Does Destructive Interference Affect Starlight in a Double Slit Experiment?
110 replies · 12K views · last reply
I’m talking about this region:
Dark background with three vertical columns of bright spots, each with a bright central blob and fainter spots above and below; a red rectangle outlines the upper-left region.
collinsmark said:
According to ideal theory, the average pixel value with both slits open should be quite close to twice the average value of a single slit.
OK, that is pretty solid. I guess my understanding was wrong. I didn’t expect it to be independent.
With the double slit if you think of the edges of the slits as separate light sources from the star (ie where the light reflected off the edges of the slits), with the central peak region you have 5 sources (odd number)… ie source 1) The light from the star that didn’t reflect that went classically straight through the slits to the central peak & sources 2) - 4) the light that reflected off the 2 edges of the 2 slits…
…but farther away from the central peak region the number of light sources switches from odd to even… you don’t have any light that went classically directly from the star and you only have the 4 edges as sources.
I wonder if there is less than double the number of photons detected in this region if it has something to do with having an even number of sources rather than an odd number.
I fear you still do not understand. This is inherently a problem of global interference of waves. The mathematics is essentially the same for sound waves, gravity water waves, EM waves, or "probability waves". Bouncing balls will not provide the correct answer.
Also there is a ~simple "exact" solution available for two finite slits. For instance https://web.mit.edu/8.02t/www/802TEAL3D/visualizations/coursenotes/modules/guide14.pdf
All the answers are explicitly there. Plot the function and play with it.
Devin-M said:
I was just wondering if your measurements agreed with my original measurements that comparisons of the pattern outside the central area show far less than double the average intensity with the second slit.
I still don't understand why you expect that regions outside of the central peak to have those intensities. You have to look at the whole difraction pattern, only then you will have double the intensity for the two slits vs single slit, because you will see the whole light that goes through. But why are you expecting there to be double the intensity in same specific regions for different difraction patterns is beyond me. Which I already said in post #27.
If you have double the total mean intensity with 2 slits overall, and double the total mean intensity with 2 slits in the comparable area encompassing the 1st single slit maxima, then you should expect to find double the total mean intensity in the areas encompassing the outer maxima as well but that isn’t what my initial measurements showed.
How well did you calibrate your frames before making the counts? Did you dark subtract? Did you remove the bias counts typically added to all images by the sensor? Does the sensor or camera automatically add or subtract values from each pixel during readout and processing?
Noise 39.7 avg
Single 115.2 avg - 39.7 noise avg = 75.5 avg
Double 173.9 avg - 39.7 noise avg = 134.2 avg (1.77x higher)
Dark photo with a red box outline; two columns of red light spots, the left column a single bright band and the right column several stacked bright spots, with faint spots above and below.
Readings straight from the RAW files:
Astrophotography screenshot of a dark, grainy image showing a vertical column of bright star spots, with a red-outlined rectangular noise sample box at right, and two statistics panels at top listing min, max, average and sigma values for RGB and G2 channels.
Screenshot of image statistics panels over a dark night-sky photo with a red-outlined rectangle selecting a dim region above three bright spots in a vertical column.
Astronomy camera screenshot showing a dark frame with a bright elongated spot, a red rectangular selection box over the dark background, and two statistics panels listing min, max, average and sigma values for R, G, B channels.
Devin-M said:
Noise 39.7 avg
Sorry, I don't know what this is supposed to show or how it answers my questions.
But what did you do to calibrate those raw files? Even dedicated astrophotography cameras, which are built specifically for low-light, long-exposure applications have to be calibrated. Just see post 56 as an example.
It was single 5 minute exposures at 6400 iso (double slit & single slit). Camera: Nikon D800 Lens: Nikon 300mm f/4.5 + TC-301 2x teleconverter for 600mm f/9. Original raw (NEF) files were inspected with RawDigger (with no modifications). Screenshots from that program are shown above. On the top right of those screen shots you can see an average pixel value for the selected areas. R AVG shows the values I discussed in the previous post. I also took a representative sample of the average noise and subtracted it from the raw values to give the final values. I selected the 1st and 2nd order maxima from the single slit and the same area for the double slit. Double slit R avg in the selected area was 1.77x higher than single slit.
RAW Files (Images 9205 & 9213): https://u.pcloud.link/publink/show?code=kZcjE2VZR1eBfOCgGAYfuGOv9EMgPH3KIR07
So you didnt do any calibration? No dark or bias frame subtraction?
Why?
I did… I sampled the dark noise and subtracted it…
Avg noise per pixel was 39.7… that was then subtracted from the signal
Astronomy image editing screenshot with two statistics panels listing per-channel min, max, average and sigma values, and a dark noise sample box outlined in red beside a grainy vertical bright spot pattern.
Grayscale microscope-style photo of a faint vertical column of blurred bright spots on a dark background, with a red rectangle marking a dark sample region above them and a panel of pixel statistics (Min, Max, Avg, σ) at top.
Screenshot of image statistics panels above a dark grey noisy image with a red rectangle over a noise-only region and a bright elongated blob of light below it.
Dark background photo with two columns of red light spots: a bright elongated blob on the left and a stack of three bright spots on the right, with a red rectangle drawn around fainter spots above.
I've never heard of this calibration method. Why would you subtract the average background noise? Unless I'm mistaken, that's not going to get rid of the counts from the dark current nor the bias counts. Just so we're on the same page, noise is the random variation of counts or pixel values between pixels in an image or between the same pixel in multiple images.
The point of calibration is to remove counts that aren't due to capturing your target's light. I call these counts 'unwanted signal'. The major sources of unwanted signal are dark current, background light that falls onto the same area of the sensor as your target, and stray light from internal reflections or other optical issues. In addition, the camera itself typically adds some set value to each pixel, called an offset value or bias value.
The bias value itself isn't noise, as it's just a set value added to each pixel and is easily removed. But all sources of unwanted signal add noise because they are real sources and obey the same statistical nature as your target. The funny thing with noise is that it simply cannot be removed. What can be removed is the average dark current and the bias value (the other sources of unwanted signal can also be removed, but it is much more difficult and well beyond the scope of this post).
To remove dark current (not dark noise, which cannot be removed) one must take dark frames, combine them together to get a master dark frame, and then subtract this frame from each target exposure. This will get rid of both the bias value and the average dark current in each pixel. These should be the worst sources of unwanted counts in your images and their removal is just about all you need to do if you're just worried about counting pixel values. You could use flat frames, but as long as we're dealing with only a small part of the sensor and there aren't large dust particles on the filters and sensor window that are casting shadows on this area we don't really need to worry about flats.
Since measuring the average background noise and then subtracting this value from each pixel doesn't remove either dark current or the bias offset I'm confused why you would so so.
That would make sense if I wanted an image as the final output, but all I want is the average ADU/pixel in the area of interest (with average noise ADU/pixel ignored). So I took the average noise per pixel and subtracted that from the average ADU/pixel in the area of interest.
You are searching for a 1% answer.
Can you not turn all the autoscaling off? You don't need more than 8 bits of useful resolution to answer your query.
Why are pixels saturating? Particularly why are blue and red ones saturating but apparently not green? You need to eliminate them from your calculation, particularly the way you are doing your averages. You really should do the manipulations on a pixel by pixel basis (can you not do that with your software?)
Instead of rerunning the same experiment endlessly, take a close look at your data. How about a histogram of the dark counts for one frame many pixels? You need to develop the ability to change your point of view.
How about a plot of the theoretical predicted graphs for your wavelength and widths? There are many ways to proceed and you seem to have plenty of data, interest, and perseverence. Ask and answer a slightly tangential question and you will learn something..
There was no scaling, and there was no saturation. If you look at each of the samples, there are two tables of data at the top, on the left is for the full image, and the right is for the selected area of interest. The only scaling occurred for display purposes on this forum, but not in the sample data. You want to be looking at the right table for each of the samples. Specifically you want to be looking at the R average values in the right table. if they were saturating, the max pixel value would read 16,383, but in the right tables for the selected area of interest, none of the pixels are reaching that value.
It’s also interesting to note if you look on the tables on the right hand side for the single versus double slit, in the selected area of interest, the max pixel value is almost exactly double not quadruple (1.99x higher). (1293 vs 648) @collinsmark
In terms of the peaks of any of the side-lobes (anything other than the central peak), it depends how the troughs (from destructive interference) from a single slit pattern line up with the additional troughs from having two slits.
And whether they line up at all, or how they relate to each other even if they don't line up, is dependent on a) the width of the individual slits and b) the separation of the slits. In other words, if you were to switch to a new Bahtinov mask by a different manufacturer, they might line up differently.
The troughs (a.k.a. "nulls") of the single slit pattern are a function of the slit widths. If you make the slit width more narrow, the whole pattern becomes wider. (and vice-versa)
The additional, and more frequent, troughs/nulls of the double slit pattern are dependent on the separation of slits. Move the slits closer together (while keeping the slits widths unchanged) and you'll get fewer, additional nulls in the pattern. Move the slits farther apart and you'll get more frequent nulls.
With that, there isn't any general rule about the off-center peaks of the pattern, or even the average pixel value of an off-center lobe. It all depends on how these troughs/nulls line up. [Edit: in other words, I think the specifics of the 1293 vs. 648 observation is largely a matter of coincidence, and based on the fine particulars of your mask's slit width vs. slit separation details.]
A bit of a side note: If you're familiar with Fourier analysis, it might help here. As it happens, diffraction patterns are intimately related to Fourier analysis. With making a few assumptions about setup, such as the slit widths and separations being << the distance to the detector; and applying various constants of proportionality, you'll find that in the limiting case, the diffraction pattern is the magnitude squared of the spacial Fourier transform of the slits. [Edit: for a given, fixed, wavelength of light.]
You can at least use this fact qualitatively if you just want a quick idea of what shape you can expect as a diffraction artifact for a given obstruction.
For example, it's no coincidence that diffraction pattern of a single slit (of monochrome light) is more-or-less that of a [itex]\left( \mathrm{sinc}(x) \right)^2[/itex]. In one dimension, a single slit is that of a rectangular function. What's the Fourier transform of a rectangular function? well, it's in the form of a sinc function. Square that [magnitude squared], and you get the same shape as the diffraction pattern. You can do the same sort of thing for the double slit.
I mention all this here because it might be easier to mess around with the math (at least qualitatively, maybe with the aid of a computer) than painstakingly cut up different masks every time you want to make a minor change to the slit pattern.
Don't get me wrong, I'm not saying that Fourier transforms are the end-all-be-all of diffraction theory. Diffraction theory can be a bit more nuanced. All I'm saying is that if you've built up an intuition with Fourier analysis, that intuition can be useful in predicting the effects of how changing the slits will change the diffraction pattern, at least in a qualitative sort of way.
You do want an image as the final output, because an image is nothing more than a bunch of data points. But that's mostly beside the point. What I'm getting at is that without carefully calibrating your image (your data) you can't draw meaningful conclusions. You don't know the average ADU for the diffraction pattern because the pattern's ADU's are mixed in with dark current ADU's and possibly a bias offset. Subtracting the average background noise does nothing because noise is not something that can be subtracted. All you're doing is finding the magnitude of the average variation in the pixels in some area and then subtracting that value from other pixels. Which is pointless as far as I know, as you're still left with all of the noise and you've introduced your own offset that has no purpose.
Devin-M said:
@collinsmark would you be willing to upload your finalized TIFs / FITs of your stacked single / double slit files (and/or a RAW file or 2) here so I can closely inspect them… ?
https://u.pcloud.link/publink/show?code=kZtCzeVZwIlHPwhNQlfVXx7j9TTxPLteswcy
@Devin-M, I've uploaded the cropped versions of the data in TIFF files, in two [now three] different pixel formats.
The more detailed format is 32 bit, IEEE 754 floating point format. This should retain all the detail involved, but not all image manipulation programs work with this level of detail.
The second is with the data converted to 8bit (per color) unsigned integer. This is the more standard/more accessible format, but less detail per pixel. As a result some of the details are lost. For example, a lot of darker pixel values are simply 0. It's probably not a big deal, since most of the data at that level of detail was just noise anyway.
[Edit: I've also uploaded the TIFF files saved with 16bit, unsigned integer format too, if you'd rather work with that.]
The final output I desire is a ratio of 2 averages. I just tested my method and it works perfectly.
Test setup:
-Piece of paper illuminated by iPhone flashlight
-Nikon D800 with 600mm f/9 lens fitted
Method:
-I put the white paper on the ground (room lights off) and pointed the iPhone flashlight at the paper at close range.
-Next I set up the camera across the room on a tripod and focused.
-I took 2 exposures- one at 1/800th sec and one at 1/1600th sec (both f/9 aperature @ 6400 iso / gain)
-Then I put the lens cap & took 2 more exposures (dark frames), again at 1/800th sec & 1/1600th sec
-Next I imported the unmodified RAW files into the computer application RAWDigger
-Next I selected an area of interest (100x100 pixels) at the center of the image which shows part of the sheet of white paper
-Next I made note of the R AVG values within the area of interest in both the light frames and the dark frames
-After subtracting the noise R AVG/px measured in the area of interest in the dark frames from the R AVG/px measured in the area of interest in the light frames (using the same method I used previously), the 1/800th second exposure R average was exactly 2.00x higher than the 1/1600th second exposure.
1/800th Dark Noise Avg 15.6
Light R Avg 199.6
199.6 - 15.6 = 184.0
1/1600th Dark Noise Avg 18.1
Light R Avg 110.1
110.1 - 18.1 = 92.0
184/92 = 2.00x higher
Screenshot of the RawDigger application showing a nearly black raw image from a Nikon D800 with a small faint grey square at the centre, and per-channel statistics panels.
Screenshot of the RawDigger application window showing DSC_9455.NEF from a Nikon D800, with a mostly black image preview and a 100x100 pixel area of interest marked at the center.
Screenshot of the RawDigger application showing a dark, mostly black RAW image from a Nikon D800 with a 100x100 pixel selection marked at the center, alongside channel statistics and display controls.
Screenshot of the RawDigger application showing a dark, mostly black RAW image from a Nikon D800 with statistics panels listing min, max and average values for R, G and B channels.
Photo of a Nikon D800 camera with a long black telephoto lens and a dark carrying strap draped over it, resting on a dark table beside a white box labeled 4K action camera.
Your method is flawed and there is a very good reason it appears to work in this situation but will not work on a real astro photo, but I leave that to you to discover, as you don't appear to want my assistance or advice.
@Drakkith I do want your assistance & advice. I was just testing the error bars on the camera to the best of my abilities.
Forgive me if I'm a bit snippy. I've had a rough couple of days.
First, I don't understand why you're doing anything with noise. Why are you subtracting the average noise value? What does that accomplish?
Good clean derivation:
http://lampx.tugraz.at/~hadley/physikm/apps/2single_slit.en.php
The noise gets rectified and so produces part of the DC offset. A false DC offset in a ratio is a bad thing.
So I think the averaging should be OK for the offset but I do not understand why OP does not look at the pixel by pixel ratios which may indicate why OP results seem junk. Use all the data you have. Can you scale and subtract images in your software?
Also why do the full frame shots above indicate saturated pixels? Are they just "bad" pixels?
I managed to do a comparison between @collinsmark 's measurements and my own.
I looked at just the 1st order maxima (not to be confused with the 0th order maxima) with the single slit and the same region with the double slit in both @collinsmark 's data and my own.
I'm satisfied the results seem consistent twice as many photons with the double slit in the same area where the 1st maxima forms with a single slit.
Two grouped bar charts of average ADU per pixel: left shows single slit measurement about 115, single slit x2 about 230, double slit about 211; right shows single slit about 90, single slit x2 about 180, double slit about 181.
Devin-M's measurements:
Single Noise R Avg 39.2
Single Light R Avg 128.8
128.8 - 39.2 = 89.6
Double Noise R Avg 37.1
Double Light R Avg 218.5
218.5-37.1 = 181.4
181.4 / 89.6 = 2.02x higher
Dark raw camera image showing a faint elongated bright streak with a small red rectangular selection box above it, with an info panel of pixel statistics at the top.
Raw Nikon D800 image in dark mode showing a faint vertical elongated bright spot with a red rectangular selection box at left; image statistics panels overlay the top.
Dark raw camera screenshot of a double slit light pattern with a red rectangular selection box at the upper centre and a vertical column of bright spots.
Dark raw image viewer screenshot showing a vertical column of bright spots with a red rectangular selection box to the left, with image statistics panels at the top.
@collinsmark 's measurements:
Single Slit Avg ADU/px = 115.2
Double Slit Avg ADU/px = 210.9
210.9/115.2 = 1.83x higher
Screenshot of a single row of pixel values rendered as a grayscale intensity profile, brightest at centre and fading to dark at each end, with a table of numeric values below in a spreadsheet.
Screenshot of Srk-1.0 image software showing a black and white image with two blurred bright bands, and below it a spreadsheet table of numeric values in columns labelled H through R.
What is the definition of 'noise' here? My understanding is that noise is the random variation in the pixels that scales as the square root of the signal.
I suspect the slight discrepancy between @collinsmark ’s measurement and mine is his noise subtraction would remove dark current and read noise but the way I subtracted noise would be expected to remove read noise, dark current and the potential background sky glow from light pollution.
For example if some “sky glow” ADUs were removed from @collinsmark ‘s measurements of both the single & double slits, it could result in his measurement for the double slit being even closer to 2.00x higher (his reading was 1.83x, mine 2.02x).
For example if the single slit ADU/px was (for example) 60 and the double slit was 110, and 10 ADU/px was background sky glow, and we subtract 10 ADU/px from each, we go from 110/60=1.83x to exactly 100/50=2.00x.
Edit: nevermind, it probably doesn’t account for the discrepency because noise from the background sky glow would be expected to double with the double slit, so the math wouldn’t work out.
@collinsmark The only other uncertainty I have… when you cropped those TIF files, perhaps in photoshop, did they possibly pick up a sRGB or Adobe RGB gamma curve?
I believe simply saving a TIF in photoshop with either an sRGB or Adobe RGB color profile will non-linearize the data by applying a gamma curve. This doesn’t apply to RAW files. (see below)
https://community.adobe.com/t5/camera-raw-ideas/p-output-linear-tiffs/idc-p/12464761
Line graph titled Gamma-Corrected vs. Linear Values, with both axes from 0 to 1, showing two nearly overlapping concave curves labelled sRGB (blue) and Adobe RGB (1998) (red) rising steeply near zero.
Three horizontal grayscale gradient bars labelled Linear RGB, sRGB and Adobe RGB (1998), each fading from black on the left to white on the right.
Source: https://www.mathworks.com/help/images/ref/lin2rgb.html
