Does Relativistic Speed Affect Mechanical Watch Oscillation?
84 replies · 8K views
Dale said:
Did you miss my response? There is no additional force involved. It arises naturally from a relativistic generalization of Hooke’s law and Newton’s laws
Yes I know there is no force, I just call it "force" to enlarging my wonder...
so conclusion is that in frame of watch tick rate is normal and in frame that moving compare to clock, tick rate is slower, or we can say appear to tick slower ?
What's the difference?
I don't know, usualy when you say tick slower that mean it is real and when you say appear that mean it is not real just apper ti be real.
Maybe same as centrifugal force appear in frame of car in turn but we know that this force don't exist?
So basicly all this come from the phenomenon that speed of light is allways 300 000km/h in any frame you choose?
So now I don’t understand what your question is. You asked about a mysterious other force but you already know that there is no force. So please try to write your question again, but clearly this time. Don’t ask about a force that you know doesn’t exist. Ask your actual question, please.
My question was ,first does watch tick slower and then if answer is yes, explain how constant speed can slow down blance wheel oscilation,because to make wacth to tick slower you must change balance wheel oscilation..
OK, this is the part that I answered already:
Mechanical watches are usually designed using Hooke’s law and Newton’s laws. Neither of those are relativistic in their usual form. If you generalize Hooke’s law and Newton’s laws to their relativistic forms then you naturally get that mechanical watches exhibit time dilation as normal. In other words, it is not any additional force, it is just how the usual forces actually work at high speeds.
What does "real" mean? What's the difference between "real" and "appear to be real"?
Bear in mind that this is a physics forum, not a philosophy forum. Terms like "real" and "appear to be real" cannot just be thrown around. You have to be able to relate them somehow to the physics that is being discussed. If you can't, then questions involving those terms are meaningless as far as physics is concerned.
That's why I stick closely to things that are observed.
This is rather meaningless. What we can meaningfully say is the following:
If we have an inertial lattice of Einstein-synchronized watches and an identical watch that is moving inertially with respect to the lattice, then the time shown on the moving watch will tick slower than the time shown on the lattice watches as the moving watch passes each lattice watch.
Rather than say "tick slower", since that is the phrase that appears to be causing confusion, it might be better to rephrase this as: "the moving watch will show less elapsed time between passing two successive lattice watches than the difference of the times shown on the two lattice watches". That states the invariant observable fact without making any claims about how, or even whether, this fact relates to "tick rates" of clocks.
In the lattice rest frame, the simple way to account for the fact just described is that the moving watch is ticking slower than the lattice watches due to time dilation.
In the moving watch's frame, the simple way to account for the fact just described is that the lattice watches are desynchronized by an amount that more than compensates for the fact that the lattice watches are ticking slower than the moving watch due to time dilation.
However, neither of those frame-dependent explanations is necessary; one can always describe things entirely in terms of invariants, in this case the invariant lengths of the appropriate segments of timelike worldlines.
Imagine three observers measuring the time shown on a watch. One observer remains at rest relative to the watch and the observers move at different speeds relative to the watch. Now, all three observers measure the watch ticking at different rates.
As far as the watch is concerned nothing has changed. It can't know it's being observed and can't physically be going at three different rates at the same time. The observed time dilation must be a non-physical effect, caused by the geometry of spacetime and not by mechanical interefence with the watch's mechanism.
"The rate at which the watches tick is the same. The number of ticks is different, because one watch experiences a longer elapsed time than the other"
How would you explain these words, is this correct?
Where do those words come from?
What does it mean?Is this correct?
As with most statements that don’t explicitly describe an experiment, you can interpret it in a way to refer to a correct experiment or an incorrect experiment. In particular, here the phrase “rate at which the watches tick” can be interpreted as different experiments.
1) measure the rate at which the watch ticks by comparing it to an atomic clock that is at all times co-located with the watch.
2) measure the rate at which the watch ticks by using an inertial lattice of Einstein-synchronized atomic clocks and at each moment comparing the watch time to the time of the momentarily co-located atomic clock.
Then “the rate at which the watches tick is the same” is true for 1) and false for 2).
Those words are (with appropriate context and supporting commentary) a reasonable informal explanation of the twin paradox.
They are (at least in my opinion) far less helpful in understanding time dilation, the topic of this thread.
What is difference between my topic and two clocks in twin paradox?
You are asking about time dilation. The twin paradox is about differential ageing.
In twin paradox clock that was on rocket, when comes back to Earth , show less time than clock at earth.
Isnt this same question as my?
And how this can happened if both clocks can say " I am clock that is at rest" ?
No. It's not the same question. Time dilation is symmetric and motion is relative.
Differential ageing results from two objects taking different paths through spacetime. The length of a spacetime path is an invariant quantity.
It can happen because of the properties of Minkowski spacetime geometry.
If you want to discuss the twin paradox, you should open a new thread. But, unless you understand the basics of time dilation, then discussion of the twin paradox will be even more painful.
A clock whizzes past Bob. Bob says: "In my opinion that clock is moving. And in my opinion the balance wheel of that clock has extra rotational inertia. And in my opinion the spring constant of the spring connected to the balance wheel of that clock is extra small. And in my opinion that clock is ticking slowly."So according to Bob the clock is moving. And according to Bob the balance wheel of the clock has extra rotational inertia. And according to Bob the spring constant of the spring connected to the balance wheel of the clock is extra small. And according to Bob the clock is ticking slowly.In my opinion this is a correct way to speak.
In my opinion physics is about measurements and not opinions!
But different observers, different results.
Actually, no. The result of any actual experimental measurement is frame invariant. It is only the “explanation” that is frame variant, not the measured result.
Observer with watch see normal clock tick rate, observer moving in relation to clock see slower tick rate.
So we have two different results.
Isnt it?
Jurgen M said:
Different observers, different results.
Better is: different frames of reference, different measurements.
This has always been the case. We routinely talk about, say, a car having "stopped" at traffic lights. But, the surface of the Earth is rotating at about ##1000 km/h## and the Earth is orbitting the Sun at about ##30,000 m/s##. The car is only at rest relative to the surface of the Earth.
Also, we may consider a collision in the "lab" frame where one object is at rest and another object is moving towards it; and, in the centre of mass/zero momentum frame where the objects are moving with equal and opposite momenta towards each other.
Sometimes it's a problem even to convince students that motion is relative and that both the "lab" and "zero momentum" frames are valid reference frames in which Newton's laws hold.
And, if the student ovrecomes that hurdle and then starts to learn SR, there is then the intellectual hurdle that lengths, elapsed times and simultaneity are also frame-dependent. This is the point at which a lot more students have problems understanding modern physics.
Nevertheless, lengths, times between events and simultaneous events are frame dependent.
Isnt it?
No, we have two different experiments. Everyone agrees on the measurement results of each experiment.
That is why I insisted on describing the experiments above. If you don’t use “shortcut words” then it takes more effort to say things, but what you say is more clear.
“it takes a long time to say anything in Old Entish. And we never say anything unless it is worth taking a long time to say.” -Treebeard
I don't agree.
This is not two different experiments, it is same experiment just looked from different perspective/frame...
  • Skeptical
It is the same thing. Observer sit at origin of frame and obsreves what is going on with objects ...
Jurgen M said:
I don't agree.
Well, then what you say disagrees with the principle of relativity. The principle of relativity says that the same laws of physics apply in all inertial frames. The laws of physics are used to predict measurement results. So that implies that all frames must agree on the results of all measurements. Otherwise the predictions of some frames would be falsified by the actual measurement result.
It would help you greatly if you would start describing specific experiments and measurements. I think that you are getting confused by vague statements, both your own and from others.
