Does lightening cause a form of cavitation?
  • Thread starter Thread starter THORPE
    Cause Form
Lightning does not cause cavitation in air in the traditional sense, as cavitation typically requires a liquid to form bubbles. Instead, lightning rapidly heats the air to plasma temperatures, resulting in a quick expansion and subsequent cooling that generates a shock wave, heard as thunder. The process involves a rapid increase in pressure and expansion of gas molecules, which differs from the bubble formation seen in fluid cavitation. While there are similarities in rapid expansion and collapse, the mechanisms and environments are distinct. Understanding these differences clarifies the nature of thunder and the effects of lightning on the atmosphere.
THORPE
Does lightning cause cavitation of air much like in a normal fluid?
It moves through the air so fast it has the same effect and then we hear thunder as a result?
Science news on Phys.org
Cavitation is the creation of bubbles that release energy when they pop. I don't think just air can form bubbles by itself, it would need a liquid to contain it. The lightning is ionizing the air and heating it to a plasma. I don't know if there are such thing as plasma bubbles and so I don't know the answer to your question.
Dragon is correct, that this cannot be cavitation the way we normally understand the term. But it is something similar. With such rapid heating of the air, you have very rapid expansion. That is followed by very rapid cooling and a collapse of the air back to something close to its original volume. This is what makes the noise.
In cavitation, you have a rapid expansion of a gas bubble, followed very quickly by its collapse. Similar, but different.
From Wikipedia:
"Because the electrostatic discharge of terrestrial lightning superheats the air to plasma temperatures along the length of the discharge channel in a short duration, kinetic theory dictates gaseous molecules undergo a rapid increase in pressure and thus expand outward from the lightning creating a shock wave audible as thunder. Since the sound waves propagate, not from a single point source, but along the length of the lightning's path, the sound origin's varying distances from the observer can generate a rolling or rumbling effect."
http://en.wikipedia.org/wiki/Lightning
Cavitation in fluids is quite different from lightning. You may Google it to learn more.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
