Devin-M
- 1,078
- 771
I’m talking about this region:
OK, that is pretty solid. I guess my understanding was wrong. I didn’t expect it to be independent.collinsmark said:According to ideal theory, the average pixel value with both slits open should be quite close to twice the average value of a single slit.
I fear you still do not understand. This is inherently a problem of global interference of waves. The mathematics is essentially the same for sound waves, gravity water waves, EM waves, or "probability waves". Bouncing balls will not provide the correct answer.Devin-M said:…but farther away from the central peak region the number of light sources switches from odd to even… you don’t have any light that went classically directly from the star and you only have the 4 edges as sources.
I still don't understand why you expect that regions outside of the central peak to have those intensities. You have to look at the whole difraction pattern, only then you will have double the intensity for the two slits vs single slit, because you will see the whole light that goes through. But why are you expecting there to be double the intensity in same specific regions for different difraction patterns is beyond me. Which I already said in post #27.Devin-M said:I was just wondering if your measurements agreed with my original measurements that comparisons of the pattern outside the central area show far less than double the average intensity with the second slit.
How well did you calibrate your frames before making the counts? Did you dark subtract? Did you remove the bias counts typically added to all images by the sensor? Does the sensor or camera automatically add or subtract values from each pixel during readout and processing?Devin-M said:If you have double the total mean intensity with 2 slits overall, and double the total mean intensity with 2 slits in the comparable area encompassing the 1st single slit maxima, then you should expect to find double the total mean intensity in the areas encompassing the outer maxima as well but that isn’t what my initial measurements showed.
Noise 39.7 avgDrakkith said:How well did you calibrate your frames before making the counts? Did you dark subtract? Did you remove the bias counts typically added to all images by the sensor? Does the sensor or camera automatically add or subtract values from each pixel during readout and processing?
Sorry, I don't know what this is supposed to show or how it answers my questions.Devin-M said:Noise 39.7 avg
Single 115.2 avg - 39.7 noise avg = 75.5 avg
Double 173.9 avg - 39.7 noise avg = 134.2 avg (1.77x higher)
But what did you do to calibrate those raw files? Even dedicated astrophotography cameras, which are built specifically for low-light, long-exposure applications have to be calibrated. Just see post 56 as an example.Devin-M said:Readings straight from the RAW files:
Devin-M said:Single 115.2 avg - 39.7 noise avg = 75.5 avg
I've never heard of this calibration method. Why would you subtract the average background noise? Unless I'm mistaken, that's not going to get rid of the counts from the dark current nor the bias counts. Just so we're on the same page, noise is the random variation of counts or pixel values between pixels in an image or between the same pixel in multiple images.Devin-M said:I did… I sampled the dark noise and subtracted it…
Devin-M said:It’s also interesting to note if you look on the tables on the right hand side for the single versus double slit, in the selected area of interest, the max pixel value is almost exactly double not quadruple (1.99x higher). (1293 vs 648) @collinsmark
You do want an image as the final output, because an image is nothing more than a bunch of data points. But that's mostly beside the point. What I'm getting at is that without carefully calibrating your image (your data) you can't draw meaningful conclusions. You don't know the average ADU for the diffraction pattern because the pattern's ADU's are mixed in with dark current ADU's and possibly a bias offset. Subtracting the average background noise does nothing because noise is not something that can be subtracted. All you're doing is finding the magnitude of the average variation in the pixels in some area and then subtracting that value from other pixels. Which is pointless as far as I know, as you're still left with all of the noise and you've introduced your own offset that has no purpose.Devin-M said:That would make sense if I wanted an image as the final output, but all I want is the average ADU/pixel in the area of interest (with average noise ADU/pixel ignored). So I took the average noise per pixel and subtracted that from the average ADU/pixel in the area of interest.
@Devin-M, I've uploaded the cropped versions of the data in TIFF files, inDevin-M said:@collinsmark would you be willing to upload your finalized TIFs / FITs of your stacked single / double slit files (and/or a RAW file or 2) here so I can closely inspect them… ?
https://u.pcloud.link/publink/show?code=kZtCzeVZwIlHPwhNQlfVXx7j9TTxPLteswcy
The final output I desire is a ratio of 2 averages. I just tested my method and it works perfectly.Drakkith said:You do want an image as the final output, because an image is nothing more than a bunch of data points. But that's mostly beside the point. What I'm getting at is that without carefully calibrating your image (your data) you can't draw meaningful conclusions. You don't know the average ADU for the diffraction pattern because the pattern's ADU's are mixed in with dark current ADU's and possibly a bias offset. Subtracting the average background noise does nothing because noise is not something that can be subtracted. All you're doing is finding the magnitude of the average variation in the pixels in some area and then subtracting that value from other pixels. Which is pointless as far as I know, as you're still left with all of the noise and you've introduced your own offset that has no purpose.
Your method is flawed and there is a very good reason it appears to work in this situation but will not work on a real astro photo, but I leave that to you to discover, as you don't appear to want my assistance or advice.Devin-M said:I just tested my method and it works perfectly.
@Drakkith I do want your assistance & advice. I was just testing the error bars on the camera to the best of my abilities.Drakkith said:Your method is flawed and there is a very good reason it appears to work in this situation but will not work on a real astro photo, but I leave that to you to discover, as you don't appear to want my assistance or advice.
Forgive me if I'm a bit snippy. I've had a rough couple of days.Devin-M said:@Drakkith I do want your assistance & advice. I was just testing the error bars on the camera to the best of my abilities.
The noise gets rectified and so produces part of the DC offset. A false DC offset in a ratio is a bad thing.Drakkith said:First, I don't understand why you're doing anything with noise. Why are you subtracting the average noise value? What does that accomplish?
