Driven simple pendulum - system of first order ODEs
4 replies · 3K views
Edge Of Pain
We have a driven pendulum described by the following differential equation:
[itex]\frac{d^2\theta}{dt^2} = \frac{-g}{l}\sin(\theta) + C\cos(\theta)\sin(\Omega t)[/itex]
I need to turn this second order differential equation into a system of first order differential equations (then use a computer to solve the first orders, but that's not the problem here).
None needed
[/B]
We are told to use some numeric values: l = 10cm, g = 9.81m/s^2, capital omega = 5/s, C = 2/s^2, and we are told to turn the equation into a dimensionless equation using the following notation:
[itex]\omega^2 = g/l[/itex]
[itex]\beta = \frac{\Omega}{\omega}[/itex]
[itex]\gamma = \frac{C}{\omega}[/itex]
[itex]x= \omega t[/itex]
Now, putting these into the ODE gives
[itex]\frac{d^2\theta}{dt^2} = \omega^2\sin(\theta) + \omega^2\gamma\cos(\theta)\sin(\beta x)[/itex]
But, the only way I can think of turning this into a system of first order ODEs is by using some dummy variable, y.
In other words, let
[itex]\frac{d\theta}{dt} = y[/itex]
and
[itex]\frac{dy}{dt} = \omega^2\sin(\theta) + \omega^2\gamma\cos(\theta)\sin(\beta x)[/itex]
Is there no way to get it all in terms of theta and x?
EDIT:
I accidentally posted this before it was complete because I hit the "enter" key. Is there a way to turn this feature off? I don't want to get into trouble over posting something which doesn't fit with the rules.
What do you mean? You had it as a system including only theta and t and you rewrite it as a system of two first order equations. That necessarily has to involve another dependent variable, one you decided to call y. It is unclear why you introduce x unless you want a dimensionless number, but then you should replace all occurences of t with x and not mix the notation.
Yeah, my thinking is the same and I think I just need to leave it at that (besides, numerically solving that system results in a graph which looks sensible).
But there is a reason why I need it in terms of x - a later part of the question is that it asks for a plot of theta against [itex]\frac{d\theta}{dx}[/itex], but the solution is for theta as a function of time. Also, it's a numerical solution - I don't actually know what theta is in analytical form so I can't just differentiate it with respect to x by hand.
My thinking is this:
I have the quantity x = omega * t. What If I just do [itex]dx = \omega dt[/itex], giving [itex]\frac{1}{\omega} dx = dt[/itex] and just substitute that into the system? I'm going to try that now.
Orodruin said:
Have you heard of the chain rule?
Yes.
Also I tried to solve this entirely in terms of theta and x, as I said I would above, but it was pointless since the only way to get Python to numerically solve this is to tell it that x is defined as omega * t, then give t values. So obviously it gave the same thing.
