What is the scientific definition of time?
In summary, Dick's talking about how we don't really know what's slowing down time, but we think it's gravity. He's suggesting that we create a system where everyone has their own "internal time scale" so we don't get confused and messed up with all the leap seconds. He also says that until we figure out what's causing gravity to slow time down, we're just going to keep doing what we're doing.
Doctordick
634
A direct quote from "Science News", April 22, 2006! :wink:
"If I were a communications company and wanted to make sure I never got bothered [with a leap second], I'd create my own sort of internal time scale." McCarthy says. "Then there's a concern that if everybody started doing this there'd be a [complete] lack of standardization.
Banks, armies, or any group of institutions depending on close coordination could start acting "like a dysfunctional family," says Allen.
In the meantime, a new problem looms. The inextricable link between gravity and time becomes increasingly apparent as atomic clocks become more and more precise. Every decade since the mid-1950s, the accuracy of atomic clocks has improved tenfold, notes Kleppner. The clocks are approaching an accuracy of 1 part in 10^16, and newer systems, based on the vibrations of laser-cooled atoms and ions, are expected to eventually attain 1 part in 10^18.
Einstein's general theory of relativity predicts, and atomic clocks have confirmed, that clocks at higher elevations run slightly faster than do those closer to the ground. Given the current accuracy of clocks, this gravitational effect requires that researchers know the altitude of timekeeping laboratories to within a few meters. Ultimately, altitudes would have to be measured to within a centimeter.
That becomes tricky because gravitational theory dictates that the altitude isn't measured relative to average sea level, but to the geoid, a hypothetical surface that approximates the shape and size of the earth. The geoid's size fluctuates in response to, for example, ocean tides and the redistribution of water due to climate changes.
These "shakes and shimmies" would make comparisons of future ultraprecise atomic clocks kept at different locations "no more meaningful than comparing the rates of pendulum clocks on small ships scattered in the oceans, each bobbing in its own way and keeping its own time," says Kleppner.
:rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Doctordick said:
http://home.jam.rr.com/dicksfiles/flaw/Fatalfla.htm
As I first said, some forty years ago, "someday clocks will be so accurate that the academic community will recognize the fact that they are confusing two very different concepts of time: the readings on a clock and the fact that two things at the same place and time can interact". :biggrin:
Anyone interested in discussing the "philosophical" issues here? I know the academy has no real interest in the issue. :rofl: :rofl: :rofl: :rofl:
Have fun -- Dick
"The simplest and most necessary truths are the very last to be believed."
by Anonymous
Have fun -- Dick
by Anonymous
The doc is in!
My definition of time is that it is a measurment system that measures change.
That's how an "hour glass" works. It is the measuring of one series of changes against another. It can be very complicated because you have the shadow of a sun dial measuring the position of the sun with regard to increments on a dial. You have sand transfering from the top of an hour glass to the bottom as compared to the position of the sun (actually the position of the earth). You also have the rate of decay of C14 or whatever and how it relates to the position of the rotation of the Earth in relation to the sun.
Then there are the changes that take place outside of the system described above and those would be the position of the solar system in relation to the spin of the galaxy and its centre. ETC...
So, what is really slowing down as you get closer to the geoid and a heavier gravitational effect?
I would suggest that change itself slows down in the nearer degrees of proximity to a gravitational source. Whether this tells us that gravity inhibits rate of change or that it stablizes it or what... is hard to say.
In fact, until the true nature, cause and reasoning behind the presence of gravity are discovered, we will not know why change slows down in its presence.
What I would suggest to ease the variance in "time keeping" between atomic clocks etc.. is that a gyroscopic chamber be devised to hold it that remains constant in relation to the continuous changes in tide, atmospheric pressure and geological changes. It would have to tap into a 24/7 feed of oceanic/meterologic/geologic data and resulting predictions to maintain a constant position with regard to the geoid and the Earth's core centre. This would also involve a feed from and advanced GPS system.
"Do Clocks Measure Time?"
No. Clocks measure the Rate of Change, usually using the sun as a reference.
:bugeye:
How about the notion that TIME is a construct of the human mind to helps people cope with the problem of MOTION. Duration of existence and TIME are not the same thing, but TIME can be used to understand the concept of 'duration of existence.' You probably do not agree with any of the above but it is my 'philosophical' view of time.
You misunderstood both of the portions you highlighted in the article. Ironic, since you were right about them being the most important parts of it. Your blind adherence to your own point of view is preventing you from even seeing and understanding the other point of view - much less making a reasoned conclusion about which one is better.
The scientific community has no interest in discussing philosophical issues here because there are none. Words have precise definitions in science. (and quantumcarl - your definition of "time" is not the same as the scientific community's definition either.)
Gee Russ, explain to me where I misunderstood. :rofl: :rofl: :rofl:
After years and years of interacting with "academic experts" I have become convinced: I am discussing philosophy and not science. That would be in the same sense that Galileo was not discussing the issues of interest to the religion of his day. I guess you would say that a compulsion to stick with a clearly failing perspective is neither a scientific nor a "philosophical" issue. :yuck:
Yes, and I have been told many times that "time" is defined as "what clocks measure". McCarthy and Kleppner seem convinced that time is at least related to "the fact that two things at the same place and time can interact". On the other hand, anyone familiar with relativity clearly comprehends that the reading on a clock has almost nothing to do with the "the fact that two things at the same place and time can interact". Who is confused here. :rofl: :rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
Now here I agree with you. Quantumcarl's definition of time is very close to mine and it is far superior to the scientific community's definition. And, when you get down to facts, it can be seen as quite precise also; see my presentation http://home.jam.rr.com/dicksfiles/Explain/Explain.htm . o:)
Considerably more precise than "no more meaningful than comparing the rates of pendulum clocks on small ships scattered in the oceans, each bobbing in its own way and keeping its own time". We are talking about the "definition" of time here and you need to keep that in mind "(as even today it blocks the view of the whole scientific community)". :wink:
The difficulty here is exactly the fact that the central purpose of time is to define when two things can interact; this is the central concern of McCarthy and Kleppner and is central to any valid description of our world. Einstein's position (that time is a coordinate of representation) completely avoids this very issue. There is nothing in Einstein's space-time trajectories which embody a differentiation between past and future. Einstein's approach only works when what has happened is entirely known and all significant interaction is a fact, having nothing to do with the readings on any clocks (the differentiation between past and future is immaterial to the problem). That perspective has already thrown out the idea that there are other possibilities (other than what has happened) before any analysis of what has happened even begins. Thus it is that his perspective will never be consistent with quantum mechanics. It is a fundamentally wrong perspective. As wrong as was was the theory of phlogiston as an explanation of heat. The scientific community is still totally hung up on interaction concepts which were introduced when pendulum clocks were the most accurate instruments in existence. :biggrin:
Have fun -- Dick
I disagree that this has no real interest for academia! Actually, as far as I understand it, this is becoming a central issue in loop quantum gravity. Some are seriously taking the approach that the usual concept of time (whether it is in Newtonian physics or in relativity) is inadequate and downright superfluous. Time is something that must actually be removed completely from the theory! The only thing left are events and the *relations* between events.
I don't know much about the details, but the folks on the Beyond the Standard Model board could say more. My main point is that this is actually a hot topic of cutting edge research. And a very very interesting topic.
Well, that is nice! However, I am persona non grata with the scientific community, and have been for many many years. No professional would condescend to even give me the time of day much less consider what I have discovered. :rofl: :rofl:
Again, that's nice. Where do they say these things? :biggrin:
Have fun -- Dick
It would seem you already know what you misunderstand. You know you are discussing philosophy and not science, but you are unable to differentiate between the two.
Your ideas are philosophical. The article is scientific. Your ideas are irrelevant to the article.
The "scientific" article has a typo:
http://www.sciencenews.org/articles/20060422/bob8.asp
Sluggish Earth
A variety of competing effects, including the moon's tug on the oceans and the melting of glaciers, combines to slow Earth's spin. A day now is about 0.002 second shorter than it was a century ago. Some 150 million years ago, dinosaurs had to jam a full day of foraging and killing into what is now only 22 hours.
A tally for ScienceNews bloopers.
Hi russ,
I certainly respect the differences in the definitions of words where scientific and common usages are concerned.
I am not aware of the scientific definition of time. Is there a formula? How much more complicated can it get than what I've already come up with on my own??
Please post the super scienterrific definition of time. In point form and with diagrams if possible. Besides, this is a physics forum... right!:wink: :wink: nudge nudge
Thank you
1.
How do clocks measure time?
Clocks measure time by using a mechanism, such as gears or electronic components, to track the passing of seconds, minutes, and hours. This mechanism is typically powered by a source of energy, such as a battery or a wound spring, which causes it to move at a constant rate and keep track of the passing of time.
2.
What is the accuracy of clocks in measuring time?
The accuracy of clocks in measuring time depends on the type of clock and its mechanism. Modern digital clocks can be incredibly accurate, with some models having an accuracy of up to one millionth of a second. However, some analog clocks may lose or gain a few seconds over the course of a day. Overall, most clocks have a high level of accuracy and are suitable for everyday use.
3.
Can clocks measure time accurately in different environments?
Yes, clocks can measure time accurately in different environments as long as they are not exposed to extreme conditions. For example, clocks may be affected by changes in temperature, humidity, or altitude, but these effects are usually minimal and do not significantly impact their accuracy. However, clocks may require adjustments or recalibration in certain situations, such as when travelling between time zones.
4.
Do all clocks measure time in the same way?
No, there are different types of clocks that use different mechanisms to measure time. For example, analog clocks use a system of gears and hands to display the time, while digital clocks use electronic components and a digital display. There are also alternative methods of measuring time, such as using water or sand, but these are not as commonly used in modern clocks.
5.
Can clocks measure time accurately over long periods?
Generally, clocks are designed to measure time accurately over short to medium periods, such as a day or a week. However, some clocks, such as atomic clocks, are designed to maintain their accuracy over much longer periods, often for millions of years. These highly precise clocks are used for scientific and technical purposes, such as in satellite navigation systems, where accuracy is crucial.
  • Other Physics Topics
  • General Discussion
  • Beyond the Standard Models
  • Quantum Physics
