Effective absorption coefficient of gold nanoparticles
The discussion centers on the effective absorption coefficient of gold nanoparticles in the context of modeling laser heating of silicon wafers with a femtosecond laser. Participants explore the optical properties of gold nanoparticles, particularly focusing on the absorption cross section and its implications for laser propagation in layered materials.
  • One participant describes their research internship involving the modeling of a 5nm gold nanoparticle's absorption cross section using COMSOL Multiphysics, noting agreement with Mie Theory.
  • The same participant expresses concern over the calculated absorption coefficient being significantly lower than that of bulk gold, questioning the validity of the formula used: $$\mu=\sigma_{abs}n$$.
  • Another participant suggests that the small size of the nanoparticles relative to the wavelength may result in minimal scattering effects.
  • A later reply emphasizes the importance of distinguishing between scattering and absorbance, suggesting that the calculations may not directly correlate with absorbance values.
  • One participant confirms that the initial calculation appears correct, but raises the possibility that the number density provided by the supplier may pertain to a liquid suspension rather than a dry layer of nanoparticles.
  • There is a suggestion to consider the packing density of nanoparticles in a dry layer to obtain a more accurate absorption coefficient.
Participants do not reach a consensus on the correct approach to calculating the effective absorption coefficient. Multiple viewpoints are presented regarding the implications of nanoparticle density and the distinction between liquid suspensions and dry layers.
Participants note potential limitations in the assumptions made regarding the nanoparticle density and the nature of the medium (liquid vs. dry). There is also uncertainty about the relationship between scattering and absorption in the context of the calculations performed.
Luke137
TL;DR
I am using COMSOL to model the optical properties of gold nanoparticles when laser light is incident on them. I am unsure about how to correctly calculate the effective absorption coefficient for a sample of these nanoparticles.
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and they agree with solutions to Mie Theory for the scattering around nanoparticles.
In my laser heating model I need the absorption coefficient of the different material in order to model the propagation of the laser in each layer. The plan was to find the effective absorption coefficient of the nanoparticles using the EM model and then apply that to a 100nm thick layer in the laser heating model (this is roughly the thickness we estimate the nanoparticles will take up). The problem I am having is with finding this absorption coefficient. I have seen in the literature it is common to use the following formula to calculate the absorption coefficient:
where ##\mu## is the absorption coefficient, ##\sigma## is the scattering cross section and ##n## is the number density of nanoparticles. From my model I am getting an absorption cross section of ##\sim 8e-18\ m^2## and from the nanoparticle supplier website I am getting the concentration to be ##5.5e19\ particles/m^3##. Multiplying these gives a value of ##\mu \approx 440\ 1/m##. This seems very low, especially since the absorption coefficient for bulk gold at 515 nm is ##\sim 1.14e6\ 1/m##. Is there something wrong with the formula I am using? I was thinking that maybe all I have done is calculate the absorption coefficient for a single "layer" of nanoparticles that is 5nm thick. If that is the case my value is off by a factor of 20 if I am modelling a 100nm layer. However, I am not sure if that is a valid way to go about this.
Any advice would be appreciated!
Science news on Phys.org
I really have no business "answering" this question and I suspect it should've been marked with an 'A'. Also, I intended to wait until views (and no replies) reached 100, but your question will probably drown. I also know that bumping threads is strongly discouraged, but maybe it'll catch the attention of a real solid state physicist. I know they have a nest here somewhere...
Until then I assume you've read this:
Enhanced absorptance of gold following multipulse femtosecond laser ablation.
It's behind a paywall or something, but then again I have no business reading papers like that anyway.
The particles are only 1/100 wavelength in size and the 100nm layer is only 20 particles thick, so scattering might be rather small.
Luke137 said:
TL;DR Summary: I am using COMSOL to model the optical properties of gold nanoparticles when laser light is incident on them. I am unsure about how to correctly calculate the effective absorption coefficient for a sample of these nanoparticles.
I think you likely need to be more carefull in your definition of "absorbance". One cannot necessarilly conflate "scattering" with "absorbance". I do not know what your particular calculations provide.
No, your calculation seems about right. There is no layer thickness involved in this calculation. Usually you get the transmitted intensity I through a system of thickness d by calculating: $$I=I_0 e^{-\mu d}$$.
However, you mentioned that your nanoparticle supplier gave you some particle number density. The suppliers usually give this as a density per ml because nanoparticles are usually sold as a stable suspension in some liquid medium. What you calculated is then the absorption coefficient of this liquid suspension.
Is that the case and if so are you interested in the properties of the suspension or do you want a dry layer of gold particles forming at some surface? If so, it might be more appropriate to assume a more realistic density of particles for the dry layer without any liquid. Probably, as a first educated guess, you can just model the gold nanoparticles as spheres that form some hexagonal closed packing ordering, estimate the particle density of that and reduce the density by a few percent to take some stacking faults into account.
I knew you were around here somewhere! Let’s hope the OP checks back so you haven’t all wasted your time. I’m aware I didn’t contribute anything but a thread-bump.
Perhaps he solved it himself or with the help of a IRL homework-helper.
:smile:
  • · Replies 0 ·
  • · Replies 0 ·
