Do diodes need to be put in, in a certain direction?
  • Thread starter Thread starter tommy-gunn
    Diodes Direction
11 replies · 23K views · last reply
tommy-gunn
I was given a christmas present and i have now begun making it and I've run into a problem,:confused: does the colour code on diodes relate to where and what direction that they need to be soldered into? please respond
Diodes are polarity sensitive devices. So the direction they are soldered matters. Usually a color band, dot, or color code bands identifies the cathode (negative). When you solder your diode make sure that you have the cathode pointing to the (more) negative terminal of your power source.
The color bands mean the diode type: example 139 semiconductor diode.
for zener diodes it can conduct both ways, sometimes people put zener with the cathode to +voltage and anode to gnd to clamp the voltage (maintain it) or act as a voltage regulator.
best to look at the manufacturer part and refer to datasheet
i think one wire is longer than the other, that's how u can tell, but i forget which one is which
When we have this, such as the case with LEDs; shorter means cathode.
oh, woops, i thpought he was only talking about LED's
from The symbol of diode ;
and you should put the positive voltage at the base of the square and the -ve at the other side
on the dide you will see a wide black band this represent the st.line close to the top of triangle
Also you shoud put a resistance in series with the diode
Hello,
there is always a silver ring on each pn junction diode on one side,
the side having the silver ring is always negative or you can say that this is N-side
and the other side is P-side.
This explanation is only for normal pn junction diodes. There are many more kind of diodes
having different indications for p and n type.
diode is always connected in forward bias, in reverse bias diode act as an open switch.
I hope you are satisfied with my answer.
Best Regards!
Using a portable DMM (ohmmeter) you could test which side is your cathode versus anode. This would be useful if the markings on the diode are ambiguous or you want to double check yourself. Here is a http://www.allaboutcircuits.com/vol_3/chpt_3/2.html, showing how to do this.
there is such a concept as diode biasing. forward bias means the positive end of the diode is connected to the positive end of the voltage/current source. in forward bias, current flows. while the reverse bias is the opposite. placing them depending on what bias you need is important.
Yes,the direction should be such that n to p points in the direction of flow of current.
