Distinguish between polyunsaturated vegetable oil and petroleum oil
  • Thread starter Thread starter xiaofupo
    Oil Petroleum
The discussion focuses on distinguishing between polyunsaturated vegetable oil and petroleum oil using various chemical reactions. The addition of bromine in CCl4 is noted as a method where polyunsaturated oil becomes colorless, while petroleum oil does not exhibit a definitive color change. Hydrogenation is mentioned as a process that solidifies polyunsaturated oil but is not conclusive for petroleum oil. Saponification produces unsaturated fatty acids from vegetable oil, but petroleum oils, primarily composed of paraffinic and naphthenic hydrocarbons, do not contain triglycerides or esters, making this method ineffective. A quantitative hydrogenation approach is recommended for accurate differentiation.
  • Chemical reaction mechanisms
  • Hydrogenation techniques
  • Understanding of triglycerides and esters
  • Knowledge of hydrocarbon structures
  • Research quantitative hydrogenation methods for oil analysis
  • Study the properties of paraffinic and naphthenic hydrocarbons
  • Explore the role of carotenoids in vegetable oil coloration
  • Learn about the saponification process and its applications
Chemists, food scientists, and petroleum engineers seeking to differentiate between vegetable oils and petroleum products for applications in food technology and industrial processes.
xiaofupo
1. Which of the following chemical reaction could be used to Distinguish between polyunsaturated vegetable oil and petroleum oil containing a mixture of saturated and unsaturated hydrocarbon?
Explain your answer.
i.addition of bromine in CCl4
ii. hydrogenation
iii.saponification
iv.ozonolysis
2.The attempt at solution:
polyunsaturated oil will be becomes colourless; whereas saturated and unsaturated mixture hydrocarbon will not become colorless
ii. hydrogenation
polyunsaturated oil becomes solidified after treated with Hydrogen , whereas saturated and unsaturated mixture hydrocarbon will not become solidified
iii.saponification
polyunsaturated oil will produce 3 unsaturated fatty acid, whereas saturated and unsaturated mixture hydrocarbon form a mixture of saturated and unsaturated fatty acid
ii. hydrogenation
iii.saponification
iv.ozonolysis
No. You know nothing about the color of the petroleum oil... before or after treatment with bromine. The color of vegetable oils would come from carotenoids perhaps but you don't know if the veggie oil has been refined and is therefore initially colorless or nearly so.
ii. hydrogenation
How do you know that petroleum unsaturate won't crystallize? You are correct in that it does tend to be true that petroleum unsaturates won't solidify but it isn't a definitive test.
iii.saponification
Do petroleum oils contain triglycerides or esters?
I assume by "petroleum oil" they are referring to either a paraffinic or naphthenic mineral oil. These do not contain triglycerides or esters, they are a mixture of paraffinic and naphthenic hydrocarbons, with somewhere between 0 and 15% aromatic hydrocarbons. There may also be some very minor concentrations of polar species (nitrogen or sulphur containing molecules) but this is very minor (<0.5%).
I would suggest that some form of quantitative hydrogenation would be a good way to distinguish the two. It is possible to measure the amount of hydrogen taken up by a sample of oil using a pressure-drop method, converting back to STP. You will find that a petroleum oil takes up virtually nothing, whereas a veg oil takes up about 0.1 - 0.2 cc of hydrogen per gram of oil.
