High School Does ionization change velocity of ion?
Ionizing 1 mol of nitrogen with 1402 kJ of energy will change the velocity of the ionized atoms, as the ionization process imparts kinetic energy to both the electron and the remaining atom, with the electron receiving significantly more energy. This energy transfer can subsequently heat the gas, affecting its overall temperature. The extent of heating and ionization depends on how the energy is introduced into the system. For calculating changes in velocity post-ionization, conservation of energy and momentum principles apply, though specific formulas will depend on the details of the ionization process. Understanding these dynamics is crucial for accurate predictions of behavior in ionized gases.
Intle
If I add 1402kJ of energy to 1 mol of Nitrogen I will ionize it, as I understand it. So when I ionize it, will it actually change the velocity of the ionized atom? What about the overall temperature of the gas?
Atomar nitrogen gas, where you magically prevent the formation of molecules? You'll both heat it and ionize some fraction of the molecules. The relative magnitude of those effects will depend on the way you put that energy into the system.
An ionization process typically gives kinetic energy to both the electron and the remaining atom, but the electron gets much more energy. It can transfer this energy to other particles afterwards, heating the gas.
I see. I asked in an earlier question what an easy gas would be to ionize and to get, and I was recommended air which is primarily composed of nitrogen and oxygen but never mind, on further research I see that it actually forms bonds with itself, so you are correct. Sorry about that. However, in fact I am more interested in calculating this change in velocity for ions directly after ionization. Is there a formula I can use?
Conservation of energy and momentum. The details depend on details of the ionization process.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 49 ·
