Do inertial forces on a vibrating bar change in weightless conditions?
80 replies · 14K views
Good afternoon, Ken.
First I agree with all you say, up to the quote below.
What are the forces on the spring the instant after the rocket engine is shut off, and in particular, do any of their strengths, sources, or nature, change in the slightest way?
Now you have actually described the forces the instant the engine cuts using D'Alembert's Principle, which also appears in the second extract of my previous post.
I don't quite understand what you mean by the question however.
Change?
Change from what? Before and after the cut?,
You have already stated there was no inertial force before the cut, but there is after so there is a change there.
Clearly the effort from the rocket motor changes.
Or do you mean subsequent to the cut?
Studiot said:
The first is the original inspiration from Professor Den Hartog. I have ringed the paragraph where he clearly and explicitly states that the third law reaction is a result of inertia. However he does not elaborate as to how this might arise as he has other fish to fry.
I'd say that despite the non-standard terminology, that first extract is clearly talking about 'reaction' forces. These are 'real' forces due to the interaction of two different bodies.
To see how this might arise the second extract is from Walker.
This makes the statement Doc Al thinks is in conflict with Den Hartog but to see that it is not, look at the diagram first.
That second extract, despite its failure to make explicit the fact that it is using a non-inertial frame of reference, seems clearly to be talking about inertial forces. Note that the applied force and the inertial force both act on the mass in question. (Not so in the first extract.)
Apples and oranges, I'm afraid.
Respectfully you are again making my point for me.
Do you agree that a reactive force is applied to whatever pushes the block rightwards?
And what point might that be?
Of course. But that force is not an inertial force, at least as the term is used in standard physics.
Just as the internal elastic forces in the bar generate the external action on the mass so the internal 'inertial force' generates the reaction of the block on the push rod.
So where did it come from? and What do you call it?
Prof DH explicitly called it the "inertia reaction"
I was trying to show how this might arise and I think he is correct although I also think he left out a step or two.
I would be really helpful if folks would stop trying to 'prove me wrong' and just work through the logic with me - I am perfectly happy to say you are correct if it turns out that way, but so far it has not.
DaleSpam said:
Hi Studiot, my understanding agrees with Doc Al, A.T., and Ken G's understanding. Inertial forces are also known as fictitious forces. They are frame-variant and only arise in non-inertial reference frames, they are not part of any 3rd law interaction, and they are always proportional to the mass.
Add me to that list. What you are calling an "inertial force" in this thread is not what almost everyone else means by the term "inertial force".
There is a very good reason to use consistent terminology, Studiot. Inconsistent terminology leads to unnecessary arguments that hopefully terminate with an Emily Litella "Oh, that's very different ... never mind" moment. Consistent terminology avoids all that.
Why give it a name? A pushes on B, thus B pushes back on A. Newton's 3rd law.
This is not a question of 'logic', but of using the standard meaning of terms. Prof DH wants to use his own personal terminology to refer to the reaction force as an 'inertial force', because it's 'due to inertia'. Fine. But that's not standard usage. (At least not in any standard classical mechanics book that I own.)
For the standard meaning of 'inertial force', read the first couple of paragraphs here (even Wiki gets it right): http://en.wikipedia.org/wiki/Fictitious_force"
And do you agree that the two extracts you quoted were speaking of entirely different things? Yes or no?
Doc Al
Was that a response to my question
Where did it come from?
If so does that mean you agree it (ultimately) comes from the inertia of the the reacting object in the cases shown.
Obviously if the reacting object was restrained then there would still be a third law reaction, but its ultimate source would be different (non inertial).
Do you not think this to be significant?
I have already said that.
What is the point of identical examples?
They are of course different in the fact that in one case we are considering the effect on object A and in the other case the effect on object B.
That does not mean that we cannot bring them to a common comparison by considering the effect on object A in both cases.
Just to clarify, that "Prof DH" is not me. Studiot is talking about Jacob Pieter Den Hartog, a professor of mechanical engineering. The book Studiot is referencing is "Mechanical Vibrations", copyright 1934, 1940, 1947, 1956, 1985. The 1985 edition is a Dover Books republication of the 1956 edition. So old, outdated terminology is most certainly a possibility here, as is a discrepancy between the terminology used in mechanical engineering versus that used in physics.
Studiot, the multiple pages of argument that comprise the bulk of this thread result from very contradictory meanings of the term "inertial force" as used in that book and the term "inertial force" as used in physics. Since the name of this site is www.physicsforums.com[/url] rather than [PLAIN]www.outdatedconceptsinmechanicalengineering.com , I would venture that the physics definition wins. At least at this site.
Studiot, I do not agree that 3rd law pairs come from inertia. Third law pairs exist even in static situations where there is no acceleration or between idealized massless objects. In either case it is hard to see the relevance of inertia. I have a hard time justifying calling a 3rd law pair an inertial force on that grounds.
I would stick with the standard usage of the term "inertial forces". It avoids confusion, and there doesn't seem to be a good reason to go to the non-standard usage.
Good evening Dale,
I think underlying this whole discussion and also the difficulty many students struggle with is the question of how can an object apply a force at all?
The whole point of matter possessing properties is for those properties to be deployed when suitable conditions prevail.
Remember that this is the classical physics thread so I do not expect to discuss exchange particles or spacetime curvature here.
Consider the block in my example 2.
It suffers a rightward force from a push rod.
Situation 1)
The block is restrained against a rigid foundation to its right so does not move.
I can measure the reaction force on the push rod by means of a spring scale. I can see why the block can do this - the other side of the block is pushing against the foundation.
Situation 2)
The block is restrained against a spring foundation to its right so does move.
However the force measured on the spring scale to right (the spring foundation) is not the same as the force impressed by the push rod.
Situation 3)
The block has no restraint to its right so does move (accelerate) indefinitely so long as the rod remains in contact.
In all three situations the reaction force measured by my spring scale is the same, yet the source of this reaction force is clearly different.
The source of the reaction force is clearly the same in all three scenarios. It is the normal force exerted by the block at the point where your push rod touches the block.
I don't really know what it means for something to be a force's source. I know what it means for a force to be a certain kind, like gravitational, or frictional, or mechanical, is that what you mean by source? In that case, the source is the same in all three situations, the mechanical compression of the structures.
Change?
Yes exactly, change before and after the engine is cut off.
I asked for any changes in forces on the spring, we agree there are changes in the forces on the rocket. This is a good device for understanding the forces on the spring both before and after the cut, to look and see if there are any changes.
Here is a new example for you experts to chew over.
A (point) mass m is attached to a smooth cone of 60 angle. The cone rotates at an angular velocity of 3.374 rads/sec.
What are the forces (real and inertial) acting on the mass?
The real forces are tension, normal force and gravity. They sum (vectorially) to the mass x acceleration of the object (ie. the centripetal force that keeps the object moving in a circle).
There is no inertial "force". The inertial "force" only appears if you analyze it in the frame of reference of the body, which is a non-inertial reference frame.
AM
The issue hardly requires "chewing", it is a simple "free body diagram" from first-year physics. It appears from your diagram that the mass is suspended from a string, and lies against the cone. If so, there are three real forces on the mass-- the tension from the string (which points along the string), gravity (which is downward), and the normal force from the cone (which is perpendicular to the cone surface). Both the string tension and the normal force are set entirely by the requirement for these three forces to add up to give to a net force, called the centripetal force, whose magnitude must be w2r, where w is the angular velocity and r is the distance from the central axis of the cone. The direction of this net centripetal force is toward the axis. In a rarely used language where the centrifugal force is regarded as an "inertial force", it will have the same magnitude but opposite direction as the net centripetal force, because in this use of the term inertial force (being applied in the inertial frame of the observer here), it is envisaged as a balancing force that must make all the forces on the mass add to zero (that's how d'Alembert used the concept, it is still seen today as a useful way to talk about the -ma term in F-ma=0). Please note the key point however: being -ma, the "inertial force" is always zero on all massless objects, like the band in your original problem.
Well this is the danger of being entirely theoretical.
If anyone did a calculation they would find that there is no normal force.
I guessed so, because such a very specific value for omega was given. But was too lazy to check.
First, that is not true in general and would depend on the radius, which was not given. Second, since you didn't give the radius a calculation was not possible.
Apologies, the string is 2m long and the mass is 2kg.
Actually, there is no possible way to set up that experiment where the normal force will be precisely zero (even if all the necessary information is included), because of one more force on the mass-- air resistance. That will require a small normal force to allow for the balance between air resistance and static friction. All this means is, if you try to spin the cone too fast, no steady-state solution will be possible, so any steady state requires a nonzero normal force. The "zero normal force steady-state solution" is an idealized situation that is impossible to achieve in practice if the motion of the mass will be due to the spinning cone.
But even that doesn't matter-- the prescription for calculating constraint forces allows them to be zero, it is not any kind of bother when they come out that way in idealized problems that do contain all the required information.
The real question is: what does this have to do with erroneous statements about what inertial forces are?
With those values the normal force is actually negative 9.9 N. I.e. 9.9 N inwards. I assume this is unintended.
Yes, I get that omega^2 * L can never exceed g / cos(theta) with that kind of setup, where L is the length of the string. Here 1/cos(theta) = 2, so omega^2 * L must not exceed 19.6 m/s2. Here it is 22.8 m/s2.
Mentor note:
This post, and several that follow, were made in another thread. There were moved to this thread because this thread is where discussions of this problem belong.[/color]
Why don't you write again the complete question in one post, give us your two solutions (inertial frame, co-rotating frame with fictious forces) and show us how the later "will definitely get you the wrong answer"?
Why?
Well first point is that both D'Alembert's and Newton's methods will lead to an invalid conclusion if inappropriately applied.
The question was specifically constructed (not by me) to demonstrate the particular point that it is posible to step outside the obvious assumptions and thereby obtain the 'wrong' answer.
Unfortunately instead of having an adult discussion about Physics I felt I was being personally attacked in the other thread.
The relevant equation, by either method, is
[tex]R = 4.93 - \frac{{\sqrt 3 }}{4}{\omega ^2}[/tex]
I make the ω at which R becomes zero the 3.374 I posted.
Various values for R, including negative ones were offered, but none if I recall correctly equal to zero.
Whirling beyond this speed simply causes enough tension in the string to lift the mass of the cone.
Of course R remains zero or is non existant. It surely is never negative.
The problem stated that the mass was attached to the cone. Therefore the mass could not lift off of the cone and the normal force could become negative. Of course, the problem did not specify the method of attachment so in all likelyhood the problem was either inconsistent or overdetermined.
Zero was not correct.
Studiot said:
In this recent thread I offered a problem (posts 53 and 54) where D'Alembert's method (fictious forces) will definitely get you the wrong answer.
https://www.physicsforums.com/showthread.php?t=531470
This triviality is quite a backpedaling compared to "D'Alembert's method will definitely get you the wrong answer". How is that problem relevant to this thread, which about comparing the two approaches?
A negative numerical result for a contact force which is defined as compressive is perfectly valid, if interpreted correctly. It means that the bodies will separate if not attached to each other, so the initial situation stated in the question will change. If attached to each other, a negative compressive force gives the tension in the attachment.
