I Does ##x_\mu x^\mu## Equal ##(x_\mu)^2## in Einstein Notation?
Silviu
Hello! Does ##(x_\mu)^2## actually means ##x_\mu x^\mu## in Einstein notation?
Drop the book using the ##x_{\mu}^2##.
Likes Mgcini Keith Phuthi and fresh_42
So this means they are the same, but ##x_{\mu}^2## is bad notation?
@dextercioby is saying that ##(x_\mu)^2## is an illegal expression in differential geometry, analogous to asking what 1s + 1Hz is. It doesn't mean anything. Unless there's some context we're missing (for example Sean Carroll's lecture notes sstarts his discussion of EM with non-tensor all-lower index notation for Maxwell's equations before re-writing them in tensor form). Where did you see it?
Although I agree that it is really a bastard notation using this for ##g_{\mu\nu}x^\mu x^\nu##, I would not categorically advice to drop such a book. You will find that many physics papers use a similar notation in the kinetic term for a field, i.e., ##(\partial_\mu\phi)^2##. There really is only one thing that can mean and still be meaningful. Of course, the understanding of this is predicated on first having learned it properly ... In Schwartz's QFT book, he places all indices down with the initial statement that it should be subtextual that one should be considered contravariant and the other covariant.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
