Effect of capacitor plates at different angle
The discussion focuses on simulating a capacitor with plates angled at 195 degrees. It establishes that while electric lines of force will not follow a purely elliptical path as they do at 180 degrees, they will retain some similarities due to the configuration. The use of the inverse cosine function for mapping these lines is questioned, with uncertainty regarding the existence of an analytic solution. Numerical simulations are suggested as a viable approach to approximate the behavior of the electric field in this scenario.
  • Understanding of electric field theory and capacitor behavior
  • Familiarity with numerical simulation techniques
  • Knowledge of mapping functions, specifically inverse cosine function
  • Basic skills in computational modeling and analysis
  • Research numerical simulation methods for electric fields in capacitors
  • Explore analytical solutions for non-standard capacitor configurations
  • Study mapping functions and their applications in electrostatics
  • Investigate software tools for simulating electric fields, such as COMSOL Multiphysics
Electrical engineers, physicists, and students interested in capacitor design and electric field simulations will benefit from this discussion.
FALI
Hi,
I am interested to simulate the capacitor with plates having an angle of 195 degrees between them.
https://dl.dropboxusercontent.com/u/32847378/cp1.jpg
I know that if the angle between of plates is 180 deg, then electric lines of forces will follow a elliptical path and equipotential lines perpendicular to them as shown in image,
https://dl.dropboxusercontent.com/u/32847378/coplanar1.jpg
and for mapping inverse cosine function is used. i.e. W = inv. Cos (Z)
where W = x + i y , Z = u + i v
So, for my case
  1. Will the electric lines of forces still follow the elliptical path?
  2. Can they also be mapped using inverse cosine function or will there be a variation?
This will help me in finding the capacitance. Thanks in advance.
Not exactly, but they won't be completely different because your setup still looks similar.
It is not clear if there is an analytic solution at all.
Hi,
Thanx for the reply. so, do you have any idea to solve that type of problem?
Numerical simulations?
Yes analytical solution. For that i know the correct tranformation (mapping) function. It would be nice to go into a detail of that problem
Huh?
I don't know if there is an analytic solution. A numerical approach will certainly give a good approximation (as good as you like if you have enough computing power).
20K
12K
