"Easy" but cool electrical engineering projects
6 replies · 5K views · last reply
Josh225
Hello, I am looking for an "easy" but cool electrical engineering project. I've tried to make a mini tesla coil, but I keep messing up the coil part itself, so I am taking a step back from it for a while. Are there any relatively easy (I am beginning) electrical projects that you have heard of, seen, or done yourself?
I would like to learn something from the project so I can apply that concept to future projects and help me understand the properties of electricity better. I also have an interest in magnetism, so a project that has to deal with electromagnetism would be cool too!
Also, Id rather not spend too much money. My limit would probably be around $20.
Thanks a lot!
How about making your own battery powered motor? Just search for DIY electric motor on youtube, and you should find several videos showing how.
Some sort of electro mechanical clock?
My dad once had a clock like that powered by a battery.
It was a pendulum clock. But instead of a main spring it had a little solenoid coil located close to the bottom of the pendulum's swing. A circuit gave that coil a pulse of current once each swing and the magnetic force gave the pendulum a tiny kick. One tiny kick each tick (a kick per tick :smile::smile::smile:) is all that is needed to keep a clock running. You could start with an existing pendulum clock and modify it.
I found a video of something similar.
These are handy for experimenting when just starting out
http://www.jameco.com/z/WBU-301-R-400-Point-Solderless-Breadboard-3-3-Lx2-1-W_20601.html
Photo of a white solderless breadboard with rows of contact holes, red and blue power rail lines along the edges, and lettered and numbered row and column markings.
build your own adjustable power supply from "Wall-Wart" transformers and adjustable regulators
junkshops are full of them
mount it on a box that'll hold your meter and small hand tools..
Find yourself one of these:
https://www.amazon.com/dp/B004573D80/?tag=pfamazon01-20
and you get a center tapped secondary. You can make an adjustable power supply with + and -.
I have no idea what the part number for the 220VAC version is. This is 110.
BoB
It is slightly above your price range ($35 + shipping), but an arduino is a great choice.
https://www.adafruit.com/products/193
this set comes with an arduino (programmable micro-controller) , breadboard (see jims post), resistors, switches, etc.
You can use these to make countless projects. you can also spend some more cash to buy motors and other things to control with the arduino. This would teach you a lot about software, and give you the ability to rapid prototype and control other larger projects in the future.
