Does ΔPΔX = ΔEΔT? Solving the Uncertainty Principle
  • Level: Undergrad
  • Thread starter mike1000
44 replies · 5K views · last reply
mike1000
Does ΔPΔX = ΔEΔT?
From the Uncertainty Principle we know that ΔPΔX ≥ hbar/2 and ΔEΔT ≥ hbar/2. I know it is an inequality and not an identity. However, when I do the math it appears to me that ΔPΔX = ΔEΔT. Taking the limits it appears to me that it leads to the differential equation dP/dt = dE/dx, or in other words, the time derivative of momentum equals the space derivative of energy, which I think is correct.
mike1000 said:
Does ΔPΔX = ΔEΔT?
The relation of identity can not be written as well. These are two distinct equations that must be distinguished not there is an equality
On the derivation of one from the other we say that the way how you obtained is not very strict, although not foolish. Physicists use mathematics with a certain ease (and do well) but be careful not to overdo it!
Demystifier said:
Due to the inequality you have written down, it does not make sense to consider the infinitesimal limit. ΔPΔX is not equal to ΔEΔT.
Why not?
mike1000 said:
Does ΔPΔX = ΔEΔT?
Let me try it a different way.
Lets ASSUME that it is true and you can take the limits. If we do, we get the differential equation ∂P/∂t = ∂E/∂x. In words, it is saying that the time derivative of momentum equals the space derivative of energy. Is that false?
Demystifier said:
Why not what? I had two negations.
Please see my immediately previous post.
mike1000 said:
Why can't you take the limits because it is an inequality?
Because in the infinitesimal limit ##\Delta p\Delta x=0##, and ##0## is not larger or equal than ##\hbar/2##.
While I absolutely love your logic, the same logic is true for ΔE and ΔT. ħ is not really involved in the equation I have written down.
Demystifier said:
This only reinforces my argument.
I don't think so. Nothing you have stated says they cannot be equal to each other.
mike1000 said:
Does ΔPΔX = ΔEΔT?
How are ##\Delta P, \Delta X, \Delta E, \Delta T## defined here?
Think of ##\Delta## as meaning something like a standard deviation. The uncertainty principle tells us that if ##\Delta X \rightarrow 0## then ##\Delta P## blows up. So you cannot make them both infinitesimal simultaneously. This does not mean that the standard deviations cannot obey the relation ##\Delta P/\Delta T = \Delta E/\Delta X##. But there is no corresponding relationship for the derivatives.
What's a standard deviation of time?
Depends on context. Standard deviation of decay times would be one well-known example.
How would decay times be related to the position and momentum of a particle?
https://lh3.googleusercontent.com/HrcUajVIBZL6SbnxV7ZXSh_yckMegKNZYk9_Z_ut4QrR-UIIW8OR96Bjqcr0bwt3e7_3lMdKWGbPsvDS_Kj26_Xa5TDipG_dOrl2CV3223CD02hJZHDzDTIv-CldsoblcYrD2xGTr9Yblag_GqGR_0G9O48HAHKkmUTDALIKZs3qyI8SKxG6J3dhXaNUHqeQO2PPbtn1DmKLO_7n7Y1-J5fI6ZolbBzIkO0iXMRQOj3vIsS485bSAR-muLhExqiuiRGu_a5q3snjHwOK01ZaqGKKCffHHj__0GNmH08MdoMB5Tfj2lDuKa8_OO3uP55aTEq-okRoo7Oac5s5GSbmtaYoorWSPOsRGEfpfZDk4ZjJsp3ZorzHBNn9twqzQBh157tsiOd7A8xOoqE5w86kyRKkYRGlGcnHn3bGVE9brISS2IewLokU7D-y2ZcI9s6V5RoMDfd-lW9KJ3Y3EuGsbUP1tTbkM_TGvITtJ1wrho1H9IiQKiiWIU_MmyGIrc3FbJZSNTVakHo1gafMML25opeiiRs3Fwdz9hzhmzBZ5GjOPp8uTLSZme8WM7KrIeJu06IY1ZJel1hDVC3kBk6h4HOfrxUdGmpdal3mH_Be0Xbk1vLY0v3Y=w133-h114-no
The image shows Hamiltons equations. I am only concerned with the top equation. The top equation states that the time derivative of the momentum is equal to the negative of the space derivative of the total energy.
If we ASSUME that the equality I stated in my first post is true and we ASSUME we can take limits, we get a differential equation, ∂P/∂t = ∂E/∂x, that is almost identical to Hamiltons first equation. They only differ by the presence of a minus sign, which could be accounted for by an i2
A decaying particle can be described in either energy-momentum space or co-ordinate space-time. As you well know, the uncertainty principle is a way of describing the limitations of doing both at once. Your question is about whether we can measure standard deviations in both descriptions for i.i.d. systems and I see no reason why, in principle, we cannot.
Consider a resonance in a scattering experiment. We know that the "lifetime" of the resonance is inversely related to the width in the energy of the resonance. Likewise the uncertainty in position at which the collision occurs can be related to the uncertainty in net momentum of the system. The fact that we idealize scattering experiments as viewed in the CM frame does not in any way contradict the reality that in any real repeatable scattering experiment there are standard deviations to both the location and net momentum of the collision, regardless of whether or not they are ever measured.
But we should not take any of this as particularly useful. I was merely trying to help the OP understand the mathematical limitations of what he was proposing.
I think you guys are getting off topic.
What does it mean when we take the limit as it approaches 0 of a variance? It means there is no variance. It means we know the momentum exactly and the position exactly and the energy exactly and the time exactly. Looked at it that way, all that we are doing when we take the differentials is converting the equation into a classical equation. And when we do that we find that the resulting differential equation is equal to the top Hamiltonian equation except for a factor of -1 (i2 )
But that's my second negation. You said that you ask about my first negation.
Concerning the second negation, nobody said that they cannot be equal to each other. They can. But they don't must to. Your argument that they must is wrong, because in this argument you use an illegitimate limit.
These two equations have a very different footing. Only the first one comes from uncertainty principle, i.e., from the non-commutation of two observables. That is not the case for the second one, since there is no observable corresponding to time in QM. Time is a parameter.
It is true but... rate of change of momentum is equal to the applied force (Newton2). Path integral of scalar product of force and distance equals work done and energy is the capacity to do work. Hey presto classical mechanics. The Heisenberg uncertainty products tell you that zeros in the equations are not permitted. The classical mechanics says that they are permitted. Getting rid of the ≥½hbar just takes you out of the realm of quantum mechanics.
In my previous post I focused on the top Hamiltonian equation and showed that the ASSUMPTION leads to a differential equation that confirms, except for the minus sign, the top Hamiltonian equation.
I now show that the ASSUMPTION leads to a second differential equation that confirms, exactly, the second Hamiltonian equation...
If we assume ΔPΔX = ΔEΔT and take limits we can rearrange the resulting differential equation into the following alternative, (but equivalent) form...
dx/dt = dE/dp,
which is equivalent to the second Hamiltonian equation shown in the image.
dx/dt = dE/dp,
You should read post #23. The terms here are not consistently defined. In fact, you can derive your equation simply. Using your style and defining nothing precisely we have:
##E = \frac{p^2}{2m} + V##
##\frac{dE}{dp} = \frac{p}{m} = \frac{dx}{dt}##
##dE dt = dp dx##
##\Delta E \Delta t = \Delta p \Delta x \ge \frac{\hbar}{2}##
Exercise: How many flaws can you find in that argument?
##dE dt = dp dx##
I was not trying to derive the equation, I was trying to figure out if the equality I stated in the first post is true. The fact that the logic I used lead to Hamiltons equations lead me to believe that it may be true.
As I worked with this, and realized that the Uncertainty Principle is using statistical standard deviations and not deltas as in differential calculus, it actually did become clear to me that as we take the limit of the standard deviations as they go to zero, the equation describes behavior in the world of Classical Physics, where there is no uncertainty in the measurements of the parameters. The fact that the Uncertainty Principle can lead to the kinematic equations that describe Classical motion I find wonderfully consistent.
If the quantities on opposite sides of an equation have the same units and can be the same numerically it doesn't follow that they must represent the same thing. As an example an energy of 100Nm is not the same as a torque of 100Nm.
I never said that nor did I assume it. That was not the motivation to ask the question ... Are they equal?
mike1000 said:
I wasn't trying to derive the equation, I am trying to figure out if the equality that I suspect to be trueI was not trying to derive the equation, I was trying to figure out if the equality I stated in the first post is true. The fact that the logic I used lead to Hamiltons equations lead me to believe that it may be true.
First, you cannot prove or justify something by showing that it leads to a known equation. Second, surely it's much better to derive the equation (as I have done), rather than assume it is true?
Third, the point that you are missing entirely, is that your equation mixes and matches quantities and terminology. You are only able to persist with your analysis because you have failed to define or recognise what ##\Delta## even means. Your analysis, as is my derivation of your equation, is physically meaningless symbolic manipulation, I'm sorry to say.
You even admit yourself that one of Hamilton's equations emerges but the other has the wrong sign.
