Draw with Teechart,language Visual Basic
  • Thread starter Thread starter nguyen_de89
    Visual
The discussion revolves around issues with updating a graph using TeeChart in Visual Basic, specifically regarding a delay in data updates that causes the graph to display too many points, making it difficult to see clearly. The user is struggling to manage the graph's data points, wanting to remove the oldest points when new data exceeds 15 points. There is confusion about registration for support, as the user is not a registered customer and lacks a license code. Suggestions include adjusting the pointer size for better visibility and creating a simplified example project to troubleshoot the issue. The conversation highlights the need for clearer communication and understanding of the graph's data management requirements.
nguyen_de89
I have one problem about this matter,data update on graph,delay a long time,then it will cornered,i can't this disposition you can help me!
Hello,
I'm not sure to understand the exact situation. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
"Important note: If you are a TeeChart registered customer,
please post your support questions at Steema's Support
monitored Forums for a prompter reply."
http://support.steema.com
Best Regards,
Yeray Alonso
Steema Support Central
Hi
Sr,i don't know registration that wedside
My problem is data drive left then stand here,so points on graph very thick can't see
i post my file you can see it.Do you use Proteus 7.7
http://www.mediafire.com/?u5o4pxndwgv22lj
Hello,
The support forums are available for Steema customers. If you are a registered customer, you should have a license code and a password you could use to log in that forums.
If you are not a registered customer, please contact us at info at steema dot com.
I'm not sure to understand the problem. Isn't the problem related to drawing speed?
If you want to make the pointer smaller, you could make it smaller with.
Code:
With TChart1.Series(0)
    .asLine.Pointer.HorizontalSize = 2
    .asLine.Pointer.VerticalSize = 2
End With
I've been able to open your project with Visual Basic 6. However does nothing. I think it expects to find something in a COM port...
So, if you still have problems with it, please try to arrange a simple example project we can run a-is to reproduce the problem here.
Thanks in advance.
Thanks for reply
But i don't know how i have license code,Do you have yahoo nick,you can give me,i can exchange easier
You don't understand my problem :D
Detail :On graph have two axial (X & Y),On my graph X is Temperature,Y is Time(Second)
When time is run about 15 seconds,on my graph have 15 points homology with time.
My graph is only contain about 15 points.If 16 points are graph to contracted
I want,if >16 points will delete all 15 points and draw 15 points next.
Do you understand my mean?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
