Does a moving magnetic field generate a current?
A moving magnetic field can indeed generate a current in a wire, as demonstrated by the principles of electromagnetic induction. Specifically, moving a magnet beneath a circular wire can induce a current, similar to how a wire moving through a magnetic field generates electricity. This principle is utilized in various applications, including Hi-Fi audio equipment with moving magnet and moving coil pickups. The discussion clarifies that the orientation and movement of the magnet relative to the wire are crucial for current generation. Understanding these concepts is essential for projects involving electromagnetic induction.
HumanDrew
Hey! Not sure if this is a stupid question or not but I was wondering if a moving magnetic field could generate a current in a wire. I know that moving a wire through a magnetic field creates a current but what if you move around a magnet underneath a circular wire. Does that generate a current?
Yes (if you are into Hi-Fi, you will know that there are both moving magnet and moving coil pickups).
Likes HumanDrew
Thanks for the answer Svein! I was just wondering because I wanted to do a science project that is reliant on creating a current in a wire with a moving magnet.
Actually to clarify my question a little better, I'm not specifically talking about something like a solenoid, where a magnet goes through a coil of wire. Instead would current be generated if there was a circular loop of wire parallel to the ground and a magnet moving left and right underneath this wire.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
