Speady said:
If you are going to write out numbers like this, use standard form. Then you are less likely to make mistakes like the above - it should be 600nm, or 6×10
-7m.
Speady said:
By accounting for the motion of the receiver or source. In the frame where the source is at rest, the satellites are moving. It should not be surprising that the time during which the receivers are illuminated is different from the emission time - you are quite literally moving the goal posts. And since you are moving the goalposts it would be a mistake to simply multiply that time by the wave speed and hope to get the pulse length. (Consider doing this with sound and a receiver moving at the speed of sound. The receiver will always be in the pulse - do you conclude that the pulse is infinitely long?)
In the frames where the satellites are at rest, on the other hand, the source is moving. Now you can use the satellite clocks to measure the pulse length in this frame and it will, indeed, be different from the length measured in the other frame. But this should not be surprising because of the movement of the source - the pulse will be shortened or lengthened by the Doppler factor (not the Lorentz factor), as expected.
If you cannot see this, you need to do the calculation properly. In some frame (probably the rest frame of the source), write down the coordinates of the events of the start and end of pulse emission and the equations of motion of the leading and trailing edges of the pulse. Then write down the equation of motion of the receiver and determine the coordinates of the start and end of pulse reception. Then Lorentz transform the coordinates into the frame where the receiver is at rest. This will allow you to calculate the pulse length and duration of illumination in either frame. You can also take the limit ##v\ll c## if you want.
Do you understand my explanation? If not, do you know how to do the above calculation?
