Can Light Accelerate When Changing Direction?
  • Thread starter Thread starter Lunct
    Accelerate Light
Light maintains a constant speed in a vacuum but can appear to accelerate when changing direction, particularly when passing through varying densities, such as in the Brachistochrone curve scenario. In a rotating reference frame, light can exhibit coordinate acceleration, which complicates its behavior. The discussion touches on the concept of momentum conservation, suggesting that the deflection of light by a prism could be measurable in terms of force. A thought experiment involving the weight change of a prism when light is turned on or off is mentioned, highlighting the complexities of light's interaction with matter. Overall, the conversation explores the nuances of light's behavior under different conditions and frames of reference.
Lunct
I know that light is always at constant speed but does it ever accelerate when changing direction, if you put light through lots of different densities it curves into the Brachistochrone curve, would that be an instance of light acceleration.
Likes ISamson
Science news on Phys.org
In vacuum.
I guess you can call that acceleration, yes.
You can get a speed that changes continuously if you send it through a variable medium, e.g. through the atmosphere vertically (as the speed of light at sea level pressure is lower than the speed of light higher up).
In a rotating reference frame light does accelerate in a vacuum
Coordinate acceleration ... You might as well say it does not have constant speed.
Likes Dale
Yes
I recall someone posted a homework question that went something like...
A beam of light is bent by a prism mounted on sensitive weighing scales. Calculate the apparent change in weight when the light is turned on/off.
That's certainly a valid thought experiment. Momentum will be conserved.
With angular momentum, it is a real experiment (with a different focus, however).
The force from deflection in a prism should be measurable as well, but I'm not aware of specific experiments.
  • · Replies 19 ·
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 40 ·
16K
  • · Replies 52 ·
13K
