Effusion Question about Uranium enrichening
  • Thread starter Thread starter CAF123
    Effusion Uranium
The discussion revolves around calculating the number of passages needed to achieve a uranium isotope purity of less than 1% contamination using Graham's Law of Effusion. The initial calculation suggested a need for approximately 9840 passages, but further analysis indicated that the fluorine atoms' mass must be included in the calculations. After correcting the approach, the ratio of isotopes per passage was recalculated, leading to a revised estimate of about 1151 passages to achieve the desired purity. The importance of accurately accounting for all components in the effusion process was emphasized. Ultimately, the participant confirmed the accuracy of their final answer after addressing rounding errors.
CAF123
A gas with equal number densities of uranium hexafluoride (UF6) molecules containing two isotopes of uranium, atomic masses 235amu and 238amu, is passed through a porous membrane containing very small holes. Use Graham's Law of Effusion to calculate:
How many successive passages through similar membranes would be needed to produce one isotope contaminated by less than 1% of the other isotope?
Grahams' Law: $$\frac{v_x}{v_y} = \sqrt{\frac{m_y}{m_x}}$$
So we want ##v_x > 99##%## v_y##. I calculated that per passage, ## v_x## is greater than ##v_y## by about 1.006. Then I divided this by 100 to get the percentage increase and divided this by 99. This gives about 9840. I think the correct answer is about 1070.
Many thanks.
Two passes mean 1.0062.
Many thanks.
For starters, have you considered the fluorine atoms' mass in your calculation? (It appears that you haven't)
Also, the 1.006 figure (or whatever you actually get after you account for the fluorine) is a ratio. Simply dividing it by 100 is not a way to get a percent. Instead, let me ask you this: if 1.006 is the isotope ratio after passing through one membrane, how would you calculate the ratio after passing through two membranes?
(Hint: see Borek's post :smile:)
In that case, per passage, the ratio would be $$\sqrt{\frac{238 + 19(6)}{235 + 19(6)}}$$
(1.004)2, where 1.004 is the new ratio I calculated.
EDIT: From your advice, I have:
We want the ratio of isotopes to be such that there is (in fact more than) 99 times more than the other. So we find ##n## such that ##(1.004)^n > 99 \Rightarrow n ## is roughly 1151. Is this correct?
EDIT2: I get the required answer by not making rounding errors. Thanks for the help.
Glad it worked out. :approve:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
