Does stacking magnets affect their weight on a scale?
  • Context: High School
  • Thread starter Thread starter sonofahb
    Magnet Scale
The discussion revolves around the effects of stacking magnets on a scale, specifically whether the weight measured would change if one magnet is floating above another due to repulsion. Participants explore the implications of magnet behavior, including pull and repulsive forces, and the concept of weight in relation to magnetic interactions.
  • One participant questions whether stacking two magnets with like poles would result in a scale reading of 1 gram or 2 grams, given that one magnet would be floating above the other.
  • Another participant argues that the scale would still read 2 grams because the bottom magnet supports the weight of the top magnet through an equal and opposite force.
  • Some participants express curiosity about the implications of the answer being 1 gram, suggesting extreme cases to test the logic of magnetic weight.
  • There is a discussion about the nature of magnetic forces, including pull and repulsive forces, with questions about whether these forces are equal and how they combine when multiple magnets are involved.
  • One participant explains that a magnet's pull force indicates the weight it can hold in contact, while the repulsive force behaves similarly but requires different arrangements.
  • Another participant emphasizes that the behavior of magnets in repulsion does not allow for easier movement without a supporting structure, referencing maglev technology.
Participants generally agree that the scale would read 2 grams when one magnet is floating above another. However, there is no consensus on the implications of this scenario or the nature of magnetic forces, as differing views on the behavior of magnets and their forces are presented.
Participants express uncertainty regarding the relationship between pull and repulsive forces, and whether the values of multiple magnets would add together in a repulsive arrangement. There are also limitations in understanding the effects of distance on magnetic forces.
This discussion may be of interest to individuals exploring the principles of magnetism, physics students, and those considering practical applications of magnets in various contexts.
sonofahb
I have a question concerning magnets.
Lets say i have 2 magnets each wieghing 1 gram each sitting on a scale. The scale reads 2 grams. What if i was able to stack the magnets by lining up the same poles so they repel each other and the magnet on top was floating over the magnet on the bottom. Would the scale still read 2 grams or 1 gram since the other magnet is floating over the one that's still sitting on the scale?
Thx :)
BTW i know this is a noob question so thanks for bearing with me. :)
It would still read 2 grams.
The top magnet is floating because the bottom magnet is pushing up on it with a force equal and opposite it's weight. For every action, there is and equal and opposite reaction, so the bottom magnet is pushed down by the floating magnet.
The bottom magnet is pushed into the scale with it's own weight (1g) combined with the top magnet's weight (1g).
Good question! Does my answer make sense?
Not a bad question at all. Sounds like something that would be fun to try..,
*Goes in search of magnets and scales*
Yes! Thank you for the reply. I thought it would be 2 grams and it kinda stinks because i had an idea if it the answer was one gram. Its still good to know however. If anyone else has anything to add id love to hear it. :)
What was your idea? It's okay if you just want to keep it to yourself, but if you don't care about it tell us, it sounds like it might be interesting.
If the answer was one gram, then why not make the floating magnet weigh 500 tons? The you could lift 500 tons just by lifting a gram.
The lesson is that we can often check our answers in physics by looking at extreme cases.
That really wasnt the question. If i use your analogy then i would be asking if the scale would wiegh 100k pounds and one gram.
The idea i had had to do with friction to the ground. Basically if an object was suspended in space, even if it is a huge massive object, it would almost be effortless to move. That is all i will say of my idea.
*sighs back to the drawing board* lol
You actually have a very good idea here. You will still have an equal and opposite reaction, ie the force on the ground, but if you have stationary magnets and attach repelling magnets above, you would be correct--it would only take force to accelerate the object. Look at bullet trains. Many are now using magnetic propulsion--the magnets alternate positive/negative down the track, attracting and repulsing the train (several dozen tons) above.
What good idea? I don't see it.
Maglev technology is well known and established. However, as pointed-out, it requires a continuing pathway sub-structure physically attached to the ground.
It is my hope that the OP does not assume that this can be done without that.
That is, a simple wheeled rolling cart with a magnet on the cart and repulsing a magnetic mass above it WILL NOT move easier than a cart containing the whole mass without magnets.
Yes I am fully aware now thank you for the reply. I have another question and i didnt want to do another post so here it goes.
Magnets are rated in strength by a value (pull force). Some of them are have a pull force of 550 lbs. what exactly does that mean? I am assuming it means that the magnet could suspend 550 lbs vertically?
Also I've looked around to find out if the repel force and pull force would be equal on a given magnet(ex. 550 pull=550 repel) and I've gotten differing answers. Maybe one of you know?
Finally let's say i have 2 magnets each with 225 lbs pull force. Would those values add? In other words would it be the same as having a single magnet that has 550 lbs pull force?
Im not trying to reinvent the wheel here lol. But i plan on buying some magnets off the net and id rather know what I am getting myself into before i order. :)
Again thank you all for your posts!
A magnet rated at 100/lbs "pull force" will hold in contact a 100/lb iron plate, and it will take approx. 100/lbs of force to "pull them apart"
If the two were an inch apart, for example, the value would be less, and if 1-foot apart practically non-existent with respect to suspending the iron plate or pulling them apart.
The repulsing force is quite similar, though involves a different arrangement.
In any event, the "repulsive" force could be considered similar to that of a metal spring. A spring rated at 550/lbs of compression will compress approx. to the point where all the coils are touching each other. Not exactly touching necessarily, but you get the point.
As such, 2 magnets in a repulsive arrangement has a maximum compressive load approx. equal to the load as if the two repulsive magnets were forced to come together, touching each other.
In other words, if you have 2 NIB magnets rated at 100/lbs pull force, and you orient them such to repel, it would take approx. 200/lbs of pressure to cause a face(N/N or S/S) contact.
I hope this makes any sense, as well as hoping I am correct.
great post! i will go off of this thank you.:)
i have another question and it kinda relates to this post... well kinda.
atmospheric pressure is caused by the wieght of the air in a column above us.(correct?) anyway when a plane or anything that flys through the air is suspended in the air does the atmospheric pressure go up due to the plane or whatever object is suspended in the air? even if the amount is almost immeasurable? or am i thinking of this incorrectly? thanks :)
In a sense you are most certainly correct.
Any object introduced into a pressurized environment will change that local environment.
To what extent it does change might be considered negligible or substantial, depending on many factors.
Perhaps someone else more educated could respond on the specifics.
Just draw a force diagram and you will see what the scale will show
  • · Replies 42 ·
  • · Replies 16 ·
10K
