Double slit probability question
143 replies · 11K views
Ostrados said:
In you setup the wave function will not go in both slits it will collapse because the which path info is now revealed due to splitting the paths using a barrier (ex: if particle hits screen A then it came from slit A). Which is equivalent to measurment at slits in normal double slit experiement.
What I don't get, is how a measurement behind the slits can fix which path the particle must have travelled. This seems a bit retrocausal to me. But maybe it doesn't, for detecting a single particle does not reveal which slit has been passed, right? It is only the emergence of a interference pattern that reveals if both slits were taken, a single particle does not reveal that.
entropy1 said:
What difference it makes to use two sources instead of one, I can't assess, but it seems to complicate the matter by the possibility of having two particles entering the boxes simultaneously; I don't know if these particles (wavefunctions) blend into one.
I proposed to consider two sources in reply to your statement that "The electron goes through both slits."
My intention was to show that while your statement might seem strange but somewhat imaginable with single source, it becomes much more stranger when you consider interference from two sources.
For setup with no interference (like your two boxed screens) it does not add much, of course.
If you look at delayed choice experiement it is even more weird, it truley appears as retro causal. This is the main puzzle in QM nobody has answer to it.
However if you think about it from conservation of energy point of view, then you will discover that what is hapening is a natural thing to happen as a consquence of superposition. It is not easy to explain it but you can think about it that if you can detect the photon at both slits then you will have extra copy of the photon which violates conservation of energy.
DrClaude said:
We don't know. As far as we understand, the (quantum) world is truly random.
So, when choosing path A or Path B, the choice is truly random? The screens have a different spatial and temporal distance from the source. Which screen is the one that makes de decision to register the impact of the electron? Or: how does the electron 'choose' which slit to take?
In the pilot wave theory the randomness comes from not being able to control the initial conditions. There's cool diagram here of electron trajectories
https://en.wikipedia.org/wiki/De_Broglie–Bohm_theory
Screens don't make decisions, electrons don't choose. Why don't you quit trying to make this kind of mental image -- it really restricts you
  • So, the electron goes to setting A;
  • Or the electron destroys itself on something else before passing a slit;
  • Or the electron goes to setting B.
The probability ratios between these depend on the width of the slits in comparison to the size of the rest of the volume.
There is a formula to calculate the probability of every possible path. Which path will be taken is a matter of pure random chance.
Am I right?
I forget if I mentioned it before in the thread but before discussing the double slit plese read:
https://arxiv.org/abs/quant-ph/0703126
Once you understand the above - the question is - why do you think the particle has any properties other than what occurs at observations? Why does it have a path, why is it a wave - indeed anything at all other than something like probability of an observation if you were to do one.
Thanks
Bill
entropy1 said:
The electron goes through both slits. Why would it go through one slit?
Why would it go through any slit. You are thinking in terms of Feynman's sum over histories approach. Although not usually pointed out it is in fact an interpretation, but of a rather novel kind. But it is still an interpretation - you can't actually say anything apart from an actual observation.
The double slit is simply a demonstration of two important concepts in QM
1. The uncertainty principle
2. The practical application of the principle of superposition.
Thanks
Bill
entropy1 said:
Then after a while, the the electron could hit screen A. The probability is 50% that it actually does.
If the electron does not impact screen A, the probability it will impact screen B is 100%!
So, what does select which screen, A or B, will be hit? If it is collapse, why does screen A collapse the wavefunction 50% of the time, and when it doesn't, why does it collapse at screen B 100% of the time left? Or do both screens collapse 50% of the time and is there retrocausality from B to A? Or is there no collapse? Is there a non-local effect? Et cetera. Or is it just the way it is (do the math and so forth :wink: )
Which-way information is available, so there would be no interference. It has 50% probability of going through slit A, or 50% probability of going through slit B. But then again, screen A is closer than screen B, so... hmmm, interesting question!
At the risk of @entropy1 starting this thread from post #1 again:
robphy said:
One thing to consider is that many aspects of "modern physics" are not intuitively obvious
since they may occur at very small or very large scales, high speeds, or many particles (which may not behave like "everyday objects").
This famous lecture by Feynman seems appropriate here.
A fuller reference is below (with an interactive transcript).
This version on YouTube has the intro trimmed and gets right to the lecture.
A useful passage [at about 3m08s above, or 4m12s below]:
For more info on this series of lectures:
http://www.cornell.edu/video/richard-feynman-messenger-lecture-6-probability-uncertainty-quantum-mechanical-view-nature
To make this clear: I do not claim that photons or electrons behave like particles or waves at some point; I was just reacting to remarks from others in this thread. So I want to make clear once more what my question is:
Suppose you have a train moving along the railway track X, is passes a switch and ends up at some other track, say track A. Another train on track X passes the same switch and ends up at the alternative track, say track B.
The question would be: what determined on which track the train ends up. The answer would be obvious: the switch!
So, if a train sets off on X, we don't look at any switch, and we 'detect' that a train ended up on track A, what determined we would detect a train on track A rather than track B, or vice-versa? (We could not claim it was the switch)
I am sensing some annoyance over my question but I cannot tell why.
It's not the question, it's the anxiety about your mental image of a quantum particle :smile: and 'our' trouble shoving you in a particular direction. So just keep going ! You're not the first (witness the double slit threads in PF) and certainly won't be the last.
It turns out to be very difficult to provide assistance at the appropriate level -- appropriate in the sense that it really helps someone to adjust their conception of what's going on. The alleged "shut up and calculate" isn't very useful in this context (you don't want to calculate, you want to understand). But Feynman's lectures are.
It's because it's full of implied assumptions all of which are open to question eg you speak of a classical situation controlled by a switch - but in QM we don't have a path little alone anything that controls it.
You have tied yourself into logical knots and confusion by thinking classically - don't do that and your confusion will disappear. It's the hardest thing in the world to do - but to make progress in QM you must.
Have you read the paper I linked to?
Thanks
Bill
Disputed #2 also seems applicable to me in this thread! :biggrin:
I have downloaded it, but I can't read it overnight; my reading (and interpreting of what I read) capability is very limited currently. So, maybe later and thanks. :smile:
UPDATE: Reading it now. :smile:
We all have been through it. I walked around thinking about Schrödinger's cat, double slit, all the stuff that gets asked around here. Then the light slowly dawned and it was so simple - the classical world emerges from the quantum - you can't explain the structure the world is based on by appeals to intuition developed in that structure. Both Bohr and Einstein fell into that trap:
http://physicstoday.scitation.org/doi/pdf/10.1063/1.2155755
So don't feel silly, stupid or any other such response. Simply concentrate on avoiding classical analogies.
Thanks
Bill
If you replace 'train' by 'particle' (when produced or detected!), you have the quantum version of my question, it seems to me.
It was never my intention to draw classical analogies; if you look around this thread you may find I responded classical to classical questions of participants! :wink:
So, correct me if I'm wrong, I think you mean I should SUAC?
Hint: do I have to study states and wavefunctions to understand my question?
The math is fairly straightforward though I often can't see what the i and ħ and so on do. But I think I get the point.
It is a pity asking question about this (or any) paper is off topic. :wink:
back to the experiment. If I understand the question is, "as a guide mechanism of the electron on the screen" A ", rather than on screen B"? In the case of trains, the answer is: the switch. But in the case of trains there are the tracks, the railroad, in the electron case there is no track, this is where the crucial point, there is not even a "path" that leads to the screen by the electron source. There are not even "trajectories", in the classical sems of the term. Between the source and the two slits, one that propagates is only a wave. Wave of what? A Like it or not, is a wave of probability.
So, what 'makes' the probability 'collapse' to a detection? You could (would) say: random chance. Then, the total sum of probabilities in the wave would have to be 1, right?
And it has to keep having a total probability of 1 over the time it is evolving?
I don't like these answers, typical autoresponse in QM world, "dont think classicaly and confusion will disappear" is no better than saying "shut up and calculate"
The correct answer: nobody in the world knows, our understanding and knowledge are limited and our theories are incomplete .. period
You might not like these answers, but that doesn't make them wrong.
No, the correct answer is that the actual world does not behave the way your classical intuition says it ought to behave. Quantum mechanics is an experimentally verified theory within the domain we are discussing. We are not suggesting that you stop thinking classically because of some abstract notion. We are suggesting that you stop thinking classically because the actual world does not work classically. That's what our experiments in the quantum realm have shown us. So if you want to understand how the actual world works, you need to stop thinking classically.
It is true that our theories are incomplete; but that does not mean they contain zero information. We don't have complete knowledge, but we have enough knowledge to know that classical physics doesn't work.
probability wave and wave collapse are just part of the standard interpretation for QM not the ultimate truth. There are many other interpretations, if you want a classical interpreration that includes no superposition and no weirdness then look at Pilot Wave theory (however it has the concept of global non localty which is harder to digest)
There is big difference between one thing to be experimentally proven, and to be correctly interpreted. The problem is that we still have no complete satisfying classical or non-classical explanation.
Btw why cannot we have a non-classical explanation that makes sense? Is that too much to ask?!
What does "correctly interpreted" mean? Why do you need an interpretation? The theory already tells you how to make predictions, and the predictions are confirmed by experiment. What more do you want?
Because your criterion for "makes sense" is "makes sense to me given my existing intuitions". But by that criterion, General Relativity doesn't make sense--to anyone who learned Newtonian physics. Evolution doesn't make sense--to anyone who was taught creationism. And so on. Sometimes your existing intuitions simply don't apply, and you have to learn new ones. Then your definition of what "makes sense" changes. If you don't allow for that possibility, some things will never make sense to you.
Not exactly, what makes "collapse" the wave function, is the detection same!
while the probability of detect the electron at that point, is proportional to the square of the wave function at that point
Yes... before you make a measurement or observation.
I don't entirely understand this sentence. English is not my mother language. In case you made a mistake, would you care to retype it? I almost understand it.
