DSP - Differential Equation for linear system H
The discussion revolves around finding a differential equation for a linear system characterized by the impulse response h(t) = e-2t. Participants explore the relationship between the impulse response, the Laplace transform, and the system's output in response to various inputs. The conversation includes technical reasoning and attempts to clarify the steps needed to derive the desired differential equation.
  • Seán seeks guidance on deriving a differential equation from the impulse response h(t) = e-2t.
  • Some participants suggest transforming the impulse response into the frequency domain using the Laplace transform, leading to the transfer function H(s).
  • There is confusion regarding the necessity of the input's Laplace transform, with some arguing that the relationship should be general rather than specific to a particular input.
  • Participants discuss the implications of using δ(t) as the input and how it relates to the output and the transfer function.
  • Seán expresses uncertainty about the steps to take after obtaining the Laplace transform of the impulse response.
  • There is a clarification that the relationship between the output Y(s) and input X(s) is defined by Y(s) = H(s)X(s), which should hold for any input x(t).
  • Some participants emphasize that X(s) should not be arbitrarily set to 1, as it represents a general input function.
  • There is a suggestion to use cross-multiplication to derive the differential equation from the algebraic relationship in the frequency domain.
Participants generally agree on the need to derive a differential equation relating the input and output through the transfer function. However, there is disagreement on the specifics of how to approach the problem, particularly regarding the treatment of the input and the use of Laplace transforms.
Participants express uncertainty about the correct application of Laplace transforms and the implications of using specific inputs versus general forms. The discussion reflects various assumptions about the nature of the input and its relationship to the system's output.
SMOF
Hello.
I need to find a differential equation for a linear system, H, which is characterised by the impulse response h(t) = e-2t, where t denotes time.
But I am not sure how to go about this. Would anyone be able to point me in the correct direction?
Thanks in advance.
Seán
1. Transform your impulse equation into the frequency (Laplace) domain: h(t) --> H(s)
2. Inverse-transform the resultant H(s) transfer function back to the time domain for your diff. eq.
Hint: H(s) = Y(s)/X(s) where X is transform of time input x(t) and Y is transform of output y(t).
Hello,
Thanks for your reply.
I will have a go at this in the morning, and I will let you know how I get on.
Thanks a lot. I just wasn't sure how to tackle it.
Yours
Seán
Hello again.
Can I just make sure I have this right?
I got the Laplace transfer of h(t), which is H(s) = 1/(s+a).
So, now I need to get the transform of the input, which is
0.5 cos(ω2 - ω1)t) + 0.5 cos(ω2 + ω1)t)
But I am really not sure about the Laplace transform of this. I was thinking it was ...0.5 s/(s2 - ω2) ...but I don't think that is right because in the time domain it is ω2 - ω1, and I am not too sure how to get this in the frequency domain.
Seán
You're supposed to describe system behavior for any x(t) input. There should be no specific expression for "transform of the input" for this problem besides "X(s)".
The goal is to have and equation for the system relating the output y and its derivatives to the input x and its derivatives.
Hello,
And thanks fot the reply.
I am afriad I am getting lost on this one.
So, if I can ask, once I have the transform of the impulse, where do I go from there?
I thought I needed to get the transform of the input to the system, and from that, get an equation for the output by relating the input to the system H.
Seán
SMOF said:
Hello,
Seán
Do you know what is the transform of the derivative of a function in terms of that function's transform?
I'm sorry, I don't.
Seán
equation 11 is the general rule for the nth derivative. For the first derivative, this would be as follows.
x(t) \stackrel{\mathcal{L}}{\leftrightarrow} X(s)
\frac{dx(t)}{dt} \stackrel{\mathcal{L}}{\leftrightarrow} sX(s) - x(0)
Hey,
Okay, yes ...I get that ...but (and I am very sorry if this sounds rude, I don't mean it to be) I don't understand how this helps me.
I am more used to the hands on stuff ...building different things ...so, the maths behind it all is very new to me.
But from what you said earlier, that I need to relate the input to the output ...I don't actually know what the output of the system is ...or, at least I don't know if I know it.
If I knew specific steps to take, I might be able to figure it out. Kind of what like Rude Man suggested, except it seem to me like the inverse transform from step one would just take me back to where I was at the start.
Again, sorry for not getting this ...maybe I have just been trying to figure it out for a bit, I just have a bit of a mental block.
Seán
Oh, I think I may have got a bit further on ...I will try it and get back either way :)
Seán
SMOF said:
Hello again.
Seán
The input in your case is an impulse = δ(t). That's what's meant by 'impulse response'.
y(t) is your output = exp(-2t), and Y(s) = 1/(s+2) as you have correctly ascertained.
So the question now is, I know what my response is if the input is δ(t), so what is the response to a general input x(t)? If the input is x(t), what is the output y(t)?
Well, you got the transform of the output right, but you blew it big-time on the input.
What does your Laplace table say for X(s) if x(t) = δ(t)?
Once you have the transform of δ(t) right = X(s), you can then say Y(s)/X(s) = transfer function of your system = H(s).
Do that next.
Hello,
Well, for the table δ(t) = 1. So X(s) = 1.
If 1/(s+2) = Y(s), then H(s) = (1/(s+2))/1 ...?
SMOF said:
Hello,
δ(t) is not 1, δ(t) = δ(t). But L{δ(t)} = 1, that's right. And H(s) is exactly what you said. So write an equation with X(s), Y(s) and H(s)?
Do you mean something like Y(s) = H(s)X(s)?
Yes I do. You know what H(s) is now, so substitute in your equation.
Okay, well, if
X(s) = 1
Y(s) = 1/(s+2)
H(s) = (1/(s+2))/1
I get
\frac{1}{s+2} = \frac{1/s+2}{1}\times1
Which is the same as
e^{-2t} = \frac{e^{-2t}}{1}\times1
I think.
SMOF said:
Okay, well, if
X(s) = 1
Y(s) = 1/(s+2)
No, X(s) and Y(s) represent arbitrary functions, constrained only by the transfer function Y(s)/X(s). You don't get to decide this X(s) is equal to 1!
Think of Y(s)/X(s), as describing a relationship between the output in the input in general. The impulse response h(t) and corresponding Y(s)/X(s) characterize the response of a linear system to any input.
When X(s) = 1 (a transformed impulse), Y(s) becomes the transformed impulse response, of course. But the solution you seek is a differential equation for the system with any input, and so it is not proper to have X(s) equal to 1.
You have determined what H(s) is. You did that by knowing that if x(t) = δ(t), so that
X(s) = 1, so since H(s) = Y(s)/X(s), and Y(s) you have determined to be 1/(s+2) if X(s) = 1, now you know Y(s)/X(s) for any x(t) which, when transformed is X(s). So, stay with your equation: Y(s) = H(s)X(s). That is the key to coming up with your sought-after differential equation.
The next step is transforming that algebraic equation in the frequency domain (never mind for now what I mean by that) into a differential equation in the time domain.
Clue: use cross-multiplication in your equation!
Hello.
I get what you mean about needing to find a solution for any input. It is finally sinking in.
So, since I need to find a silution for any x(t), which is X(s), so would a better form of the equation to work with be
X(s) = Y(s)/H(s)?
I thought to go from the frequency domain (Laplace) to the time domain, I just needed to use the Laplace tables in reverse basically. I take it that is not the case?
And if I stick with Y(s) = H(s)X(s) ...how do I cross multiply this? Anytime I have cross multiplied something it has been in the form of (a/b) x (c/d).
Seán
SMOF said:
Hello.
X(s) = Y(s)/H(s)?
Seán
Substitute for H(s) what you determined H(s) to be in the equation Y(s) = H(s)X(s).
Hello,
Sorry for my late reply, I was in work this evening.
Also, sorry for not getting what you meant ...so, (1/(s+2))/1
Y(s) = H(s)X(s) → Y(s) = \frac{1/(s+2)}{1}\timesX(s)
Well, first make life easier for yourself: (1/(s+2))/1 = 1/(s+2).
Now, perform the cross-multipklication!
So this is just Y(s) = H(s)?
I think I am doing the cross multiplication wrong. This is what I am getting
\frac{1/s+2}{1} = \frac{1}{s+2} → \frac{1}{s+2} x s+2 = 1 x 1 → 1 = 1
And that can't be right.
Cross-multiply Y(s) = X(s)/(s+2)
Where did that come from?
That would get Y(s)(s+2) = X(s)
Sure would.
Now expand the left-hand-side to 2 terms instead of one.
That should be
sY(s) + 2Y(s) = X(s)
SMOF said:
That should be
We are getting close.
We are now going to inverse-transform this equation back into the time domain.
So the 2Y(s) term is obviously transformed to 2y(t).
What are we going to do with the sY(s) term?
Hint: another poster has previously given you a hint as to what to do with this term.
(I have to leave for several hours, will get back about 5 hrs from now.)
The sY(s) is the is the first derivative y'(t)
No worries, it is nearly 3am here, and I need some sleep!
Thanks.
Seán
  • · Replies 16 ·
