Does 2 spring @ 30 degrees = 1 @ 90?
  • Level: Undergrad
  • Thread starter alaix
    Degrees Spring
alaix
Let's say you have 2 identical springs
Let's say length = 1m
Spring constant = 0.5
You attach each spring to the ceiling and a mass. The springs make a 30 degree angle with the ceiling. Basically the system forms a triangle...
Is it OK to say that the effective spring constant of the system is equal to the spring constant of one spring, since 2*sin(30) = 1?
effective constant,,,for how long? I mean, as soon as you move a bit, that 30 degree angle is not going to be there...
...the truth is that I have not look into it, just yet, I figure I shoot you back a quick reply to make you think about your own statement, for now.
Yes, I think this is correct... for the vertical spring constant, in a small neighbourhood around the equilibrium.
Horizontally it is different, and it will change as the end moves, as gsal mentioned.
for two springs connected in a series, the effective spring constant K is given by-
1/K=1/k1+1/k2.
in parallel -
K=k1+k2.
this is a question of parallel connection so accordingly use the right expression.
(note this is righty the opposite to series and parallel connections of resistors as in electricity)
