Does Anyone Use Newtonian Physics w/ Arbitrary Time Coordinates?
pervect
Staff Emeritus
Insights Author
It's fairly common to use Lagrangian mechanics to handle arbitrary space coordinates. But is it ever actually used to handle arbitrary time coordinates, particularly in Newtonian mechanics?
For example, does anyone consider the transformation
x = X
t = T + uX
where (x,t) are normally synchronized coordinates, and (X,T) are abnormally synchronized coordinates.
I fiddled with this, and I'm currently getting the following. Consider a free particle, and let X' = dX / dT
Then I get:
<br /> L(T,X,X&#039;) = \left(\frac{m}{2}\right) \, \frac{X&#039;^2 }{(1 + u\,X&#039;)}<br />
<br /> p = \frac{\partial L}{\partial X&#039;} = m\,X&#039;\,\frac{(1+\frac{1}{2}u\,X&#039;) }{ (1+u\,X&#039;)^2}<br />
which gives an energy function, h of
<br /> h = pX&#039; - L = \frac{m}{2} \left(\frac{X&#039;}{1+u\,X&#039;}\right)^2<br />
It seems to work, because the energy function h is what one expects, i.e h = (1/2) m v^2, where v = dx/dt, the velocity in normally synchronized coordinates.
as
dx = dX, and dt = dT + udX,
so dx/dt = (dX/dT) / (1 + u (dX/dT)) = X' / (1+u X')
however, I had to try a couple of times to get the Lagrangian right - while L has the same numerical value independent of changes in the spatial coordinates, it's NOT independent of the changes in the time coordinates , rather L dt is the same, and dt != dT.
Anyway, if this is legitimate, is there any paper or textbook that considers the problem?
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
