Do Computer Icons Follow Classical or Quantum Physics?
  • Level: Undergrad
  • Thread starter Thread starter Rade
    Computer Physics
33 replies · 12K views · last reply
The book has physical properties that can be measured regardless of whether or not you are bouncing photons off of it. The spot on the wall does not. A simple question can demonstrate how simply wrong you are: Where is the spot? With your definition (a set of photons), the spot is a constantly flowing set of photons... but it isn't the spot on the wall.
Again, the photons are physical objects, the spot is not. Grouping the photons together does not change that. And no one mentioned it, but what you said about gravity affecting the spot is wrong too. Gravity affects the photons, but it does not affect the spot like it does a physical object.
Thanks for that, Russ. For some reason, I froze up trying to point that out. :redface:
chroot said:
There is no "exact" boundary. Quantum mechanics becomes indistinguishable from classical mechanics in the limit of a large ensemble. The larger your ensemble is, the more accurate the agreement between the two theories.
Thank you. But, as in the concept of the "limit" of the calculus, which can be viewed as a boundary never to be reached, would not the "limit of a large ensemble" then correspond to the "exact boundary" condition between classical and QM ?
Forgive me if I keep asking about this subject. Actually I have never seriously thought that a spot is a real object, but I found it interesting to talk about it.
About where is the spot, I could ask the same about a photon. Where is a photon?
