Don't Understand Why I See Moving Pencils
  • Context: High School
  • Thread starter Thread starter Mozart
The discussion revolves around the phenomenon of visual perception when moving a pencil back and forth quickly. Participants explore the reasons behind the perception of seeing the pencil in multiple locations simultaneously, touching on concepts such as persistence of vision and the effects of screen refresh rates.
  • One participant expresses confusion about seeing the pencil in different places simultaneously and questions whether there is a delay in the eyes registering the image.
  • Another participant introduces the concept of persistence of vision, suggesting that an image stays in view slightly longer than the light is shining on the eye.
  • A participant mentions that the refresh rate of screens can create a "strobe" effect, making the pencil appear clearer at certain moments.
  • Some participants note that the human eye can only perceive a limited number of frames per second, which may contribute to the perception of motion.
  • There are references to other examples, such as the effect of waving a pencil in front of a screen or plucking a guitar string in front of a TV, to illustrate similar visual phenomena.
Participants present multiple competing views regarding the mechanisms behind the visual perception of motion, including persistence of vision, screen refresh rates, and the limitations of human visual perception. The discussion remains unresolved with no consensus reached.
Participants mention various factors that could influence visual perception, such as the type of lighting and the presence of screens, but these factors are not fully explored or agreed upon.
Mozart
So yeah I am sitting here, and I should be studying for my French test but I keep moving my pencil back and forth, and it is pissing me off that I don't understand why it appears as if I see the pencil in different places at the same time. <---that was a long sentence. Or actually that I see where the pencil used to be before...
So I can't imagine that there is a delay in the light traveling to my eyes because that's just ridiculous light travels way to fast. Is there a delay in the eyes registering the image, and sending it to the part of the brain where you see?
:confused:
Science news on Phys.org
:confused:
Yes, there is what is called the permanence of vision. An image stays in view slightly longer than the time for which light is actually shining on the eye. Actually, the lightbulbs in a normal room go on and off 120 time every second due to the alternating current they receive (they don't fully turn off in this short time, but they do turn off enough that the difference between the maximum and minimum illumination would be easily visible if they lasted longer. An LED can turn completely on and off 120 times a second and if you looked at it, it would just seem on) The time this takes is about 1/60 of a second.
Just like if I tapped a stick on the ground at a very high frequency I would hear a non stopping sound. Thanks.
Are you perhaps sitting in front of a television set while doing your homework? (A very bad idea by the way!) Or are you doing your homework on a computer? Because a television set, or computer, refreshes the screen at regular intervals, it sets up a "strobe" effect. If you wave your pencil in front of the screen, you get more light from the screen at that times. While you don't notice it normally, waving a pencil in front of the screen will cause you to see the pencil more clearly at those moment so instead of a "blur" you see the pencil itself at several different moments. That together with the "Persistance of Vision" LeonhardEuler explained makes it look like you are seeing more than one pencil at one time.
like with a fan, interesting point...
Haha, yes my computer was directly in front of me and my television was behind me.
http://www.aapt.org/Contests/pc05full.cfm?Meeting=sm05&Category=Contrived&Placing=42
Here is an interesting picture describing the same kind of thing.
:confused:
yes there's a delay, but there's also the problem of your eyes only being able to see about 60 frames per second, anything moving faster than that gives us a false perspective.
That reminds me. Have you ever tried plucking a guiter string or a string of a bow in front of a TV? You can actually see the waves rippling through the strings instead of the normal apparent back and forth motion you would see without the TV in the back.
Or under any fluorescent lighting?
It's more like 10 frames per second. Otherwise, movies, at 24fps, would look like a bunch of still images to us.
  • · Replies 172 ·
21K
  • · Replies 19 ·
20K
  • · Replies 30 ·
11K
  • · Replies 17 ·
