Drag Force Equation Useless in Finding Terminal Velocity
The discussion centers on the limitations of the drag force equation in determining terminal velocity, highlighting that while the equation can yield a tautological result (W=W), it does not effectively solve for the drag coefficient (Cd) or terminal velocity (V) without prior knowledge of Cd. The terminal velocity equation, Vt = sqrt(2W/(p*Cd*Ac)), is deemed more practical when Cd is known. Participants also explore the iterative process of estimating Cd using Reynolds numbers and adjusting calculations based on empirical data. A specific example involving a quarter illustrates the calculations, leading to a corrected terminal velocity of approximately 30 mph. Ultimately, the conversation emphasizes the need for accurate values and units in calculations to achieve reliable results.
picklefeet
As most of you know, the drag force equation is Fd=1/2*p*Cd*V^2*Cd*Ac.
At terminal velocity, Fd equals weight. If you find the value of all the variables except Cd and V, you still won't have anything. But the terminal velocity equation is Vt= sqrrt of 2weight/p*Cd*Ac. So if V is terminal velocity, it is reasonable to conclude that V^2 is equivalent to 2W/p*Cd*Ac. So if you replace V^2 with what I've stated above, you'd get W= 1/2p*Cd*2W/p*Cd*Ac.
This equation is true, but only because it cancels out everything but W. You are left with W=W. This is useless for finding Cd. You could also do the opposite. Replace Cd with (1/V^2*2weight)
pAcCd
In this case everything cancels out too. In conclusion, this formula is useless in finding terminal velocity.
Well, no. Clearly the forumla is useful for finding terminal velocity of an object with a known drag coefficient.
Since I am assuming that you are carrying this over from the previous thread about the quarter...
I'm going to neglect the buoyant force...
F_d = W
\frac{1}{2} \rho V^2 A C_d = m*g
For air you can use STP value of :
\rho = 1.201 \frac{kg}{m^3}
\mu = 1.79 x 10^{-5} \frac{N*s}{m^2}
The quarter has values of:
d = 24.15 mm
A = 4.522 x 10^{-4} m^2
m=5.67 x 10^{-3} kg
So now we have:
\frac{1}{2}\left(1.201 \frac{kg}{m^3}\right)\left(V^2\right)\left(4.522 x 10^{-4} m^2\right)\left(C_d\right) = \left(5.67 x 10^{-3} kg\right)\left(9.81 \frac{m}{s^2}\right)
V^2 C_d = 206.22 \frac{m^2}{s^2}
Now, it just so happens, that if you look up the drag coefficient for a circular flat plate, perpendicular to flow,
it is a relatively constant value of 1.1 which makes this a trivial solution.
V = \sqrt{\frac{206.22 \frac{m^2}{s^2}}{1.1}}
V = 13.69 \frac{m}{s}
However, if you did not have a constant C_d you would guess at the C_d and calculate the resultant V.
From that V you would then calculate the Reynolds Number for that flow using
Re = \frac{\rho*V*D}{\mu}
You would then use the calculated Reynolds Number and look up on a chart the corresponding C_d. If that value you
just looked up comes very close to your guess, you are done. If it isn't, use the new value of C_d you just looked up
and recalculate the velocity. Repeat the Reynolds Number calculation to get another C_d value.
Keep doing that until you converge on a solution. It shouldn't take that many iterations to solve it.
The fact that you got W=W in your result means that you had circular reasoning in your analysis. You did some algebra on the original equation and then plugged it right back into the original equation. If you do that I should hope you get W=W.
The fact is, if I already knew the Cd, I wouldn't have to use the Fd equation.
I'd just use the terminal velocity equation of Vt= sqrt 2weight
pAcCd
And I did find the terminal velocity ofa quarter. It's 83.136 miles per hour (rounded to the nearest thousandth.) on a different not, How do I use the mathematical symbols? i can't find them.
pAcCd
But the terminal velocity equation is derived from Fd = Weight. You're going in a circle again.
You're way off, you slipped a digit or two somewhere. Per Fred's response, the terminal velocity of a quarter falling belly up is about 14m/s, or a mere 30 mph.
I'm realize now that I placed the decimal point one space to the left while figuring out the cross-sectional area (oops). But for some reason I don't see where you got 30 m.p.h. If I plug in 1.17 for Cd, 11.34 g. for weight, .46353465 m^2 for Ac and 1.184 for air density, I get about 10.9914 miles per hour. My problem might be the units I'm using. If so, please correct me. thanks.
You need to use Newtons for the weight, not grams. Also, your area is off. Take a look at my post and you'll see that the area is A = 4.522 x 10^{-4} m^2
Thanks for the info. For the cross-sectional area, do I use centimeters or meters? And I still don't know where to find the mathematical symbols to put in my replies. Can you tell me where they are?
Thank you to all who helped me with this problem. And thanks for the link to the mathematical symbols.
