Effect of temperature on Entropy
The discussion centers on the relationship between temperature and entropy, particularly through the equation dS = dQ / T. It highlights that while higher temperatures generally lead to increased entropy due to more available energy states, lower temperatures can yield larger changes in entropy for the same amount of heat added. The conversation emphasizes the importance of context, such as whether the heat exchange is reversible and the specific conditions of energy input. An analogy is provided comparing the shuffling of cards in different states of order to illustrate how entropy changes with temperature. Overall, the key takeaway is that the change in entropy is influenced by both the temperature and the nature of the heat exchange.
weng cheong
i'm a pre-U student, and i came across this when i study the topic on entropy
dS = dQ / T
i understand that as temperature increases, entropy increases as well, as there are more quanta of energy and more thermal states(energy levels) available.
however according to this equation, it seems to indicate that with a lower temperature, we can get a greater entropy?
Science news on Phys.org
S is entropy. dS is change in entropy.
So, for a given temperature T, the change in entropy is equal to the change in heat energy divided by whatever the temperature that system is currently in.
The equation you wrote describes the infinitesimal increase in entropy of a system at constant temperature when infinitesimal energy is added reversibly by heating. That's not the same as the change in entropy of a system with increasing temperature, which is \partial S/\partial T. This quantity is, indeed, always positive.
You can integrate your equation to get \Delta S=Q\ln(T_2/T_1), which confirms that entropy increases with temperature when a system is heated.
Does this make sense?
You get a larger change in entropy, that's correct.
ETA - I figured that constant temperature and reversibility were givens, considering the Clausius formalism used by the OP. (Although that dQ should be dQrev, which is how I recall seeing it written in textbooks.)
ETA 2 - One analogy that might be useful - if you scream at a sports game (add a tiny bit of energy to a high-temperature system), most likely you will not make that much of a dent in the general soundscape (a small change in entropy). If you yell in the middle of a wedding (adding a tiny bit of energy to a low-temperature system), it would be far more dramatic (a large change in entropy).
Careful!
The temperature of the the system at the point (moment) of heat exchange, currently is a bit vague and could mean after the exchange.
Note also it is a differential relationship so may be integrated from point to point.
Imagine this situation.
You provide X joules of heat to a system at
1)say 100 K and 2)say 300K
So, in the first case, what you will observe is the there will be a larger change in the randomness than in the second case, as due to the pre-existing higher temperature, there will be already a large amount of disorder in the system!
It's just like shuffling a deck of kinda properly arranged cards (analogous to a lower T) will give you a larger change in disorder than shuffling a pack of cards that are already random in order (higher temperature!).
Am I correct?
The entropy change in the system, in both cases, depends upon the conditions of energy input, which have not been specified.
and can you please help me out wit what that is? :)
If both additions of heat are reversible then the entropy change of the second case input is 1/3 of the first.
The addition of heat may become the work of expansion, which allows greater entropy in the form of freedom of space to occupy,
or
It may be taken up in a phase (state) change so the particles become more disordered.
  • · Replies 16 ·
