Does dropping a Jupiter from the Pisa tower still accelerate at g = 9.81?
In summary, the acceleration of the Earth due to gravity is independent from the mass of the object dropped.
DuctTapePro
im confused about this thing, because they said Earth's acceleration due to gravity is independent from the mass of the thing dropped
If Jupiter were the size of a basketball (it must remain external to all of the mass of earth) then yes. Of course someone would need to carry it up the tower: the structural engineering is suspect...
The acceleration of the Jupiter will be 9.81 m/sec^2, however the acceleration of the Earth will be 3159.15 m/sec^2 ( assuming we are talking about a small object with the a 1 Jupiter mass which is the only way its center mass mass could be Pisa Tower distance from the surface of the Earth. )
Anytime you drop an object, their closing rate will be due to both the object's acceleration towards the Earth due the Gravitational attraction, and the Earth acceleration. The force acting on both will be equal, but in everyday circumstances, the Earth's acceleration will be negligible.
For example, if you drop a 1 kg weight, the force accelerating it is 9.81 Newtons, yielding an acceleration of 9.81 m/sec^2. The Earth feels that same force, but with a mass of ~6e24 kg, this only produces an acceleration of 1.635e-24 m/sec^2. if we increase the weight to 10 kg, it stills accelerates at 9.81 m/sec^2, and the Earth's acceleration increases to 1.635e-23 m/sec^2. Even though this is 10 times as much it is still immeasurably small compared to 9.81 m/sec.
Of course, the tidal forces from a basketball sized Jupiter would be quite devastating. That's 3159 meters per second squared at the Earth's center, some 6000 kilometers away. Locally at a range of perhaps 6 meters, we are talking about an acceleration that is higher by a factor of a trillion (1012).
[The above is a Newtonian calculation. Jupiter's Schwarzschild radius is 2.82 meters. So basketball sized is a bit less than is feasible]
Likes jim mcnamara, hutchphd and PeroK
Normally, if you are talking about dropping an object, you are talking about an object that is very small compared to the Earth.
Your example could better be described as dropping Earth towards Jupiter.
But, really, it's a collision between two planets. As others have said, if the planets somehow start at rest relative to each other and very close, then sure enough Jupiter will accelerate at Earth surface ##g## and the Earth will accelerate at the Jupiter surface gravity ##g_J##.
Although, actually you would also need to take into account the physical size of the planets. Jupiter's centre of mass would be a long way from the surface of the Earth.
@Janus provided a very good answer, but I would like to clarity that Jupiter will not accelerate at 9.81 m/s2 with respect to the Earth's surface. From the point of view of the tower, it would appear to accelerate much faster.
Likes hutchphd
ohh thanks for the replies.. i had an internet black out so i haven't been online for days... so.. independence from the mass of the second object isn't really true... it's just negligible... i get it now, thank you :)
That depends on your frame of reference. In Newtonian physics the object always accelerates at 9.81ms-2 according to an inertial observer. How fast the Earth accelerates varies, and is completely negligible in realistic scenarios, yes.
So if you use an inertial frame the acceleration is constant; if you use the Earth's surface frame it varies.
I think you may misunderstand...it is exactly true, but there are host of additional things you may also need to consider.
Likes PeroK
If the object is large, then its centre of mass is not near the Earth's surface. Jupiter would never get close enough to accelerate at ##g##.
Likes Ibix
True. I should say that all objects will accelerate at the same rate depending on the altitude of their centre of mass (per a Newtonian inertial frame). For small objects near the surface of the Earth, thus is 9.81ms-2. Large objects can't get that close, as you say.
To be pedantic, what matters is their center of gravity in the non-uniform gravitational field of the Earth.
Likes hutchphd and Ibix
But when each object is spherically symmetric there is no difference, yes?.
Right you are.
To continue the pedantry, neither Earth nor Jupiter are rigid spheres. They are both "planets". Which, by definition, means they are not rigid.
jbriggs444 said:
Right you are.
Sir, you have taken pedantry to a new extremum.. ...I confess ambivalence as to the direction traveled.
Likes jbriggs444
1. What is the significance of dropping a Jupiter from the Pisa tower?
Dropping a Jupiter from the Pisa tower is a thought experiment that helps us understand the concept of acceleration due to gravity and its relationship with mass and distance.
2. Will the Jupiter accelerate at the same rate as an object with a smaller mass?
Yes, according to Newton's law of universal gravitation, all objects experience the same acceleration due to gravity regardless of their mass.
3. Why is the acceleration due to gravity on Earth equal to 9.81 m/s²?
This value is a result of the Earth's mass and radius, as well as the universal gravitational constant. It is a constant value that applies to all objects near the Earth's surface.
4. How does the distance from the Earth's surface affect the acceleration due to gravity?
The further an object is from the Earth's surface, the weaker the gravitational force and therefore the lower the acceleration due to gravity. This relationship follows an inverse square law.
5. Is it possible to drop a Jupiter from the Pisa tower in reality?
No, it is not possible to drop a Jupiter from the Pisa tower as Jupiter is a gas giant with a mass much larger than the Earth's. Additionally, the Pisa tower is not tall enough to reach Jupiter's surface.
