Efficiently Lift 10KG with a Small Winch Motor - Expert Tips and Tricks
  • Thread starter Thread starter bowlingo
    Motor Winch
The discussion focuses on finding a suitable small winch motor to lift 10KG approximately 6-12 inches every couple of weeks, with a final lifting point 5 meters away. The user has struggled to find off-the-shelf winches, as most start at 125KG, which is too large for their needs. They have ordered a geared DC motor that should work for their application and are considering building a custom solution using a metal box and a spool. Suggestions include using a shaft coupler to connect the motor to the spool. The conversation also raises the question of whether a winch is necessary for lifting only 10KG.
bowlingo
Hi all,
I am trying to lift 10KG around 6-12 inches every couple of weeks of which will end up 5 metres from the original lifting point...I am asuming I will be using wire on the winch
I am basically looking to get my hands on a small winch. The only ones I can find online are winches that start from 125KG of which are far to big and won't look good attached to the ceiling..
Today I contacted a motor specialist and have this one arriving tomorrow of which the tech guy said will do the trick as it needs to be geared so it can lift around 12 inches in several minutes.
https://catalog.precisionmicrodrives.com/order-parts/product/2a2-300-102mm-dc-gearmotor-89mm-type
The way I can sort of see me getting this to work (unless someone has seen a tiny winch that's off the shelf) is to fix it inside a metal adaptable box...slide some kind of shaft extension bar inside the box so it lines up with the original motors 8mm wide, 23.2mm long part flattened shaft, somehow fix it in place, put some kind of spool on the end of the protruding shaft (might only need the furthest end to have a spool as the metal adaptable box could act as the other end) fix a 5metre thin wire onto it and loop it over.
I don't know anyone locally who has a lathe etc so my only hope is to use affordable items that are off the shelf
bowlingo said:
Hi all,
Welcome to the PF.
To attach the two shafts (motor shaft to spooling shaft), you would use a shaft coupler:
http://www.google.com/search?tbm=isch&hl=en&source=hp&q=shaft+coupler&gbv=2&aq=f&aqi=g1g-m2&aql=&oq=
Sorry to be possibly insulting but if you only need to lift 10Kg why do you need a winch?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
