Divergence of magnetic flux density
The divergence of magnetic flux density, represented as \nabla \cdot \textbf{B}, is established as zero based on Gauss's law for magnetic fields, which states that the magnetic flux lines are closed and do not terminate on magnetic charges. This conclusion is derived from the divergence theorem, which equates the surface integral of \textbf{B} over a closed surface to the volume integral of its divergence. The discussion emphasizes that if the volume integral of \nabla \cdot \textbf{B} equals zero for any arbitrary volume, then \nabla \cdot \textbf{B} must be identically zero throughout that volume.
  • Understanding of Gauss's law for magnetic fields
  • Familiarity with the divergence theorem
  • Knowledge of vector calculus, specifically divergence and integrals
  • Basic principles of electromagnetism, particularly magnetic fields
  • Study the application of the divergence theorem in electromagnetism
  • Learn about Biot-Savart's Law and its implications for magnetic fields
  • Explore the mathematical proof of \nabla \cdot \textbf{B} = 0 using vector calculus
  • Investigate the implications of magnetic monopoles in theoretical physics
Students and professionals in physics, particularly those studying electromagnetism, as well as educators looking to clarify the concepts of magnetic flux density and divergence in their teaching materials.
Defennder
This is from my textbook Engineering Electromagnetics by John Buck and William Hayt 7th Edn, pg 238 in the chapter titled "The Steady Magnetic Field":
The magnetic flux lines are closed and do not terminate on a "magnetic charge". For this reason Gauss's law for the magnetic field is \oint_S \textbf{B} \cdot d \textbf{S} = 0 and application of the divergence theorem shows us that \nabla \cdot \textbf{B} = 0.
Divergence theorem:
\oint_S \textbf{B} \cdot d\textbf{S} = \int_{\mbox{vol}} \nabla \cdot \textbf{B} dv.
How does \nabla \cdot \textbf{B} = 0 follow from the application of the divergence theorem in this case? It is only required that the volume integral of \nabla \cdot \textbf{B} = 0 , but not \nabla \cdot \textbf{B}, right?
Think of it this way:
\oint \vec{B}\cdot d\vec{s}=\int_V\vec{\nabla}\cdot\vec{B}dV
and also remember that we can say:
\int_V0dV=0So, can you prove the statement using these two statements?
It appears that your second statement is sufficient for \int_{\mbox{vol}} \nabla \cdot \textbf{B} \ dv = 0 but is it also necessary that \nabla \cdot \textbf{B} = 0?
Sorry, I wasn't clear above, I guess.
So, we agree that:
<br /> \int_V\vec{\nabla}\cdot\vec{B}dV=0<br />
Now we also agree that:
0=\int_V0dV
correct?
If so, you should be able to use the following hints to solve the problem:
1) Properties of equality- i.e. if A=B and B=C then A=C
2) You should end up with one integral equal to another. Both integrals have the same bounds, so what can you say about the integrands?
Is this any clearer?
Well GO1, I may be misinterpreting what you wrote, so please correct me if I am, but what you wrote seems to not be accurate. If I understand correctly, you say
<br /> \int_R{fd\xi} = \int_R{gd\xi} \rightarrow f = g
However, an obvious counterexample would be that
<br /> \int_{0}^{2\pi}\sin xdx = \int_{0}^{2\pi}\cos xdx
while the integrands are clearly not the same function.
With regards to the OP's post, the usual argument I have heard is that since S is any surface, V is any volume, and the only way that the integral can be 0 for any volume is if the integrand is identically 0.
Yes, you are correct nick. Sorry for any confusion. I could not remember the exact argument from when I took E&M. I was trying to piece it back together under time constraint and that was the only argument I could think of. If I wasn't at work, I would hopefully have caught that obvious inconsistency. Thanks for the help.
But how do we show that that is the only way it is possible? I was thinking there might be some electromagnetic theory I haven't learned yet which might show that the volume integral of div B is always zero for all closed surfaces even though div B is non-zero.
Start by taking div(B) to be continuous. Can the integral of div(B) over ANY volume be zero without div(B) being zero?
I actually have no idea how to prove this, I suspect one might need a bit of analysis that I don't have. It might be easier to prove it in one dimension first For a continuous function f
(\forall a \forall b\int_a^b{f(x)dx}=0)\rightarrow f = 0
But I'm not even entirely sure how to prove this.
(The continuity condition is important, as then an obvious counter example would be f(x) = {1 is x is rational, 0 if x is irrational}).
Is this part of a rigorous approach or an intuitive one? nicksauce's post suggests you might be hinting at something rigorous but which I have no idea how to prove it rigorously so I'll just interpret it intuitively.
By continuous you mean to say the value of div B is changes gradually over a vanishing distance dr right? So assuming that means to say if the value of div(B) is non-zero at some point, say, (a,b,c), then the following must be nonzero in the neighbourhood of (a,b,c):
\begin{array}{cc}\mbox{lim}\\ \scriptsize{\triangle v \rightarrow 0} \end{array} \nabla \cdot \textbf{B} \ dv
but if that is so then the flux of B through the closed surface encompassing the differential volume at (a,b,c) must be non-zero, by the divergence theorem which contradicts Gauss law for magnetic flux density. Is this right?
(How do you make the latex font smaller for the lim subscript?)
EDIT: I think there's another way it can be proved. The same textbook on pg 68 defined div F as \nabla \cdot \textbf{F} = \begin{array}{cc}\mbox{lim}\\ \scriptsize{\triangle v \rightarrow 0} \end{array} \frac{\oint_S \textbf{F} \cdot d\textbf{S}}{\triangle v} and it is evident that if the numerator is always zero then the div F is always zero as well.
EDIT 2: It looks like both approaches are the same.
That's it. If div(B) is continuous and positive at x, then it's positive in a small region around x. Implying the integral is nonzero. Ditto for negative. Even if you allow discontinuous function like nicksauce's example, the technical answer is that it's still equal to zero 'almost everywhere'. But I wouldn't worry about that.
One last question, is it possible from an EM theory viewpoint as opposed to a mere mathematical viewpoint that div(B) may be discontinuous? Assume steady state magnetic fields at the moment, but I'm willing to consider time-varying fields as well.
There are reasons to consider discontinuous function for div(E). Things like point charges and surface charges. There's no call for anything like that with div(B), there aren't any magnetic sources.
Ah ok thanks!
To prove that the divergence of B is zero, just take the divergence of Biot-Savart's Law. It's got some nasty math steps, and you have to employ the divergence of a cross-product, but I have the work in front of me. If I knew LaTex better, I'd post it but as it goes, I have no scanner either.
2 year old topic. I don't think it's relevant anymore.
E&M is always relevant.
  • · Replies 17 ·
9K
