Does a free falling charge radiate ?
  • Level: Graduate
  • Thread starter Thread starter greswd
    Charge Falling
102 replies · 18K views · last reply
PAllen said:
That section is describing zero and first order approximation to geodesic. Then, the error terms vanish as M->zero, without reaching it. For small M, the path is almost independent of M; the convergence of these paths as error terms go to zero (an infinitesimal mass particle), the path becomes exact geodesic.
But aren't the errors parameterized by λ, not M?
Intuitively, I'd expect that for non-zero mass, but the taking the test body approximation (body is not a source), then we get an exact timelike geodesic.
Then if we allow backreaction (body is a source), then we get an approximate timelike geodesic.
PAllen said:
The question is, what is the test? A geodesic of the numerical metric would represent a test body motion in the spacetime of the two massive bodies, not the motion of of the massive bodies.
I would expect it to represent both, at least at the level of approximation I think is being used for the binary pulsar modeling. AFAIK they are not modeling the pulsars' internal structure; they are just treating them as spherically symmetric objects each with a given mass and radius, where the radius is much smaller than the distance between them. The motion of each body is represented by the motion of the geometric center of each sphere; that's the motion that I believe works out to a geodesic of the overall metric.
I'd like to see some reference for that. I could find no such thing when I last researched this. I was specifically looking for a way to treat it like that (each body moving on a geodesic fo the total spacetime), but could find nothing.
A body not a source is counter-factual unless body has infinitesimal mass. Thus, a no source approximation is a limit of mass approaching zero.
I guess he has λ→0, but M≠0. So you are saying mass goes to zero because λ→0, whereas I am saying mass is not zero, because M≠0. I do think λ→0 is kind of a mass→0, so I see your point, but I still don't understand then why M≠0.
I think the treatment in section II of:
http://arxiv.org/abs/1002.5045
Which is based on Gralla and Wald, is a bit simpler and easier to understand. They make explicit that mass must decrease to zero as λ decreases to zero.
Looks like there are 2 masses. He says λ→0 is mass going to zero, but at the end M≠0, which he says is the ADM mass.
For λ→0, it's more like a size going to zero. He says in words mass goes to zero, otherwise it's a black hole. But I don't see a problem with the point particle being a black hole, so is there a need to say λ→0 is size and mass going to zero?
It seems conceptually ok to have the "word description" of λ→0 as size going to zero, we allow the point particle to be a black hole, and we end up with non-zero mass M≠0.
I think I see the resolution. The metric is scaled during the limiting process, and the ADM mass is a scaled ADM mass. That is, unscaled, the mass goes to zero, but the scaled ADM mass remains constant:
"The results of this section (i.e., the results of sec. IV of [4]) may be summarized as
follows. Consider a one-parameter-family of spacetimes containing a body whose size and
mass decrease to zero, according to the stated assumptions."
"Furthermore, the “particle mass” M is indeed the
ADM mass of the body (as measured in the scaled limit)."
All of this must be true based on my physical argument: you cannot treat a finite mass body as not being a source, no matter how small you make it (without also decreasing its mass).
Let me try to get at the crux of the matter. There is some exact metric (which we don't know) representing two similar mass orbiting bodies. If we assume they are BH's, what might be presumed to represent a world line trajectory for one is the world line of a singularity - oops, better not go their; that's not in the manifold. Thus, we better not assume BH.
Then, a world line representing a body trajectory is one that is always inside a world tube of non-vanishing SET (call it a matter region). What would need to be shown is that there exists a timelike geodesic in matter region that remains always in the matter region. Then if the matter size is small, this is reasonably a body trajectory. I am unaware of any such result being referred to in the literature. It would be really cool if it were true and someone provided a convincing argument for it.
Then, also, a timelike geodesic in the vacuum region would represent a test body trajectory.
Another take on this would be to imagine co-orbiting spherical shells. Then also what we would like to believe is that some geodesic inside each shell (one with the right initial tangent) is always inside the shell, never hitting the edge. (Note that while for one shell, you have Minkowski space inside, for two shells you do not - there is no such thing as a gravity shield, and one shell influences geometry inside the other shell).
PeterDonis said:
I see that Sam Gralla made this comment:
I think that the binary pulsar case would be an example of the bolded phrase above; the neutron stars in binary pulsars are very far apart compared to their individual sizes. So in that case one might be able to derive post-Newtonian analytic expressions for the metric and its geodesics, if I'm reading him right.
However, he also mentions numerical solutions at the end, which makes me wonder: do numerical solutions not give enough information to even apply the test I described?
I don't think that is the sense of Gralla's comment. Post-Newtonian methods give valid appproximations for weak-field situations, you might try and use it just to approximate the orbit of 2 bodies when their distance is very large wrt their radii and call them geodesic orbits, but that won't get you a realistic approximation for the gravitational radiation of that system, for that you need strong-field numerical relativity.
Ultimately this might be a definitional problem, but if you want to call geodesic motion to all orbiting bodies, extended or test particles, regardless of the intensity of the radiation (gravitational or EM) they are emitting you basically are saying that all test particles and extended bodies worldlines following some kind of orbit no matter how unstable are following geodesic motion which I don't think it's true.
I used to also think that extended objects in orbit followed geodesics but was convinced here at PF that this would make gravitational radiation a superfluous notion since if orbiting bodies emitting radiation, regardless of the intensity(strong-field case) didn't see affected their geodesic motion, first:what could actually ever affect a geodesic path? and second: how do we expect that radiation to affect distance bodies detectors if it isn't capable to alter the geodesic path of the emitting body in the least(as long as we still consider third Newton's law as valid of course).
Yes, the physical argument is good. I'm guess it is right that the massless limit (λ→0) is an exact timelike geodesic, and it is also right that this limit depends on M≠0, where M is the ADM mass for a scaled observer at any λ > 0, so that the massless case "remembers" that it has come as the self-similar limit of a massive body. So the massless point particle on an exact timelike geodesic exists, but cannot exist on its own, and must come from a limit of massive bodies.
atyy said:
Yes, the physical argument is good. I'm guess it is right that the massless limit (λ→0) is an exact timelike geodesic, and it is also right that this limit depends on M≠0, where M is the ADM mass for a scaled observer at any λ > 0, so that the massless case "remembers" that it has come as the self-similar limit of a massive body. So basically, the massless case cannot exist on its own, and must come from a limit of massive bodies.
That's the way I interpret it. Especially given that we know that over 50 orders of magnitude (Jupiter around sun, to atom around sun), the path is essentially the same. The limit is a continuation of this process. Call it the 'infinitesimal limit of mass and size' rather than a mass of zero.
That paper is like magic. First he says point particles don't make sense, then he shows they magically pop out when you consider a family of massive bodies. The appearance of the ADM mass is the most amazing thing.
One thing that prevents any possibility of such a limiting process approaching a null geodesic is that there is no such thing, in GR, of an 'almost null' timelike path, in any coordinate independent sense. So you must get a limiting timelike path, as the physics suggests.
But shouldn't be an analogous argument for null geodesics, since those are what test light rays move on?
This makes sense, and I agree it might indeed be what Gralla was trying to say. Basically this would mean that, since the orbital period of the binary pulsar is much shorter than the characteristic time scale for gravitational radiation from that system, the post-Newtonian method would give approximate geodesic orbits for time scales short compared to the radiation time scale, but if you tried to model the long-term behavior of the system that way you would have to adjust the orbital parameters every so often as gravitational radiation was emitted to keep the approximation close enough. To actually predict the long-term changes in the orbital parameters, you would need to do the strong field numerical simulation.
I'm not trying to say this. I agree there would be little point in the concept of a geodesic if it didn't give you a way to pick out some meaningful subset of all possible worldlines.
Geodesic paths can "change" and still be geodesic paths because of changes in the metric that defines what a geodesic path is. Consider the detector scenario; suppose we have a GW detector that uses interferometry, like LIGO or LISA. When a gravitational wave passes through the detector, it shows interference fringes; but the individual mirrors that reflect the laser light that shows the fringes (because of small changes in the proper length between the mirrors) are in free fall the whole time. They are following geodesics, but geodesics of a time-varying metric.
Similarly, the two neutron stars in the binary pulsar could be following geodesics, but still have their orbital parameters change, because the metric is changing. In fact, that's probably the wrong way to think about it, though, because the changes in the orbital parameters, at least to a first approximation, *are* the changes in the metric. The stars themselves don't change, considered in isolation; what changes is their relationship. The overall metric of the system as a whole includes the relationship between the stars, so if that changes, the metric changes, even if each star remains exactly the same internally. This doesn't mean the stars don't travel on geodesics; it means that there is a single self-consistent solution realized by Nature (which we can only approximate at our current level of knowledge) that has each star (more precisely, each star's center of mass) traveling on a geodesic of the full, time-dependent metric that is ultimately due to the two stars acting together as sources.
But *why* would the orbital parameters change, if the stars themselves are not changing internally? AFAIK the answer to this involves the light-speed time delay in the propagation of gravity, as outlined, for example, in this paper by Carlip:
http://arxiv.org/abs/gr-qc/9909087
Of course it's possible that the full, self-consistent solution realized by Nature does not have the stars traveling on exact geodesics of the full, time-dependent metric; that's what Gralla seems to think, for example. We won't know for sure until we can construct such solutions and make more precise observations. But I don't think we can rule out the possibility that, at least for systems like the binary pulsar, gravitational waves can be emitted without requiring any deviation from geodesic motion to explain them.
I would think it should be possible to make a similar argument for light. Start with some SET representing a wave packet in some background geometry. Theoretically it acts as a source and can produce GW, thus not following a geodesic exactly. Then, in some limiting process to zero size and energy, it does exactly follow a null geodesic. Not saying I have any idea how to pull this off. Note, that there are null paths that are not geodesics. This would presumably take the limit of nearly geodesic null paths to the geodesic limit.
It's easy. Just kidnap Sam Gralla ...
I'm really skeptical this can be done in any meaningful sense. Consider a fluid body with internal flows and eddies. Then geodesics of the metric from the SET would seem to represent the local flow at a point. You might then have many different convoluted geodesics. If you then try a limiting process like Wald & Gralla, here you have to keep actual (not scaled) mass constant as you shrink the bodies - at least if you want your limiting case to include GW. But then you get singularities ...
If you try an averaging approach, how do you make it precise? Average of a bunch of convoluted geodesics? If the approach only applies to sufficiently simple SET, it isn't much of aresult.
I haven't seen you address the issue of geodesics of what, exactly? Clearly, if you had a complete solution including matter and vaccuum, representing co-orbiting stars, geodesics of the vacuum metric would represent test particle paths for particles under the action of the stars and their GW. Geodesics in the matter region are more complex, but I would think they represent matter flow lines which could be all over the place for a general SET. I am completely failing to see how to state the proposition that the star is following a geodesic.
And if I imagine limiting this to zero sized stars, at every stage, vacuum geodesics near a star represent a test particle orbit, while the star itself becomes singular.
Consider a simple example: a spherically symmetric gravitating body like a neutron star. The worldline of the center of mass of the star (which is also its geometric center, and the spatial origin r = 0 under the usual Schwarzschild-type coordinates) will be a geodesic; just ask yourself what its proper acceleration is. If it's nonzero, then it picks out some preferred direction in space (the direction of the acceleration), which breaks spherical symmetry. So whatever the full metric in the matter region is, the star's CoM follows a geodesic of it.
It is true that, since the star has finite size, no portion of the star other than its CoM will travel along a geodesic; again, that's obvious just by considering that the proper acceleration of any piece of matter at r > 0 must be nonzero. So there are certainly pieces of matter present that are traveling on non-geodesic worldlines. But if we don't need to worry about the star's internal structure, we can ignore all that, and just treat the motion of the star's CoM as the motion of the star.
What I'm hypothesizing is that a similar dodge will work in a case like the binary pulsar: we can ignore the internal structure of the two neutron stars and treat the motion of each star's CoM as the motion of the star itself. Then the question becomes: what is the proper acceleration of each star's CoM? I'm hypothesizing that it's still zero; the only thing that I can see that would make it nonzero is that curvature effects would cause a net force on the star as a whole, something like "spacetime swimming":
http://dspace.mit.edu/handle/1721.1/6706
In the binary pulsar case I would expect any effect of this type to be too small to matter because the separation between the stars is so much larger than their sizes; but I admit I have not tried to do any calculation along these lines.
Well, for starters, there are big problems defining COM in GR. In any case, I assume you no longer would claim you know that this will work.
Last night I did find an old write up by Synge of the following:
Under very broad assumptions, given a matter world tube with sharp boundary, and assuming no non-gravitational radiation, and an exterior vacuum metric region with no assumptions made (e.g. could be non static; no asymptotic flatness assumed), then there exists in the matter world tube a locus of points of no proper acceleration that form a continuous curve*. However, he claimed (without showing it, only by reference to ancient literature he was borrowing the treatment from) that such a locus not only need not be the path of any matter, it could be spacelike! (Even though every piece of matter is following a timelike path).
* For a non-spinning body, it is necessary to assume things about pressure that seem physically plausible, to get this result. For a spinning body, he had to assume a limit on amount of spin. Without assuming these, it did not follow that there was a locus of no-acceleration at all.
So, I think you have a lot of work to make your argument really convincing.
But we don't have any such solution of the EFE and it's hard to see that coming soon. This IMO would get us close to the no useful distinction between timelike geodesics and timelike worldlines scenario.
Interferometry for GW detection either ground-based or space-based measures motion between separated 'free' or test masses. That motion is obviously a deviation of the expected free fall motion of the masses that gets reflected by the mirrors, otherwise nothing is measured, that deviation is the deviation from geodesic motion of the emitter.
If GW are disturbances of the gravitational field i.e propagation of changes in spacetime curvature, it is hard to see how it would be possible for them to be emitted and detected maintaining geodesic motion of the body that emits them or the detector that receives them as long as we think of geodesics as the straightest spacetime lines in a curved manifold.
In the general case, yes. I don't mean to say that the sort of thing I'm talking about will work in the general case. I'm trying to see if something like the binary pulsar can be treated as close enough to an idealized special case where the big problems don't arise.
I didn't mean to claim that in the first place. Sorry if that wasn't clear.
Hm, interesting. I don't suppose anything like this is available online? :wink:
"Expected" in the absence of GWs.
Not necessarily. That's the question under discussion.
I think you're failing to consider that the spacetime curvature of the manifold is time-dependent; a time-dependent metric means that a geodesic curve won't look "straight" in the sense you would expect it to based on looking at geodesics in time-independent metrics. If GWs are present then the metric has bumps and wiggles in it; that's what the GWs *are*. So geodesics of such a metric will also have bumps and wiggles, which will be followed by objects lying in the path of the GWs. AFAIK the fact that the motion of the mirrors in an interferometer-type GW detector is geodesic is well-established; I'm pretty sure Kip Thorne goes into this in Black Holes and Time Warps, for example, at least at a lay person's level.
Not that I could find.
I did find a way to visualize this surprising claim:
Imagine there is fluid wave motion inside the body. Then the locus no acceleration could reflect that some 'particle' in the wave has no proper acceleration, while a nearby particle in a slightly different phase of the wave is the 'next' particle with no proper acceleration. Then the locus of no acceleration represents something more like a phase propagation than a material propagation. I can imagine it in a spacelike zigzag through the world tube.
Perhaps under much more restrictive assumptions about the SET, you could get a nicer result. But, again, I've looked and not found any sign of such claim in the literature (but I don't have access to a university library, and don't claim to any great searching skills).
[In particular, I did a lot of searching on 'generalized equivalence principle' and 'Detweiler-Whiting' to see if there even any proposals that these could be generalized. I found none. The implications of some writers was clearly that this could only be expected for the extreme mass ratio case covered by the MiSaTaQua equation. ]
I have no problem with the geodesics in a time-dep. metric. Think of the FRW metric. I just said we don't have such a metric for a spacetime compatible with GWs.
Well the existence of such metrics as solutions of the EFE is what's being discussed.
Yes, but that motion has to be disturbed to register a GW.
