Does a Conductor's Diameter Affect Its Magnetic Field Strength?
3 replies · 5K views
cataldo
I have two conductors in no magnetic material such as copper. One has diameter 20mm and other has diameter 50mm and both through by same current about 100A. Where do i have the maxi magnetic field on surface of conductor...I tinks on conductor with diameter 20mm..Is exactly ?
For the same current, the magnetic field at the surface is proportional to 1/R.
Tanks cleam.. Excuse me for the stupid question but i had one discussion with my friend which sayed that the magnetic field at the surface was higher on conductor with diemater 50mm ...
Bye
If the two conductors are isolated from one another, the higher field is at the surface of the 20 mm conductor. The B field outside an infinite straight conductor of radius R is
B = 2 x 10-7 I/a tesla (a>R)
where a is the distance from the center of the conductor. The field inside the wire is
B = 2 x 10-7 r I/R2 tesla
where r is a point inside a conductor of radius R (r<=R)
So the field scales as r inside the conductor, and 1/a outside. If the current is an AC current, Eddy currents force the currents toward the surface of the conductor.
