Do charges always lie on the inner surface of capacitors?
The discussion revolves around the behavior of electric charges on the surfaces of capacitors, particularly in the context of parallel plate capacitors and their arrangement. Participants explore concepts related to electrostatics, charge distribution, and electric fields within conductors, raising questions about the conditions under which charges reside on inner versus outer surfaces.
  • One participant posits that all +1C charge must lie on the inner surface of plate A, questioning why some charge cannot reside on the outer surface.
  • Another participant emphasizes that in electrostatics, charges arrange themselves to ensure there is no electric field within the conductor.
  • A participant challenges the assertion that charges can lie on both surfaces of plate A while maintaining a zero electric field, suggesting that charges on other plates must be considered.
  • Some participants discuss the interactions between charges, noting that positive charges attract negative charges on opposing plates, which minimizes potential energy.
  • There is a suggestion to analyze the electric field of a homogeneously charged plane and apply Gauss's Law to understand the charge distribution better.
  • One participant raises the question of whether the arguments regarding charge distribution apply to configurations with multiple plates, seeking clarity on the implications for charge placement.
  • Another participant mentions that if a third plate is introduced, it could lead to a redistribution of charges on the other plates, prompting further inquiry into the energetic favorability of such configurations.
  • Symmetry arguments are proposed as a means to understand the electric field behavior in large plates, with references to Gauss's Law and the condition of zero electric field inside conductors.
  • There is a discussion about the relationship between Gauss's Law and the conditions within conductors, with emphasis on the role of Ohm's law in determining electric field behavior.
Participants express differing views on the distribution of charges on capacitor plates, particularly regarding whether charges can reside on both inner and outer surfaces. The discussion remains unresolved, with multiple competing perspectives on the implications of charge interactions and electrostatic principles.
Participants reference various principles such as Gauss's Law and energy minimization, but the discussion includes assumptions and conditions that are not fully resolved, particularly concerning charge redistribution and the implications of introducing additional plates.
phantomvommand
Parallel plates A, B are 5mm apart, with charges +1C and -1C respectively. Parallel plates C, D are 2mm apart, with charges +1C and -1C respectively. Capacitor CD is slid between capacitor AB. Find the potential difference between AB.
The key idea to solving this problem is to suppose that +1C lies on the inner surface of A, thus, -1C is induced on the outer surface of C. Since C has charge +1C, its inner surface charge is +2C. Following this logic, D has inner surface charge of -2C, outer surface charge of +1C, B has inner surface charge of -1C.
My question is: Why must all the +1C charge lie on the inner surface of A? Why can't some of it lie on the outer surface of plate A?
After sliding the second capacitor in and waiting a short time you have an electrostatic situation. The key thing to remember is that in electrostatics the charges arrange themselves so that there is no E field in the conductor.
Thanks for the reply. Could you please elaborate on this further? If I have charges that lie on both the outer and inner surface of plate A, there is still 0 electric field in plate A. Why must all the charges lie only one 1 surface then?
This is not correct. Don’t forget the charges on the other plates.
If I have the following charges on the outer and inner surfaces of each plate (A, C, D, B):
2 - Q
Q - 1
1-Q
Q
-Q
Q-1
1-Q
Q-2
Are you saying that the 1-Q charge (and other charges outside) creates some electric field in plate A? How does that reconcile with Gauss's Law, which suggests that because there are no charges inside plate A, the electric field is 0?
You can also think about it in terms of the interactions between the charges: The positive charges on one plate attract the negative charges at the other. Thus the charges tend to get as close to each other as they can, which also minimizes the potential energy as it must be in the static situation.
This was how I resolved it intuitively. However, I have yet to grasp Dale's idea that there is E-field in the conductors. Do you mind explaining why there would be an E-field in the conductor if the charges lie on both exterior surfaces, instead of just 1 surface?
Just start by thinking about the electrostatic field of a homogeneously charged plane (i.e., a plane carrying constant surface charge). I don't know at which level you are, but one simple way is to think about the symmetry of this configuration and make an ansatz for the electrostatic field due to this symmetry and then use Gauss's Law to get the numbers out.
Then just put another infinitely large plate parallel to the first with the opposite surface-charge density and write down its field and then add it to the field of the first plate.
If you have some more vector calculus at your disposal you can also look at the problem by solving Poisson's equation for the electrostatic potential using the appropriate boundary conditions at the plates.
I am just studying undergraduate level physics (eg University Physics level). It seems to me that you are discussing the 2 plate situation, which I see why charges would all lie on 1 side of the plate. Does your argument extend to the case of multiple plates, in which the topmost and bottom most plate must all have their charges lying on 1 surface of the plate?
Did you miss the word "no" in what Dale said?
Well, if you have a third plate somewhere between the two plates, at this plate there must be surface charges on both surfaces.
Sorry, I meant why there would be E-field if the charges are not fully on 1 side.
Why is it not possible that the third plate causes a redistribution of the charge in the 2 other plates, such that there would now be charges on both surfaces of those 2 plates?
I think the energy argument is most straightforward. This is (intuitively) not favourable energetically. Is there another way to see this?
As I said, you can argue with symmetry arguments how the electric field should look like (for very large plates such that you can neglect edge effects) and then use Gauss's Law together with the contraint that there must be no electric field inside of conductors.
yes, I did not realize the symmetry idea. Thank you!
Be careful here. It is not Gauss' law that tells us the electric field inside the plates are 0. We know that the field is 0 inside the plates due to Ohm's law, ##\vec J = \sigma \vec E## and the electrostatic condition, ##\vec J = 0##.
Once we have that information that inside the conductor the field is zero then we can use that together with Gauss' law to calculate the field between the plates. Usually we use a simplifying assumption about the symmetry, namely that the plates are infinitely large. This allows us to know by symmetry that the E-field is purely normal to the plates. We can then draw cylindrical Gaussian surfaces with the ends parallel to the plates and the sides along the normal direction. Then we know that there is no flux through the sides and all of the flux is at the ends.
Putting one end inside conductor A and moving the other end inside conductor C we can determine that the charge on the right side of A is equal and opposite the charge on the left side of C. Similarly for C and D and then for D and B. That gives us three equations.
We get four equations from the conservation of charge on each plate. So we have 7 equations in 8 unknowns. We need one more equation. That is energy minimization. The energy density is proportional to the square of the E-field. So the energy is equal to the energy density times the volume. The volume outside the outer plates is infinitely larger than the volume between the inner plates, so it is the only one that matters. So the final equation is obtained by minimizing the field outside the outer plates. This is proportional to the square of the charge on the left side of A plus the square of the charge on the right side of B. In this case that is 0.
Thank you so much for explaining this is such great detail :)
Or:
1. Assign unknown charge density ##\sigma_i## , i=1 to 8, to the 8 sides.
2. ##\sigma## on sides of facing surfaces must have equal and opposite value (why?). This reduces the number of equations (in ##\sigma##) from 8 to 5.
2. For each plate the sum of ##\sigma## on both faces (times plate area) must equal the total charge on each plate. That gives you 4 equations in 5 unknowns.
3. The fifth equation is most easily found by mentally placing a small test charge in one of the plates and vectorially adding the contributions of all 8 sides to the test charge so as to make it see zero force (zero E field).
There is one and only one configuration for any combinatiuon of charge that will satisfy these equations.
Knowing the ##\sigma##s you know D eveywhere, thus E, then integrate from A to B for your potential.
rude man said:
Or:
Thanks for this, I suppose the only configuration is the one where the charges all lie on the inner surface of the topmost and bottommost plate? This is a general result, right?
No. Remember what I said about any inside face pairs?
In general there will be charges on all sides.
In your case (assuming unit area),
Q1 = ##\sigma1+\sigma2##
Q2 = ##-\sigma2+\sigma3## (remember about inside faces)
Q3 = ##-\sigma3+\sigma4##
Q4= ##-\sigma4+\sigma5##
For the last equation (putting the test source inside plate 1),
##\sigma1-\sigma5 = 0## (the inside charges always cancel).
From this,
##\sigma1 = \sigma5 (outside faces) = 1/2 (Q1+Q2+Q3+Q4) ##
which of course can be non-zero.
Etc.
To get the E fields, ##\sigma = D = \epsilon E ##
Then integrate to get ##V_1-V_2##.
From this,
Etc.
thanks for this!
BTW one more thing - if you think about it you will realize that the charge on the outer two surfaces will always be the same - in magnitude and polarity. So actually that reduces the number of equations to 4.
  • · Replies 18 ·
11K
