Double Slit Interference (nonzero slit width)
5 replies · 10K views
TOD
A mask with 2 slits is illuminated by a light of 589nm wavelength. Slits each have a 0.1mm width separated (centre to centre) by 3.0mm. Calculate the distance between adjacent bright fringes on the screen if a screen is placed 5.0m away from the slits.
Where
[tex]\beta[/tex]=2[tex]\pi[/tex]dsin[tex]\theta[/tex]/[tex]\lambda[/tex]
[tex]\phi[/tex]=2[tex]\pi[/tex]asin[tex]\theta[/tex]/[tex]\lambda[/tex]
d=slit separation
a=slit width
E=E(max)cos[tex]\frac{\phi}{2}[/tex]*([tex]\frac{sin(\beta/2)}{\beta/2}[/tex])
(sorry, no good with this latex stuff, some stuff not showing right)
First, I assume that if given a slit width of some size then we cannot assume that the interference comes from points sources. So to calculate the distance between adjacent bright fringes, I took on the formula for intensity and turned it into electric field of some form (just square rooted) and tried to differentiate the electric field and then find the roots of the equation. However I have found this extremely lengthy and most probably unnecessary. Can anyone get me started in the correct direction?
Treat the problem as the superposition of two diffraction patterns, one from each 0.1 mm slit. Where a bright fringe from one source occupies the same position as the other source's bright fringe this is a bright fringe of the double slit system.
TOD said:
Where
Looks like you have φ and β switched around here, given your expression for E below.
d=slit separation
a=slit width
Okay. And what must
cos(φ/2) = cos[π d sin(θ) / λ ]
be equal to, for a bright intensity fringe to occur?
Ah yes, my bad.
Okay. And what must
Plus or minus one? So I could in theory get that thing to equal 1, but that doesn't mean the product of this and the sine of a sine function is maximum does it?
Redbelly98 said:
Okay. And what must
TOD said:
Plus or minus one?
Yes, exactly.
That's a good question. The answer, in practice, is yes it does. Since measurements of fringe spacing are typically done near the central axis, where
sin(β/2) / (β/2) ≈ 1,​
the effect of the sin(β/2) term can be ignored.
Or put another way, the cos(φ/2) term oscillates many many times for each oscillation of the sin(β/2) term. This is because d and φ are much larger than a and β, respectively. (In the present case they are 30 times larger.)
Hope that helps.
Redbelly98 said:
Yes, exactly.
Hope that helps.
Very interesting. Thanks for the help.
