Distinguishing classical physics vs. quantum physics
115 replies · 16K views · last reply
Zafa Pi said:
Ok, I admit you are technically correct that "QT is not weirder than any other mathematical description". But the real world = nature that it is attempting to model is weird. And that's what I think Feynman meant when he said, "Nobody understands QM". People confuse the map with the territory on a regular basis. (not to be confused with a Hilbert space basis :rolleyes:)
Physics is about the objectively observable quantitative behavior of nature and its description. The only adequate language today is that of mathematical theory. Calculus free physics is a contraditio in adjecto. Anybody who is promoting such a thing is a false prophet, and we have to fight against this tendency in modern STEM didactics as vigorously as we can, which is a pest (at least in Germany). It's a step backward into the middle ages and particularly dangerous in this era of "post-truism"!
Zafa Pi said:
I can for example distinguish Newtonian Theory from GR by saying, "A clock on a mountain top runs faster than one at sea level according to tests and GR, but NT says they run the same.".
A radioactive atom decays according to QM but not according to classical mechanics.
A suggestion from a non-professional..."In QM energy can only be delivered in discrete packets, which leads to the correct description of blackbody radiation. Classical theory fails."
But that's wrong even for black-body radiation. There are photons (in the sense of QED not to be mistaken as particles!) of any frequency, and the black-body spectrum is continuous. Correct is that electromagnetic radiation in a definite frequency mode can exchange energy with matter only in discrete portions of ##\hbar \omega##.
Zafa Pi said:
For some time I've been wondering how to eloquently distinguish classical and quantum physics. What I mean by eloquent is both simple and short. By simple I mean understandable to any college freshman, and with that caveat, as short as possible.
Zafa Pi said:
... but I'm not sure a freshman who has never taken physics would understand it.
If you really want to address someone "who has never taken physics" few of these answers will do it. If you tell them that "##qp-pq=i\hbar##" or "Alice and Bob are too far apart to communicate and neither knows what the other is doing, etc" they'll give a totally blank look - and never again ask you anything about physics!
This is alright for a layperson: "quantum has inherent randomness classical doesn't", and a couple other attempts also.
Zafa Pi said:
can I get some help from the wisemen?
If there's one word that describes, quite precisely, what almost all physicists aren't, it's "wise".
Vanadium 50 said:
Since only 37% of high school students have taken a physics class, "any college freshman" is a standard that will probably be harder to meet than you intend.
Good point. But really it's not that hard, if you happen to be a teacher.
With a person who has never had any physics, the first thing to tell them is "QM is mainly about very small things like atoms. Classical is about bigger things". Then, "QM generally gives uncertain answers, classical gives exact, certain answers". And "QM is the real truth, classical is an approximation to it".
Zafa Pi said:
I can for example distinguish Newtonian Theory from GR by saying, "A clock on a mountain top runs faster than one at sea level according to tests and GR, but NT says they run the same.". I consider this both simple and short, while also providing a concrete, simple example of different predictions. I would like something similar for CT v QT.
These two are good: "QT is consistent with the stability of the matter surrounding us (a prerequisite for our very existence!), while classical physics isn't" (@vanhees71) and "A radioactive atom decays according to QM but not according to classical mechanics" (@A. Neumaier).
I'm not saying which of these is "best", or even that they're entirely accurate. I just want to emphasize, this is how to talk to non-physicists.
Finally this would also be appropriate for a layman: "The basic ideas of QM are easier to understand than a lot of classical physics, contrary to what you may have heard."
I thought the standard answer would be that we do not know of any sharp boundary between QM and CM. However, we have some ideas about how CM arises from QM via Correspondent principle and Ehrenfest theorem. As a matter of fact I have been looking into Ehrenfest theorem of Dirac's relativistic equation for altogether a different reason but it also takes QM vs CM arguments to a different height.
http://physics.lnu.edu.ua/jps/2015/1/pdf/1003-10.pdf
In some other sense both QM and CM have action at distance and invisible fields of sorts.
There is no boundary between QM and CM. CM is an approximation to QM, referring to "macroscopic observables", i.e., coarse grained "microscopic observables". Today there are no known boundaries of validity of QT. One also shouldn't say that QT doesn't make accurate predictions about the behavior of nature since there are no known contradictions between observations and the predictions of QT, and as far as QT is tested (and it's the best tested and most challenged physical theory ever) it is astonishingly accurate (in some cases 16 or more significant digits of accuracy in the comparison between theory and experiment).
vanhees71 said:
One also shouldn't say that QT doesn't make accurate predictions about the behavior of nature since there are no known contradictions between observations and the predictions of QT...
Sure, but some of the predictions are probabilistic. "It might be spin up or spin down" is 100% verified by observation. It's always one or the other.
I've accurately predicted the results of every U.S. election since 1960! There was never a contradiction between my predictions and the actual result! - Because I always predicted that either the Democratic or the Republican candidate would win. But for some reason, no one is very impressed with my political analysis skills.
Wow! The most I had heard about till now was 10 digits. Would you mind providing links?
Well, QT tells us that that the probabilities are inherent in nature and not just our ignorance about the future. Don't be to critical against your political analysis skills. Most polls over the last elections were wrong. At least your predictions are save ;-).
Hold on a minute. Are you saying CM forbids atomic decay? Decay was certainly known before QM.
Decay was indeed known towards the end of the 19th century, before QM. (In fact the phenomenon was noticed long before that.) But CM had, and has, no way to explain it - although they tried. To say it "forbids" it wouldn't be exactly correct, CM just has no theory to deal with it. Of course once you postulate the basic fact you can analyze it statistically, for large samples, without understanding the mechanism; you might call that a "classical" analysis.
Indeed, everyone seems to think so. In post #1 I even said as much, "quantum has inherent randomness classical doesn't", but I rejected it.
It's funny, I look through various QT axiom schema and I can't find inherent anywhere. I do find axioms that say that measurements are random variables, and I am unable to find any cause for the random nature of of measurements of entangled photons, but so what. Hence it would be really nice to see a proof (that convinces one who believes in super-determinism).
At first I went along with Neumaier"s statement; "A radioactive atom decays according to QM but not according to classical mechanics.", but now I have problems.
1st off a radioactive atom is one where we notice decay, so the first half of his statement is a tautology.
2ndly CT didn't have an explanation for why masses produced gravitational forces, but there was Newton's formula and gravity was apart of CT.
3rdishly As you point out, CT had statistical laws for decay and acknowledges it does occur, but was silent for why decay occurred. Well for that matter so is QT.
What is the cause of radioactive decay?
(sorry but I don't know how to condense a link into a word)
There can never be a proof, either theoretical or experimental, that QM randomness or uncertainty is truly "inherent". As far as we know right now, it is. That's shown by the fact that representing measurements as RV's gives the right answer. But we might someday find a way to predict the RV's value. If so it would no longer be an RV - instead it would be a deterministic equation of some sort. This possibility can never be ruled out.
However it is sensible to look for a proof of this nature: given some other facts of physics (symmetry, conservation laws, etc) show that inherent randomness logically follows from them. For instance uncertainty principle is easily proved given the (current) fundamental math of QM (due to Dirac), which represents complementary observables such as position and momentum as Fourier transforms. That's a "conditional proof" that uncertainty is inherent. Bell's theorem is of this nature also, but conversely.
It's also sensible to continue to experimentally check that randomness is still inherent under new experimental conditions not previously tested. For instance, (just off the top of my head), someday check whether radium half-life is affected by strong gravity waves. No reason it should be but you don't know until you try.
In these ways we can expect to become more and more sure that the randomness is truly inherent. But obviously it can never be proven for certain. Someday we might get a surprise.
Uncertainty of the truth value of physical theories is inherent.
Here is the short version of your two sentences: "We can't prove it, but we know it's true."
vanhees71 is a little more sure about things than you, I'm still hoping for a proof.
Are you sure about that?:rolleyes:
Is it? The randomness is already an axiom of the fundamental math of QM, so it's to be expected that any conclusion based on that fundamental math is going to be consistent with that axiom and randomness. The current state of affairs is "QM is inherently random. We don't know whether QM is the last word"; to move beyond that we would need to find a theory that underlies QM so that it is no longer the last word. When and if we have that theory we can consider whether it is deterministic or random, but as long as QM is the only game in town the randomness is already an axiom.
You won't find one within the framework of QM, because it's already an axiom there.
The existence of no collapse interpretations like the MWI would seem to indicate that this can't be right. In the MWI, there is no randomness; the quantum state evolves by unitary evolution, which is perfectly reversible and deterministic. And there is no randomness in measurement results, because all measurement results happen. In fact, the challenge of the MWI is to explain how the Born rule for "probabilities" arises since there are no probabilities in the fundamental math.
As I see it, MWI just moves the randomness around. No matter which interpretation I choose the mathematical formalism will not allow me predict the outcome of my measurement even with complete knowledge of the initial conditions. Yes, with MWI I don't have the wave function collapsing to a random value with probabilities given by the Born rule, but instead I'm left wondering why I'm looking at this measurement result instead of one of the others that also happened.
You're right: probability in MWI - demonstrating Born rule - is still an unsolved challenge. But for the sake of argument let's suppose it can be solved (FWIW,IMHO it can be). Then MWI would be a complete consistent interpretation. But that still doesn't disprove inherent randomness.
MWI says that from the observer's point of view fundamental math of QM is correct. (Note the observer can be thought of as an "Information Gathering and Utilizing System", and the issue of consciousness completely ignored). IOW MWI agrees precisely with the "naïve" collapse theory.
But MWI adds an extra superstructure: many worlds in a Block Universe. That is indeed, deterministic, but not from any point of view we can have. BU depends on, or assumes, a "super-observer" (sometimes called "God's-eye view"). At the moment, as far as we know, that can't possibly be observed or detected. It's irrelevant to humans, unless there's some new breakthrough.
So what MWI actually proves is that determinism is possible - which we already knew. It doesn't prove determinism is real.
Yes, it will. The formalism tells you that all possible outcomes occur. So obviously it can't tell you "which one" will occur, since it's telling you they all occur.
There is a "you" who is looking at all of those other results, just a slightly different one--each of "you" has exactly the same history up to that point, so you're all almost identical, you just have that one last observation that differs. And each of "you" is wondering the exact same thing, because "you're" all forgetting that there isn't just one of "you".
Bear in mind, I'm not saying I agree with the MWI; I'm just saying that I don't see how it includes any randomness. It just requires a drastic rethinking of what the QM formalism is actually telling us.
No, it doesn't. It says there is one wave function and it evolves by unitary evolution. It says nothing at all about "observers" or "points of view".
No, MWI just recognizes that that structure is already there in the QM formalism. As soon as you realize that, according to the formalism, there is one wave function and it evolves by unitary evolution, the "many worlds" are there; nothing else has to be added. They're there because that one wave function can't possibly be an eigenstate of all operators, which is what would have to be the case for there to be "just one world".
When a determinist says, "The outcome of a coin flip in a wind tunnel is not inherently random, but is in principle determined by the conditions prior and during the flip."
Or when a quantumist says,
Or when a godist says, "There is a god."
It's all the same to me. I'm an apatheist .
@Zafa Pi, you remind me of ...
John Lennon said:
I don't believe in magic
I don't believe in I-ching
I don't believe in Bible
I don't believe in Tarot
I don't believe in Hitler
I don't believe in Jesus
I don't believe in Kennedy
I don't believe in Buddha
I don't believe in Mantra
I don't believe in Gita
I don't believe in Yoga
I don't believe in Kings
I don't believe in Elvis
I don't believe in Zimmerman
I don't believe in Beatles
I just believe in me, Yoko and me, and that's reality
I'm even more apatheistic than John Lennon: I don't believe in Yoko either :-)
As an apatheist, it isn't that I don't believe in, say inherent randomness or god, it's that I'm apathetic, I just don't care.
Question: When Lennon mentioned Zimmerman was he referring to Dylan?
BTW, I believe in Lennon, Ali, and Einstein.
but is cannot be modeled using classical mechanics. Spectrosdcopy was also known before QM, but classical mechanics has no explanation or even place for it.
