How Does Sound Travel on the Moon?
Sound cannot travel through the moon's thin atmosphere, which is essentially a vacuum, meaning you wouldn't hear sounds like a rocket explosion from a distance. However, sound can travel through solid materials, so if an astronaut is close by and stomping hard, their footsteps could be heard through the ground or through space suits. The sound would be perceived as vibrations rather than traditional auditory sound. Therefore, while distant sounds are inaudible, close sounds can be perceived under specific conditions. Understanding these principles highlights the unique acoustic environment on the moon.
Bipix
can we hear the sound of our steps in moon?
No.....
No, the helmet muffles the sound. :wink:
Our own steps? Potentially yes. If we wear a fully air filed rather rigid space suit.
Sound needs air or other material to travel through. It does not travel through vacuum. The moon's atmosphere is so thin that it is essentially a vacuum. Therefore sound will not travel directly through the atmosphere. However, the sound can still travel through the ground, space suits, and human bodies. So on the moon, you would not hear a rocket exploding a few hundred feet off the ground. But if you are standing on the moon's ground and a rocket crashed into the ground next to you, you would hear that. Because the sound would be traveling through the ground, you would perceive it as the ground rumbling. So you could hear a fellow astronaut stepping along the moon if you have good hearing, especially if he is right next to you and is stomping hard.
QFT. Nice answer.
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 17 ·
9K
  • · Replies 19 ·
