Elastic collision between neutrons and deuterons
3 replies · 30K views
Edwardo_Elric
Canadian nuclear reactors use heavy water moderators in which elastic collisions occur between neutrons and deuterons of mass 2.0u.
a.) What is the speed of a neutron expressed as a fraction of its original speed, after a head-on elastic collision with a deuteron which is initially at rest?
b.) What is its kinetic energy, expressed as a fraction of its original kinetic energy?
c.) How many such successive collisions will reduce the speed of a neutron to 1/6600 of its original value?
If the 2nd particle is at rest
[tex]V_{A} = \frac{m_{A} - m_{B}}{m_{A}+m_{B}}[/tex]* V2
[tex]V_{B} = \frac{2m_{A}}{m_{A} + m_{B}}[/tex]* V2
let n = neutrons , dn = deuterons
a.)
VnMn = MnVn2 + MdnVdn2
using equation above:
[tex]V_{n2} = \frac{2.0u - 2.0u}{2.0u+2.0u} V_{n}[/tex]
Vn2 = 0
b.) K2 = ?
since Vn2 =0
VnMn = Vdn2
K2 = 1/2 (2.0u)(Vdn2)2
K2 = u(Vdn2)^2 <<<< K equals velocity of deuterons squared times u
c.) (2.0)(1/6600Vn) =
3300 collisions
I honestly don't know about this
For an elastic collision one applies conservation of momentum and energy.
Intially, the deuteron at rest, Vd, is zero, so it has not momentum or KE.
The neutron will not lose all its energy or momentum, but will recoil 180°.
So write the momentum and energy equations and one should end up with
http://hyperphysics.phy-astr.gsu.edu/hbase/elacol2.html#c1
but i thought masses are the same:
which makes
v{initial speed of neutron} = (m1 - m2) / (m1 + m2) * V{final speed of deuteron}
equal to zero? and the deuteron goes to move which has a speed equal to the initial speed of neutron?...
which makes
deuteron has a mass of 2.0u. Neutro has a mass of 1.0u
