Solve Econ Math Problem: Price & Quantity of Apples
  • Thread starter Thread starter Error Prone
The discussion centers on solving an economics problem involving the supply and demand equations for apples. The user correctly calculates the equilibrium price at $10 and the equilibrium quantity at 80 apples, but expresses confusion about the relationship between price and demand. They mistakenly believe that a higher price should correlate with higher demand, which contradicts the downward-sloping demand curve. A suggestion is made to graph the supply and demand curves to clarify the concepts visually. The key takeaway is that the user has successfully found the equilibrium but needs to understand the inverse relationship between price and quantity demanded.
Error Prone
I'm probably making a really stupid error (I often make those in numerical contexts!), but I'm having a bit of trouble with an introductory economics assignment that involves a little elementary algebra.
BACKGROUND: We learned about the supply-demand equilibrium - a price at which the quantity supplied equals the quantity demanded.
QUESTION: Suppose the demand & supply for apples is given by:
Demand: QD = 100 - 2P
Supply: QS = 50 + 3P
a) Solve for the equilibrium price and quantity for apples.
MY SOLUTION:
Well, I made both equations equal & solved for the unknowns:
100 - 2P = 50 + 3P
50 = 5P
P = 10
Since 50 + 3(10) and 100 - 2(10) both equal 80, then QD = QS = 80
And it seems all nice & what not, but then the next sub-question asks:
"With price on the vertical axis & quantity of apples on the horizontal axis, graph the demand & supply curves & illustrate the equilibrium price and quantity".
So, to try finding some points on the curve I tried to find the price at which demand would equal zero.
QD = 0 = 100 - 2P
2P = 100
P = 50
BUT 50 IS A LOWER PRICE THEN 80! And I was taught that the demand of a good goes up as it's price goes down, so this makes no sense. At 50, their should be more demand that at 80, NOT LESS!
Am I confusing something here?
MY SOLUTION:
100 - 2P = 50 + 3P
50 = 5P
P = 10
QD = 0 = 100 - 2P
2P = 100
P = 50
Plot it and label the plot and you will figure out your confusion.
With Economics curves use anything, but plot it. You don't need complex math software, even a graphing calculator. The plot will illustrate the concept.
According to your work, the quantity was 80, not the price. The price was 10.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
