B Do multiple WiFi devices create areas of high EMR?
In typical homes or offices, constructive interference from multiple WiFi devices could theoretically exceed safe power levels for individual devices. However, commercial devices operate at power levels significantly below regulatory limits, making this concern largely unfounded. The oscillators in these devices are not phase locked, resulting in a random interference pattern that averages out rather than creating consistent peaks. Therefore, while the additive effect of multiple devices exists, it does not pose a significant risk. Overall, there is no need for concern regarding WiFi exposure in these environments.
ChrisXenon
TL;DR Summary
Do they constructively interfere to create local high spots?
I'm thinking in a typical house or office, areas of constructive interference may exist which aggregate the fields of maybe 10 WiFi devices.
Wouldn't this mean the safe power levels stipulated for any single device would be routinely be exceeded? And if so, do we care?
They are not stationary, so interference will never sit still in one spot.
The simpler answer, is don't worry.
Likes Motore
Sure. When modeling the exposure, the safest assumption would be to assume they are additive (always constructively interfering).
No. Commercal home/office devices don't operate at power levels anywhere close to the limits. They are several orders of magnitude too weak:
https://www.fcc.gov/general/radio-frequency-safety-0
Moreover, the oscillators in all the devices are not phase locked so the resulting phasor addition of a number of sources will only ever give you a random-looking product with an RMS value that's the sum of the source waves; no identifiable peaks and troughs, (un?)fortunately.
Excellent - thank you both.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
