Double iintegral (volume) this is redicuious
  • Thread starter Thread starter evilpostingmong
    Volume
11 replies · 2K views · last reply
evilpostingmong
Find the volume of the solid bounded by y=2 y=x and z=4-y^2
I DO NOT UNDERSTAND WHY I'M WRONG! limits of integration for x=2 to 0 limtis of integration for y=2 to x and 4-y^2 is the integrand I ended up with 4/3 but the answer (according to the answer sheet) is 4! WHY
I think your limits of integration are wrong
The area in the xy plane is a triangle. I can't really draw it but x doesn't go from 2 to 0 if I read your limits of integration right. Also, y isn't going to go from 2 to x either.
Wait I found it. limits for x are y to 0 and for y 2 to 0. If I went from 2 to x for y then that would be like integrating for x again, since the integral lines would be parallel to y.
I think that would work...however I believe y should go from 0 to 2 otherwise you might get a negative answer.Here's what I have:
[tex]\int^{2}_{0}[/tex][tex]\int^{2}_{x}4 - y^{2}dydx[/tex]
With that I integrate with respect to y first and then x.
Hi evilpostingmong! :smile:
I don't think well in 3D … :redface:
but that isn't bounded, is it? :confused:
Technically you're correct...I assume that they mean it's bounded by the axis planes...
hmm … I always assume someone copied the question wrong :wink: …
until I'm reassured! :smile:
If it's not bounded then...the volume is infinite if I am not mistaken.
It's alright, I did it out. I got 4 so these limits (x=y to x=0 and y=2 to y=0) are correct.
I appreciate the help, but the limits you put were the same as mine (the ones I put at the first post) which would net you 4/3.
Yes it is bounded by the xy plane.
Then I made a stupid mistake when I did the integral itself, which I'm known for, lol I just
did it my original way (the one that we thought was wrong) and yes it is 4. Ur rite.
One mistake I made was getting to a point where I had 16x/3 and not plugging in the 2 for the x and getting a 16/3 instead of a 32/3 which changes things.
