Unraveling the Mysteries of the Universe with E8 Theory
  • Thread starter Thread starter billiards
    Theory Universe
An impoverished surfer has proposed a groundbreaking theory of the universe that has garnered significant attention from scientists, primarily due to its simplicity and reliance on only one dimension of time and three of space. This theory is based on the intricate mathematical structure known as E8, which has 248 points and may explain the relationships between elementary particles. Lisi's work suggests that the various particles and forces can be mapped onto E8's structure, with 20 gaps filled by hypothetical particles, including those related to gravity. The theory's validity will be tested with predictions regarding the masses of these new particles, particularly as the Large Hadron Collider prepares to begin operations. Lisi expresses optimism that his theory may yield observable results, potentially surpassing predictions made by string theory.
billiards
Hey, have you heard about this? Check it out...
http://www.telegraph.co.uk/earth/main.jhtml?xml=/earth/2007/11/14/scisurf114.xml
An impoverished surfer has drawn up a new theory of the universe, seen by some as the Holy Grail of physics, which has received rave reviews from scientists.
His proposal is remarkable because, by the arcane standards of particle physics, it does not require highly complex mathematics.
Even better, it does not require more than one dimension of time and three of space, when some rival theories need ten or even more spatial dimensions and other bizarre concepts. And it may even be possible to test his theory, which predicts a host of new particles, perhaps even using the new Large Hadron Collider atom smasher that will go into action near Geneva next year.
Lisi's inspiration lies in the most elegant and intricate shape known to mathematics, called E8 - a complex, eight-dimensional mathematical pattern with 248 points first found in 1887, but only fully understood by mathematicians this year after workings, that, if written out in tiny print, would cover an area the size of Manhattan.
What makes E8 so exciting is that Nature also seems to have embedded it at the heart of many bits of physics. One interpretation of why we have such a quirky list of fundamental particles is because they all result from different facets of the strange symmetries of E8.
Lisi's breakthrough came when he noticed that some of the equations describing E8's structure matched his own. "My brain exploded with the implications and the beauty of the thing," he tells New Scientist. "I thought: 'Holy crap, that's it!'"
What Lisi had realized was that he could find a way to place the various elementary particles and forces on E8's 248 points. What remained was 20 gaps which he filled with notional particles, for example those that some physicists predict to be associated with gravity.
Physicists have long puzzled over why elementary particles appear to belong to families, but this arises naturally from the geometry of E8, he says. So far, all the interactions predicted by the complex geometrical relationships inside E8 match with observations in the real world. "How cool is that?" he says.
The crucial test of Lisi's work will come only when he has made testable predictions. Lisi is now calculating the masses that the 20 new particles should have, in the hope that they may be spotted when the Large Hadron Collider starts up.
"The theory is very young, and still in development," he told the Telegraph. "Right now, I'd assign a low (but not tiny) likelyhood to this prediction.
"For comparison, I think the chances are higher that LHC will see some of these particles than it is that the LHC will see superparticles, extra dimensions, or micro black holes as predicted by string theory. I hope to get more (and different) predictions, with more confidence, out of this E8 Theory over the next year, before the LHC comes online."
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
