Does a regular polygon's area approach circle area as n approaches infinity?
7 replies · 3K views · last reply
John Clement Husain
TL;DR
Does the limit as n approaches infinity of the area of an n-sided polygon equal to the area of a circle?
Hello everyone!
I have been looking for a general equation for any regular polygon and I have arrived at this equation:
$$\frac{nx^{2}}{4}tan(90-\frac{180}{n})$$
Where x is the side length and n the number of sides.
So I thought to myself "if the number of sides is increased as to almost look like a circle, does it result in the area of a circle?"
Is this:
$$\lim_{n\to\infty} \frac{nx^{2}}{4}tan(90-\frac{180}{n}) = \frac{C^{2}}{4\pi}$$
true?
$$tan(90-\frac{180}{n}) $$
should become smaller with increasing n, to get a finite limit.
John Clement Husain said:
Summary: Does the limit as n approaches infinity of the area of an n-sided polygon equal to the area of a circle?
Hello everyone!
Is this:
$$\lim_{x\to\infty} \frac{nx^{2}}{4}tan(90-\frac{180}{n}) = \frac{C^{2}}{4\pi}$$
true?
Why are you taking the limit as ##x \rightarrow \infty##?
If you keep ##x## fixed, then the area is infinite as ##n \rightarrow \infty##. If you want your polygon to tend to a finite shape, then you need ##x## and ##n## to be related.
Note that using ##l## for the length of a side might have been more conventional.
It might be simpler to look at the angle, ##\theta = 2\pi / n## at the centre of the polygon and have a fixed distance to the vertices, ##r##, say.
Then you let ##n \rightarrow \infty## and see what happens to the limit of the area of the polygons. Note that the length of the sides of the polygon will tend to ##0## in this case.
PS what's perhaps more interesting is to show that the length of the perimeter of the polygons, ##nl##, tends to ##2\pi r##.
Oh! right, that was a typo.[/QUOTE]
You still need to calculate ##x## in terms of ##n##.
It's easier to see if you find the area in terms of one variable relating to a circle. Take for instance the area of a regular polygon in terms of the circumradius r and number of sides n.
##A = \frac{r^2 n sin(\frac{2\pi}{n})}{2}##
The limit of this formula as the number of sides ##n\rightarrow\infty## is the familiar formula for the area of a circle.
