Does a flashlight battery have internal resistance?
Flashlight batteries do have internal resistance, which causes the open circuit electromotive force (ε) to differ from the voltage measured across the terminals when current is drawn. This internal resistance is influenced by various factors, including electrochemical processes within the battery. Understanding this concept is crucial for analyzing battery performance under load. The discussion highlights that all real-life batteries exhibit some level of internal resistance, impacting their efficiency. Further research into battery chemistry can provide deeper insights into this phenomenon.
carnivalcougar
Does a flashlight battery have internal resistance? Explain.
V = ε - Ir
Yes, they do have internal resistance. This results in the open circuit ε being different than the voltage measured across the terminals if a current is drawn from the source.
I'm not sure why, though. I'm also not sure if the question is asking why they have internal resistance or if its just asking what the implications of this internal resistance are.
V = ε - Ir
Yes, all real-life batteries and power supplies have internal series resistance. You can Google battery chemistry internal resistance to learn more to help you answer that part of the question. :smile:
Likes 1 person
What he said.
Just about everything has resistance (except superconductors), including the terminals of the battery.
Likes 1 person
Likes 1 person
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 42 ·
  • · Replies 24 ·
