Doppler effect and frequency of the horn
The discussion revolves around the Doppler effect and how it relates to the frequency of sound perceived by an observer when both the observer and the source of sound are in motion. The original poster presents a scenario involving a horn with a known frequency and various possibilities for the perceived frequency based on their relative motions.
  • Participants explore different scenarios where the perceived frequency could be higher than the source frequency, questioning the implications of relative motion and direction. They discuss the relationship between pitch and frequency, and the conditions under which frequency changes are observed.
There is an active exploration of the options presented, with participants questioning the validity of certain choices and clarifying the concepts of speed versus velocity. Some guidance has been offered regarding the implications of relative motion on frequency perception, and multiple interpretations of the problem are being considered.
Participants are navigating the constraints of the problem, including the requirement to identify all correct answers from a list of options. There is an emphasis on understanding the nuances of the Doppler effect and the conditions that lead to different perceived frequencies.
Naldo6
John is listening to a horn. He knows the frequency of the horn is 300 Hz when both he and the horn are at rest. If he hears a pitch of 330 Hz, there are clearly several possibilities. (Give ALL correct answers, i.e., B, AC, BCD...)
A) Both can be moving and have the same speed.
B) Both can be moving and have different speeds.
C) John is moving towards the horn at rest.
D) The distance between John and the horn is increasing with time.
E) Both cannot be moving in the same direction.
F) Both can be moving, in opposite directions.
I select B,C,F and get the wrong answer... why?... can anyone help me?...
is the pitch inverse to the frecuecy or proportional?...
The pitch is proportional to frequency, so we want to have the cases where John hears a higher frequency than the actual frequency. When does that happen?
Imagine yourself standing right next to a moving train, does the horn sound high pitched when you are close to train or away from train. Just turn on some music and move your head towards and away from the source of music. You'll get your answer then.
And btw, frequency and wavelength are inversely proportional.
ok, when both are moving at the same speed, it can't be, but when moving with diferrent speed iti coulb be, when john is moving towards the horn the pitch is going to be going up so it could be, when the distance betwenn them is increasing the frequency is going down so it is not an option, when both are moving in the same or oposite direction it depends on their velocities right?...
so i know that the answer B and C are correct but i don't know if it is also the E or the F
Right then, notice that F implies D... if two bodies are moving in opposite directions, their distance must increase. As for E, chew on this... exactly what determines the frequency in the Doppler effect, relative velocity or direction of travel?
so the correect answer is BCE... right?..those are the three posibilities?...
May I ask for your justification for option E?
direction on travel... if the source and observer moves towards the frequency goes up but if the source and the observer go away the frequency decrease... right?...
Ah, I see where your confusion lies... actually it's not as simple as saying that it is determine by them moving towards each other or otherwise.
Doppler's effect is actually determined by the relative speeds of the source and listener. If the listener is approaching the source with respect to the frame of the source, then the frequency heard by the listener increases. This could happen in two cases... can you identify them?
i really don't understand... too much but my answer B and C are correct, but there is any other option that is correct too?... which is?...
B and C are definitely correct. If this is a web assignment, check the formatting for your initial answer B, C and F, which should be inputted as BCF. F can hold true, if the source and the listener are approaching each other (I made a mistake earlier regarding the F implying D, I'm so sorry). My answer would be BCF, then , your original answer, but if the formatting was correct, then try BC only.
i have tried BCF, BC, and give me the wrong answers... i also tried the BCEF and is still wrong.. it shuold have another posibility that we are not thinking about...
Oh dear, I think I finally got it. Option A says same SPEED. Yes, they can have the same speed but different velocities, i.e they can be moving towards each other at the same speed. I completely missed that point. ABCF... that should be it. I'm so sorry I missed that out completely.
ok thanks that was the correct answer but what is the diference betwenn speed and velocity?..
Speed is a scalar, meaning that it is only the magnitude, regardless of direction. Two objects may have the same speed but may move in two completely different directions, i.e. possibly towards each other or away from each other or any other combination.
Velocity is a vector, meaning that it has both magnitude and direction... Two objects of the same velocity must have the same speed and same direction, and their separation must be constant.
oh ok thanks...a lot
