Effect of temperature on capillary rise
Increasing the temperature of a liquid generally reduces its surface tension, which could lead to decreased capillary rise. However, as temperature rises, the liquid's density decreases, which reduces the weight of the liquid column that needs to be lifted. The overall effect on capillary height depends on the balance between these two factors, varying by liquid and temperature. For example, water's density increases from 0°C to 4°C, complicating the relationship. In equilibrium, the height variation is influenced by the ratio of interfacial energy to density, assuming a constant contact angle.
Binayak95
We all think that by increasing the temp of a liquid, the surface tension would reduce and so capillary rise will not be as high. But on increasing the temp, the liquid's density also decreases and so the weight of liquid to be lifted also reduces. Which will have the dominating effect, decrease in the weight of liquid leading to an increase in capillary height or a decrease in the surface tension causing a fall in the capillary height?
Science news on Phys.org
It will depend on the liquid and the temperatures involved. E.g. water gets denser from 0C to 4C.
Presumably you are referring to equilibrium, as opposed to say, thermocapillary flow (Marangoni effect). AFAIK, the interfacial energy is a monotonically decreasing function of temperature (since it goes to zero at the liquid-gas phase transition), but the temperature dependence of the contact angle is less clear- at least, I couldn't easily find any useful data.
Since we are discussing equilibrium, the usual formula applies and the variation of height will go as δ(σ/ρ), where σ is the interfacial energy and ρ the density (assuming the contact angle remains constant).
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
