Does This Lagrange's Equation for a Spring Pendulum Look Correct?
  • Thread starter Thread starter superpig10000
    Lagrange's equation
superpig10000
A pendulum consists of a mass m suspended by a massless spring with unextended length b and. spring constant k. Find Lagrange’s equations of motion
Here's how I set up my equation:
x = lsin(theta)
y = -lcos(theta)
(x=0 at equilibrium, y=0 at the point wehre the pendulum is hung from)
Kinetic energy = 1/2 * m * l^2 * (theta dot)^2
Potential energy = -mglcos(theta) + 1/2 kl^2
L = K - U
So after differentiating, I come up with:
theta double dot = w^2 sin (theta)
Does that look right to you?
I appreciate any help.
Can anyone help?
Since the mass is attached to a spring, the length l of the pendulum is not constant.
With Lagrangian problems you should always consider the degrees of freedom of the system and decide on which coordinates to use to decribe the configuration of the system. In this case the angle theta is a good choice. For the other the distance the spring is stretched from equilibrium seems like another good one, call it u. So the length of your pendulum is the rest length of the spring plus u. Then express L in terms of these variables.
Your kinetic energy is also missing a term.
heres how i would solve the problem:
T = kinetic energy
U = potential energy
L is the displacement of the mass along the spring
O is the angular displacement of the pendulum
T = m*(L_dot^2)/2 + m*(L^2)(O_dot^2)/2
U = m*g*L(1-cos(O)) + k*(L^2)/2
plug into Lagrange's equation for two equations of motion (generalized coordinates are L and O)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
