptions and calculations.
Participants are navigating the complexities of sign conventions in physics, particularly regarding the direction of gravity and how it affects their calculations. There is also mention of the need for clarity on the average velocity formula and its application in this context.
mattcom1
A man bungee jumps off a cliff and free falls for 3 seconds. The bungee cord stops the jumper in 5 seconds. How far did the man fall in total?
X = V0t + 1/2at2
Xf = X1 + X2
X1 = V1it1 + 1/2a1t12
X1 = 0 * 3 + 1/2 * -9.8 * 32
X1 = -44.1m or 44.1m (not sure if I should keep this absolute value or not...)
X2 = V2it2 + 1/2a2t22
v2i = v1f = a1 * t1
a2 = Δv/t = (v2f - v2i)/t = (v2f - (a1*t1))/t2
a2 = (0 - (-9.8*3))/5 = 5.88
X2 = (-9.8 * 3) * 5 + 1/2 * 5.88 * 25
X2 = either -73.5m, 73.5m, or 220.5m [(9.8*3)*5 + 1/2*5.88*25] ? depending on whether everything is in absolute values or not, once again, I'm not sure.
Xf = -44.1m + -73.5m
Xf = -117.6m or 117.6m
Thanks!
Is acceleration due to gravity +ve or -ve ?
Your method is basically correct . What you need to do is understand your sign convention .
Hope this helps .
If you want a quick way to solve problems like this, think about the average speed for each part of the fall. I assume the bungee deceleration is taken to be constant?
I'm glad to hear I'm not too far off on the methodology. I'm going to stick with -ve for gravity.
Yes, I believe that the deceleration is intended to be constant.
Try to find the quick way! First, what's the average speed for the free fall?
Hmmm... The only formula I know for average velocity is: Avg Velocity = Distance/Time. Distance is unknown and Avg Velocity is unknown. Is there another equation for avg velocity that I'm not aware of?
For constant acceleration from rest, average velocity is ##\frac{at}{2}##
Interesting. Let me give it a go.
X = V1avg * t1 + V2avg * t2
X = 0.5 * a1t1 * t1 + 0.5 * a2t2 * t2
X = (0.5 * -9.8 * 3) * 3+ (0.5 * 5.88 * 5) * 5
X = -44.1 + 73.5
similar numbers as the first way, but a different sign... Certainly something else to consider! Thanks!
X = -44.1 + 73.5
You need to be careful with your signs. IMHO, you are trying to plug numbers into equations without thinking enough. If gravity is negative, then the downward direction is negative, so all your displacements and velocities should be negative.
In this case, it would have been better, therefore, to take the downward direction as positive.
Here's another question: what can you say about the average velocity for the free fall and the deceleration?
You seem to be confused with your acceleration .
If this is the case , first assign your convention .
For example , let upward direction be -ve and downward +ve . Now , solve everything following this convention - Remember , all your variables ( except t ) are vectors , so pay careful attention to the sign .
15K
9K
